Wanted - Updated tensioner bracket 202786 | FerrariChat
Wanted Updated tensioner bracket 202786
Discussion in 'Ferrari Parts & Collectibles' started by RedNeck, Sep 6, 2022.
  1. RedNeck
    RedNeck F1 World Champ
    12,303
    The CSA
    Me
    I ordered one from Eurospares a year or more ago, but when I finally went to use it, I discovered its the wrong one that doesn't have the hole to accept the centering bushing according to TSB1315, I wanted to replace this bracket to update the car to the more reliable tensioner but it seems that everyone that has it actually has the old bracket and has it listed wrong. The highlighted part is the part that needs the wider, deeper hole.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Remove the bushing (as the TSB recommends), problem solved.
  3. RedNeck
    12,303
    The CSA
    Me
    True… but that pretty much defeats the purpose of the updated tensioner. Engines already in a million pieces, I might as well do it right.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    If the engine is apart. It would be a simple matter to modify the bracket to accept the bushing.
    f355spider likes this.
  5. RedNeck
    12,303
    The CSA
    Me
    I don't have a drill press unfortunately. Is this something you have to do often?
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I haven't needed to do it.
    I have a machine shop, and could easily bore the recess if necessary.
  7. windsock
    windsock Formula 3
    1,153
    Most of these have all been updated in our area. Occasionally we see one and simply drill the hole oversized and install a stainless helicoil.
  8. Rifledriver
    37,099
    I really do not like that method. The support dowell had a very good reason for being there. It takes the shear load off the bolt. They have had the bolts break and Ferrari introduced that fix (and it was a good one) but then discontinued the mount.
    I have installed many and never bought the mounts. It is an easy modification to make the mount accept the updated tensioner. I have done 2 in the last couple of weeks.
    2NA likes this.
  9. Rifledriver
    37,099
    It is simple anyway.
  10. RedNeck
    12,303
    The CSA
    Me
    Exactly...one of the main reasons I am updating that tensioner is because of the new "design". Removing the bushing would make it an exercise in futility IMO. I don't have access to a machine shop but it may be easier just to send it to someone with experience to modify the current bracket if that's truly the only difference.
  11. Rifledriver
    37,099
    Updated tensioner is also stronger. One of the mounting ears was breaking off on the previous design.
