Upgraded Kevlar Timing Belts | Page 2 | FerrariChat
Discussion in '348/355' started by MicroFirm, Sep 7, 2016.
  1. fatbillybob
    Aug 10, 2002
    29,252
    socal
    That's the cool thing living in the 1st world we got choice. You are free to choose whatever you want. What you call popular opinion I call hard won over decades of experience. You see I have used only Ferrari bearings when that's all there was. I used the 1st Hill bearing when they had no serial numbers. I did not need to be a scientist to see the grease puking out of the OEM tensioner bearing yet the grease staying in the Hill bearing. I could feel the roughness of a used OEM bearing that still was not near failing. But a similarly used Hill bearing was smooth. I don't need to be a scientist to feel a 0.001" of play and want something better. For the very little difference in cost I'll take the hill bearing and a Ferrari branded yellow T belt. I do my own work so I can spend it in parts. Some DIY'ers are still changing T-belts with nail polish timing marks. The 8 year old NOS dayco belt is perfect for that person. And the cool thing is it all works within the service life specified. But if you want a little more you have to do a little more just like you have done with sticky parts. It seems you have taken that to the next level. Why? The same reason you buy a Ferrari branded yellow T-belt.
    Unfortunately there is so much history between you and me that we could not agree if a turd stinks.
  2. Jon Von Bon
    Jon Von Bon Formula 3
    1,697
    Toronto / Florida
    Jeff
    LOL!
    Carl, many on the coast know you well. Your experiences, like others here, with these cars spans many decades. I hope that I am not embarrassing you here but You, like many other of the great contributors here have intuitive and hard won experience that goes beyond what a book or measurement or "scientific" sum offers. Frequencies, harmonics and the combination of the components that deliver the overall performance of Ferrari goes beyond what is found in most other car manufacturers. On paper, a lot of it doesn't even make any sense, but it works and it's that magic that sets Ferrari apart.
    I bet if you went through Cralls books you would find notes on every single component that would turn many "scientific" scenarios on their head. Many of us here that have racing experience, in my case motorcycles, you experience builders and tuners that have the ability and the magic who are able to pull it together to provide a faster car/bike than anyone else on the field. Anyone has access to science or the ability to follow where those have gone before. Anyone can read a micrometer or read a book. It's in the realm that lies between the lines where the innovation and magic lie.
  3. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    Same story for Audi's. The belt will last 15 years (don't ask) but the tensioner and water pump will not.
  4. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,269
    Worcester, England
    Phill J
    When I bought My 348 a couple of years ago from The Ferrari Centre in the UK, I got talking to the owner Roger Collingwood about how often the cambelt should be changed and he informed Me that the belts themselves are actually very robust, and that in their experience, on the 348 and 355 it's always been either a failed belt tensioner or a failed water pump that has taken out the timing belt - They had never seen a belt fail on it's own.
    He also said that on the 348 he would have no worries extending the cambelt service from 3 years to every 5 years, but on the 355 they recommend sticking with the 3 year changes as the belt tensioners on the 355 can be more temperamental.
    Make of that what you will, agree/disagree, whatever - That's what I was told.
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Phill,
    No argument, just a discussion.....
    The belts have been given the 3 year term based on time, not usage. Perhaps that is understandable for a belt? But for items like bearings, unless the car is in a poor environment, bearings will fail mostly due to usage so in that case, mileage should be a leading criteria over time.
  6. fatbillybob
    Aug 10, 2002
    29,252
    socal
    Agreed. No argument just discussion. I don't think there is any data for your last statement. I think bearings once put in use fail over idle time just as much as with higher miles for reasons like a 5 y/o timinig belt with only 500miles should be replaced with as much urgency as a young belt with 30,000miles. There is a difference between a bearing on the shelf in the yellow box and a bearing sitting idle installed on the car even with its only mileage to drive it off the lift and both bearings live in the same garage. I have seen this kind of sitting bearing failure of time in real life. I'm not a scientist but I can guess why. Bearing once put in use scrapes grease off balls. There is metal to metal contact upon sitting giving rise to pitting and fretting corrosion. Use the bearing let sit get this corrosion in new spot. Rinse and repeat until bearing death. Contrast that with bearing used everyday. There is no corrosion only wear that engineers have accounted for in their service life recommendations.
    None of this matters of course if reasonable service intervals are used.
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The idea of replacing bearings every 3 years on a street car, is just over servicing unless said bearings are poor quality to begin with.
    5K miles and 4+ years on my OEM tensioner bearings (often seeing 8500 RPM) and no issues presently...
    Carl, given your statement above, we would be replacing many other bearings on regular intervals too like the ones for the wheels :)
  8. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    +1. I agree with Dave. Its mileage for the tensioners, not time. As for belts, mileage should be taken into account. But for most of us who don't put on many miles each year, a 355's belts are better judged on time. And it should also be remembered, unlike the 348s, 355 belts don't turn anything but the tensioners and cams. So tensioners aside, the only thing of concern is the belts themselves. However these belts will last a surprisingly long time, easily more than 3 to 5 years. I know of several that were changed at 7 and 8K (and one at 13K!!!) but still looked just fine. Not that I'm advocating 8 years between belt changes, just that they are more robust than most give them credit for.
  9. Jon Von Bon
    1,697
    Toronto / Florida
    Jeff
    Bottom line is, these things fall apart and it gets hot in there so just like oil changes are an excuse to get under the car and look for what else might be going on, 5 years is a good marker for getting the engine out and looking over what you can't see during regular use. I pull them out every 5 years unless I see, hear or smell something going on beyond the visual once over whilst doing regular operational maintenance.
  10. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    #35 SoCal1, Sep 14, 2016
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Yeah screw that unless you have an oil leak or open belt drives
    I have blown my share of open primary belts I mean the BIG STRONG ones not these pee shooter one we use
    2 main causes of failure are foreign object and out of true belt pulleys. Laser test/align your pulley alignment all the time
  12. MicroFirm
    MicroFirm Karting
    Dec 6, 2010
    231
    Colorado
    Frank
    I just tried googling that belt and don't readily see a P/N. Is that made for the 355 or have you substituted specs?
    Do you have a P/N you can share?
  13. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Well, I can speak to the tensioner bearing on the 308. Mine were replaced for the first time at 27k miles, 25 years. There is noting obviously wrong with them. Seals good. No play. Spin smoothly. I guess applying Carl's logic, vis-a-vie the GCK, I can generalize that T bearing last at least 25 years. No problems, no worries.
    FWIY, when shopping for my 355 I looked at several cars that had 10 years or more since the last major. No broken belts, bearing, etc.
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Thats for a Top Fuel car :)
  15. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    By the way. Pretty obvious everyone is bored. Seems topics are being invented to discuss. Let's talk about headers next. Then we can revisit valve guides, lead down tests, dash shrinkage,...what else, tires, top tier gas, skinny blonds, penis size?
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    I just sprayed peppermint and clove oil on my yard, smells nice :)
  17. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    I just sprayed UR 50 reducer all over my garage. I'm high!:D
  18. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Damn, wish I could. Think I tossed it. Plugzit saw it and, in fact, it came apart in his hands when he helped me with my last major. I don't think all 348's (or 355's) do this, but it did happen to me with a stock replacement part. Just wanted to react to the comment about bearings not failing.
  19. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    Why can I relate to that :)
  20. fatbillybob
    Aug 10, 2002
    29,252
    socal
    Science seems to look at absolutes. If a the parameters that made the tacoma narows bridge perfect are held to then the bridge is perfect. The problem was having full grasp of other parameters especially those that caused the bridge to collapse. A wheel bearing is not equal to a tensioner bearing just because they have "bearing" in their name. Ferrari has had an interesting issue with wheel bearings. They don't seem to fail. In fact this wear item on so many other cars is a NLA item on some models of "modern" ferrari or are so expensive that we use aerospace bearing rebuilders to refurbish them. For just about any other car you buy them at the autoparts store. Why? I can only guess that this is one place ferrari seems to over build for durability. Remember, I'm not a scientist but from my limited understanding if my corrosion theory holds them big giant balls in a wheel bearing is going to corrode from sitting quite a bit differnt from very small diameter tensioner bearings. Add that to the ability of any end user to "tech" inspect his wheel bearings just like every amater racer who goes out on track. Tensioner bearings are hidden and some you can't even see covered by covers. Tell tail puking of grease is often not seen until the next major or until it gets so bad they make noise.
    Then you have to consider other bearings use. If you have a layshaft tranny bearing living in oil that is a very different environment. You can't shear lubricant off an immersed bearing like you can in a packed in gease bearing.
    So the answer is no. I think you have to look at the entire context especially if one uses the car outside the typical envelope. For example when I raced my 348, I changed my T belt annually. Was that overkill? I dont know. There is no data.
  21. plugzit
    plugzit F1 Veteran
    7,791
    Redondo Beach, CA
    Bruce Bogart
    Every belt failure I've seen began with either bearing or installation problems. I haven't seen a belt fail independently on a 348.
    WATCH OUT! GRENADE IN THE FIRE!
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #47 Dave rocks, Sep 14, 2016
  23. johnk...
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    OMG someone actually posted a picture. :)
  24. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Right of a wheel bearing in a timing belt thread!
    No problem. Hijack on.
  25. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Bob, you have been around long enough to know not a single thread stays on topic :)
