Upgraded my Headlights to LED's | Page 2 | FerrariChat
Discussion in '348/355' started by 308gtsqv, Dec 28, 2015.
  1. Subarubrat
    Subarubrat Formula 3
    Apr 1, 2009
    2,072
    VA
    Scott
    I get it, someone has to jump first, I bought HIDs when they were 10x what they cost now and a fraction as reliable. I am just pleased to see that they have come this far, and what that means for just a few months from now.
  2. nismodrifter
    nismodrifter Formula Junior
    Jun 11, 2008
    548
    YYC/YVR
    Navdeep
    Excellent, will probably go LED once summer rolls around.
  3. ferrari bud
    ferrari bud Formula Junior
    Jun 29, 2014
    261
    SF Bay Area
    Chris
    OP, can you confirm your headlights are the 5000K color? I got an email from OPT7 saying they don't make a 5000K color for some reason. I'm asking them to confirm.
  4. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,254
    Huntsville, AL., USA
    Andrew
    That sounds like a much better idea than HID kits.
    Could we see an illuminated picture from the front of the car? :)
    All the best,
    Andrew.
  5. 308gtsqv
    308gtsqv Formula Junior
    Feb 12, 2008
    610
    Mass/Cape Cod
    #30 308gtsqv, Dec 30, 2015
    So when I searched on eBay I specifically looked for 5k not 6k as I didn't want them to look to Blue.
    So you can see from the link I posted they advertised them as 5k. I just went and looked at the box that shipped and they are indeed 6000k not 5000k. I will say I'm a bit irritated that the misrepresented them but the end result is a White color. So it's a "it is what it is" kind of thing.
    I would still recommend them.
    Sure, not sure if this give you a good enough idea, its raining here right now. I'll take better shots later in the week.
    NeuroBeaker likes this.
  6. madturk
    madturk Formula 3
    1,508
    Williston, ND
    Seyhan Kilincci
    That looks hid bright.
  7. ferrari bud
    Jun 29, 2014
    261
    SF Bay Area
    Chris
    How much of a blue do you see? Like you, I'm not a fan of any blue tint.
  8. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,254
    Andrew
    Thanks, that looks good. :)
    All the best,
    Andrew.
  9. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,610
    Menlo Park, CA
    Paul Chua
    This is an awesome post, thank you so much for sharing.
    I apologize for the noob question, but would this work for the 348 and/or Mondial t?
    Thanks in advance.
    Cheers
  10. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,291
    Worcester, England
    Phill J
    If you'd read the advert at the time more carefully, whilst the "headline" part of the advert did indeed state "5000K" (they've now changed it to read 6000K), the detailed description and the pictures of the box both clearly stated that these were 6000K bulbs.
    (Trust Me on this one, when the query of 5000k or 6000K was first made I rechecked the advert very carefully! - As I say, they've now changed the advert!)
  11. ferrari bud
    Jun 29, 2014
    261
    SF Bay Area
    Chris
    I talked to their customer service team and he told me they would be updating the listing title.
    That was fast!
  12. 308gtsqv
    Feb 12, 2008
    610
    Mass/Cape Cod
    The look white, with maybe with a hint of blue. Nothing like a blue 6k HID its much more OEM looking.
    As long as you don't have a sealed beam light it should work fine, just check the bulb type.
    Yeah.. I only have myself to blame for the mistake. I suppose I'm just lucky with the result. They look white and thats all I was after.
  13. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,610
    Menlo Park, CA
    Paul Chua
    thank you 308gtsqv - your car looks awesome!
    Cheers
  14. GTO Joe
    GTO Joe Formula 3
    1,003
    Charlotte, NC
    Joseph Troutwine
    They really do look good, thanks for the detailed heads up. It is now added to my "348 to do list". :)
  15. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    thanks for sharing ....cool uprade
  16. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,291
    Worcester, England
    Phill J
    To be totally fair, they should also have done a better job with their advert!
    (BTW: Thank you for not taking any offence at My post! Re-reading it again it did sound as though I was having a bit of a dig at you about reading the advert correctly, which wasn't My intention when I wrote it! - Sorry if it came across that way! )
  17. ssnowball
    ssnowball Formula Junior
    296
    Scot
    Installed today with standard adapters, took maybe 15 minutes. Love the results, thanks for the lead.
  18. tcbquattroporte
    tcbquattroporte Karting
    Jan 31, 2014
    132
    New Mexico
    Tom
    Awesome post. Thanks for the info.
  19. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    +1. Thanks for sharing your experiences. Like you, I dislike blue tint in headlamps and I would have expected 6000k to be way too blue for my tastes. It's great to see firsthand that they're not.
    FWIW, I've found that actual color temps vary considerably from the manufacturer's claims. I bought a set of HID lamps of a well regarded brand to replace the cheapies in my HID converted ///M3. I went off of the color chart provided by the manufacturer and wound up ordering a good bit higher temp lamps than I would have expected considering how blue the original cheap HID lamps were. Seems like the replacements were rated as a higher color temp than the cheapies, but they were a good bit less blue in actual use. So, anecdotally at least, higher color temps in a better lamp may not be as blue as it would be in a cheaper lamp.
    In any case, your pics make it look as though the color of your lamps is perfectly acceptable. While I prefer a tiny bit of yellow tint, I've found that a tiny bit of blue is okay, but much more than that just gets harsh.
    Nice work and nice post! Thanks.
  20. ferrari bud
    Jun 29, 2014
    261
    SF Bay Area
    Chris
    Just did the upgrade over the weekend. I'm definitely not a fan of any blue tint, but after the install, overall, I thought the color was pretty close to white with maybe a super slight tint of blue. Agree that this doesn't look like 6000K I've seen in the past with other manufacturers.
    Light output is much better than stock like the OP mentioned, but the one downside I'm not a huge fan of is that because there are two LEDs on each side, if you look directly at the projector housing, you'll notice it's not one solid beam of light. The light doesn't fill the entire projector and you still see the light source from the left and right side.
    Below are two photos:
    1/ Partially installed to see the difference
    2/ The left side/right side issue I mentioned above
  21. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Nice pics, Bud. Care to give us a WAG as to the difference in light output? Are the LEDs double the brightness of stock? More? Less?
  22. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    excellent update
  23. 308gtsqv
    Feb 12, 2008
    610
    Mass/Cape Cod
    Glad to hear everyone that did this after my recommendation is happy with them!
    Wow I never really noticed that. They're so bright I never looked right at them to catch that. That being said, most of them time I drive the car it's not at night and when I do have them up no one really really pick up on that.
    As time goes on I'm sure there will be better bulbs that are brighter and more efficient, but for now these are a great and cheap way to improve night driving without really messing with anything.
  24. ferrari bud
    Jun 29, 2014
    261
    SF Bay Area
    Chris
    I would guess it's around 1.5-2x brighter by just looking at it. Overall, I like it -- simple to install. I wonder if OPT7 were to add a 3rd LED at the tip if it would make any difference when filling out the light beam in the projector housing.
    Any lighting experts here care to chime in? :)
  25. m.stojanovic
    m.stojanovic F1 Rookie
    3,316
    Serbia - Niš
    Miroljub Stojanovic
    I would only be concerned about how they fill the road.
