Upgrading A/C and Radiator While I'm In There | Page 14 | FerrariChat
Discussion in '308/328' started by Ferraridoc, Oct 20, 2019.
  1. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    The same bloke who made the skid plate makes them. I'll send you a PM
  2. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    So the skid plate has a built in included angle of 178 degrees to follow the chassis rail, but when I dry fitted it, it needed way more than that
  3. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
  4. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    The cross member was bent up (probably from jacking) when I bought the car, and I jacked it back down, but it obviously needs to be a bit straighter than the moustache you see there.
    Sent from my SM-N920I using Tapatalk
  5. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
  6. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    Here's the new bottom plate of the cross member. There are three 5mm plates welded in so I can drill and tap mounting holes for the skid plate.
    Saabguy likes this.
  7. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
  8. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
  9. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    I had to place the panel in position, offer up the skid plate, and mark up where to drill the holes. I then drilled and tapped for the M5 stainless counter sunk Allen screws. I put the plate back in and lined up the holes with the skid plate. I will tack weld it in with the skid plate loosely mounted. When I finally put the spoiler on, I'll bolt it all together and the drill the final mounting holes.
  10. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    My fabricator mate came over and welded the steel into the chassis member. The best I could do was stand around looking useless. So I polished my horsey!
    I also cleaned the grille, which was... tedious.
  11. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
  12. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    Put the spoiler on... not quite fitting. So, I took it off for a look. It turns out that the bloke who repaired it decided to add reinforcing at the major stress points, which is great, but the glass was too thick in places, so a bit of careful sanding was in order. That wasn't good enough, so off it came again for something more... thorough.
    Sent from my SM-N920I using FerrariChat.com mobile app
  13. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    rjlloyd likes this.
  14. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    Aus_yz and Saabguy like this.
  15. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    Got the skid plate mounted, with difficulty. The fibreglass doesn't exactly click into place like a Swiss watch, more like a piece of Italian agricultural machinery. Two of the mounting holes go into a closed box section, so had to be tapped.
    miketuason likes this.
  16. Ferraridoc
    Jun 20, 2012
    17,252
    Gold Coast, Aust.
    Patrick
    OK, it's been a while, but, I've... finished. Sort of. I have yet to pack foam around the radiator, which is best done with the grille out, but I just couldn't wait any longer. The bumper and grille were put on and taken off half a dozen times to get it perfect, but I got there in the end! Getting the spare wheel tub in wasn't too bad (35 #8 self-tappers), and the clearance to the high point of the fans is about 3mm. So, left to do is the aforementioned foam, some stone chips (I know), and wiring the evaporator fans through a relay (currently wired straight to 12V).
    I've gleaned a few things along the way. One that comes to mind is the oily crap that I found all over the front chassis and firewall wasn't oil - it was perished underbody sealant. That's why I had so much trouble getting it off with degreaser, boiling water, and a steam cleaner. Another point is: don't start one job without allowing for a dozen other jobs to crop up along the way - these cars have been around a long time, and things need doing! I've also noticed that nothing on these cars is perfectly square, straight, or symmetrical; a margin for error must be allowed for. There's lots more, but I'll have to post them up as I remember - it's all a bit hard to remember right now! (Maybe I should read my own thread...)
    Saabguy likes this.
