Upgrading A/C and Radiator While I'm In There | Page 2 | FerrariChat
Discussion in '308/328' started by Ferraridoc, Oct 20, 2019.
  1. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
  2. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
  3. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
  4. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
  5. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    miketuason likes this.
  6. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,109
    Mansfield, TX
    Ron
    Was your old evaporator defective or are you replacing it with an upgraded unit?
  7. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    No, the evaporator wasn't defective, I'm just improving the air flow. I'm told a serpentine design is better than a tube and fin, but finding and adapting one of those, or getting one custom made, is above my pay grade
  8. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,529
    Cerritos, CA.
    Patrick, is the new motor has the higher or faster RPM?
  9. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    You get colder air the slower the air blows.
  10. miketuason
    Feb 24, 2006
    15,529
    Cerritos, CA.
    Cold air is not the problem as mine does get cold it’s just doesn’t have enough air speed or volume specially on a hot day.
  11. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Not quite how it works. ;)
    Gizzi likes this.
  12. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Sure it does.
    You can shoot that air thru that evaporator at light speed and it wont be in their long enough to transfer the temperature very well.
  13. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Well, that is true.
    Plus we have the solar panal windshield and all that hot air blowing in thru the crack by you foot.
    Every little bit helps, I suppose.
  14. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
  15. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    Hi Mike
    The new fan pushes out 588 cfm, the standard one about half that. I'm not sure what rpm it does
    Sent from my SM-N920I using Tapatalk
  16. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    Just gone through this thread, and there seems to be a couple of missing posts. Must be the FerrariChat App, which I notice is fried at the moment. I'll try and dig up the pics and use tapatalk...
  17. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    OK, me bad, I posted them in the wrong thread. There is a similar thread about upgrading a 303's cooling fans running concurrently - I can't switch the posts, so I'll re-post the pics here...
  18. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
  19. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    Still a bit more work to do on the evaporator housing. Here's the mounting plate mid fabrication [​IMG]
  20. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    The new blower is so wide at the face, it reaches the metal frame of the housing. This makes it a stronger mounting, but there's a pronounced step to the plate, so I made up a thick card gasket to give a level mounting face
    Milkshaker0007 likes this.
  21. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    Here it is trial assembled. You can see the pencil lines where I need to further relieve the plastic housing [​IMG]
    thorn likes this.
  22. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    428
    Midlands,uk
    Paul
    Great work Patrick, love these type of threads, improving and modifying to make good.
    Nice work
  23. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    I carefully marked out where the screw heads would foul the evaporator frame and drilled tiny holes to clear them. They were so far out, I must have broken the laws of physics to get it that wrong. So I drilled great big ones! The frame is still plenty strong enough...
  24. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
  25. Ferraridoc
    Jun 20, 2012
    16,149
    Gold Coast, Aust.
    Patrick
    Electric motors have maximum torque a zero rpm. If you control speed but using resistors, it drops the voltage, and the motor has no grunt until almost max rpm. It also generates heat. A far better solution is pulse width modulation (look it up). This gives full voltage at all times, but varies power by using narrow pulses, at higher and higher duty cycles, until full power at 100% duty cycle.
    Anyway, I just had to have one.
    Sent from my SM-N920I using FerrariChat.com mobile app
    JCR likes this.
