Upgrading A/C and Radiator While I'm In There | Page 3 | FerrariChat
Discussion in '308/328' started by Ferraridoc, Oct 20, 2019.
  1. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  2. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  3. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  4. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    The PWM uses Mosfets as switches, so it's very efficient, and doesn't generate nearly as much heat as a resistor pack, but it still needs a bit of air. And there happened to be a hole in the housing...
    You can see it in the side of the rear fan housing Image Unavailable, Please Login
    Sent from my SM-N920I using FerrariChat.com mobile app
  5. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  6. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  7. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    The problem is, it will be completely inaccessible, and if it fails, I'd have to remove the evaporator again to get to it. So I needed to ensure it was going to be reliable. The capacitors were rated to 63 volts - not even the Chinese margin of error would cause problems at 12 volts. Someone told me they save money by skipping using contact paste on the heat sinks. So I had a look. Yep, dry as a bone.
  8. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    Milkshaker0007 likes this.
  9. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    In the end, I decided that the risks outweighed the benefits of having it so neatly tucked away, so, after spending many hours going up this blind alley, I have given up yet another dream.
    I'll probably stick it here
  10. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  11. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  12. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  13. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  14. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  15. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    davem, Milkshaker0007 and miketuason like this.
  16. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  17. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  18. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  19. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  20. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  21. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  22. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    Before I work out a condenser solution, I'll see if I can get the radiator and fans to fit.
    First, the fan mounting. They come with plastic zip tie things that mount through the coil, but my welder guy was adamant that it was too naff, so we'll make up brackets to the top and bottom tanks. Before we do that, I had to invent something to fasten them togethet.
  23. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  24. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
  25. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
