Upgrading A/C and Radiator While I'm In There | Page 4 | FerrariChat
Discussion in '308/328' started by Ferraridoc, Oct 20, 2019.
  1. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
  2. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    I've spaced the fans out with corrugated cardboard. I will most likely use a rubber U channel moulding on the edge of the fan shroud, which will free up another couple of mm
    Sent from my SM-N920I using FerrariChat.com mobile app
  3. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    Good job
  4. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
  5. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    Ta. Long way to go, but getting there.
  6. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Where are those available?
  7. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    ebay
  8. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    That appears to be the same board, but the casing is different, and it has a cooling fan - very flash! My casing is simply perforated metal. Once mounted, I may run a little duct to it from the a/c.
    Edit: actually, it's also a slightly different board, but it doesn't matter, so long as the specs are the same. The ad has some similar products listed underneath - it's one of those.
    Saabguy likes this.
  9. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    Regarding the seal for the dash vents, did you consider something other than foam? I was thinking about a rubber door seal instead. Yes, Ferrari used foam but we aren't under the same budget constraints that they were. If it costs $10 more it won't break the bank.
    Lester
    Nice work BTW!
    [QUOTE="Ferraridoc, post: 146869552, member: 119018"
    snip
    You can also see the seal I made for the three dash vents, hanging over the steering wheel
    Sent from my SM-N920I using FerrariChat.com mobile app[/QUOTE]
  10. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    [/QUOTE]
    It has to be fairly soft, because, IIRC, the gap gets narrower, so it ends up a wedge shape. It will also dislodge when you slide the dash back on, so will need a bit of judicious poking and prodding through the vent holes to get it seated properly.
    Saabguy likes this.
  11. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
  12. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    Trial fitting bottom brackets. Together with the cross member, they form a saddle which cradles the bottom tank. There will be thin closed cell foam padding added before final installation.
    The radiator is perfectly square, but there isn't a straight line or right angle to be seen on the chassis. It's going to take a bit of fiddling to get it to sit nicely.
  13. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
  14. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    Fan speed pot?
  15. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    Sorry, should have been clearer - yes, the fan speed pot. Actually, I just realised that the on-off switch also powers the compressor circuit, so need to rig that up somehow.
  16. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Depending on the value of that pot there are a ton of stereo volume pots with on/off switches attached . Great work!
  17. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    It's a 100K pot, and it has an attached switch, but that switches the PWM on and off, so will be a board voltage of 5V. I need a separate 12V switch to power the a/c compressor circuit. It does have 4 contacts, so hopefully a DPST switch, which will solve my dilemma.
  18. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Through a relay I assume. That switch won’t handle much current.
  19. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
  20. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,527
    California SF bay area
    Paul
    I'd like to replace that AC fan speed selector, it is such a cheesy switch. Even the sound it makes when you turn it screams out CHEAP!!
  21. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    You have to replace the switch and the resistor pack if you're going to go down the electronic route
  22. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    Welded in top and bottom brackets. In primer. Some black paint next, and then trial fitting the radiator with fans and condenser attached. I've already tried it, and it's a very tight fit. I want it to be serviceable in future - I won't always have this level of access.
