Upper front A arm weight reduction | FerrariChat
Discussion in '308/328' started by sp1der, Jul 7, 2010.
  1. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #1 sp1der, Jul 7, 2010
    Just some images of work in progress on a spare set of 308 upper A arms that I have for my group iv project. Although these are not strictly copies of the Michelotto cars, there is still a useful weight reduction to be had.
    All that was required was to draw up a template, check the clearances to the edges etc, then make a centre hole template. I then just used standard Bosch bi metal hole saws in 14, 20, 30, 35, 40mm diameters to remove the material in a standard bench drill press.
    The plan is then to shotblast, re-paint and use the energy suspension black bushes.
  2. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,007
    Cape Town South Afri
    Dave
    A suggestion , you should try and dish the the edge lip of each hole . This will increase the stiffness of the flat plate .
    The back of a large socket with a bolt though and an even bigger socket on the other side , does a nice job on the smaller holes . You would possibly need to machine a die for the big holes , depends on how big a socket set you have ???
  3. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,866
    Atlanta
    John!
    The Michelotto arms looked like Swiss cheese when they were done. Holes everywhere imaginable so it seemed
  4. maestro8
    maestro8 Formula 3
    2,054
    Nor Cal
    Jason
    Did you put the arm on a scale before / after drilling? What was the effect?
    Forgive me for being naive, but how would one notice this reduction when driving?
  5. Ferraripilot
    May 10, 2006
    17,866
    Atlanta
    John!
    Any reduction of unsprung weight is good. I suspect he shaved a pound maybe less.
  6. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    I'd be curious to the before and after as well.
  7. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    If I remember right, the michelotto A arms were seam welded....like certain other parts of the frame and body.
  8. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    The upper front A arms on the michelotto cars look as if they were just drilled, the lower fronts and rears had plates welded in to tie in the U section rails top and botoom, as the pressed parts are only connected on one side. The whole point of the exercise is a reduction in unsprung mass. If you some up the total package it amounts to quite a few kg, see below;
    Weight saving in A arms
    Alloy calipers plus 2 piece discs (alloy bells) I have 355 parts on my car
    Alloy dampers (intrax or similar)
    All up in the region of 5-6kg per corner for a given wheel and tyre size. I will add it all up once complete, but this was done whilst I had a week back in the UK, plus stripping out some GT4 rear stub axles which do not have the same stress rasiers that the GTB stub axles have. So the work is not yet complete. You can see more details if you look on www.mat.fi at their project 308's.
  9. Tour de Corse
    Tour de Corse Formula Junior
    Aug 13, 2007
    259
    Copenhagen, Denmark
    Morten
    #9 Tour de Corse, Jul 8, 2010
    Hey Simon,
    Keep up the good work :)
    Just for your information - the four standard Koni coil-overs is about 25 kg and four Intrax Titanium coil-overs is 12,4 kg :)
    All the best
    Morten
    www.rallyferrari.com
  10. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    While total weight reduction numbers are great, it's always a good idea to get a baseline for each part before you start cutting weight.
  11. Ehamilton
    Ehamilton F1 Rookie
    2,673
    Durham, NC; USA
    Eric Hamilton
    +1. Stiffening the plate will increase its resistance to fatigue, and with all those new surfaces where fatigue cracks can start, that's something to be concerned about. I'd expect that it's also a good idea to smooth and polish the cut edges to eliminate the tiny defects where fatigue cracks will start.
  12. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,881
    Mike 996
    When doing work like that, how do you determine what amount of metal can be removed without compromising the strength of the part? Is there some sort of formula or is it just basically trial and error?
  13. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Mike,
    Let's hope that it's not trial and error. I'd hate to be the guy behind the wheel if and when it fails. I have to give the engineers at Ferrari at least some credit that they knew what they were designing, and why.
    Michelotto was preparing those cars for racing, so one would assume they knew what they were doing as well. But their objective of getting the car as light as possible might not have been compatible with long-term reliability. Most race cars aren't built to last more than a few seasons, at best, or in some cases a few races, without replacing major components. One wonders how long they expected those upper A-arms to last before they would be replaced. Might be good to know before turning your own into Swiss cheese.
  14. PCA Hack
    PCA Hack Formula Junior
    May 9, 2008
    610
    Rancho Santa Fe, CA
    +1
    Cool project, but I'd make sure to keep a close eye those arms.
  15. Speedmade
    Speedmade Formula Junior
    387
    Minneapolis, MN
    Reed H
    Can you elaborate on this? Or do you have any pictures?
  16. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #16 sp1der, Jul 9, 2010
    From what I can establish based on old UK FOC articles plus part history the stub shafts have had 3 evolutions as follows;
    Early GT4's to chassis number 12006 had rear stub axle part 106128 (this part is used in conjunction with the cast iron rear upright, it looks like an evolution of the Dino rear upright)
    GTB's started with rear stub axle part 124964
    This has then been replaced by part number 108046
    It is also interesting to note that the early GT4's had cast iron rear uprights and that the cost of the part 106128 is £238.50, i.e. considerably cheaper than 108046 which are £707. I do not know the reason for this, but the earlier stub axles seem to have a very generous radius at the 'T' where it joins the wheel hub i.e. is not a stress raiser and should have improved fatigue life. These are the parts that I believe are the most robust, other than inspecting yearly and/or buying the latest parts.
    However the problem does seem to only afflict cars that have had hard use e.g. track days, and or have wider wheels, different wheel offsets,or if the car has had previous damage affecting the integrity of the shaft. Attached is pic borrowed from an earlier thread of the rad in question (marked in red), plus part sheet showing earlier and later rear uprights.
    With respect to the upper wishbones the top plate only really prevents 'racking' of the wishbone, the main bending loads being taken by the U section rails. I do not anticipate any major issues with life as the car will only be used on the road, and in fairness wishbones can be obtained fairly cheaply and there is a ready supply. I also have the original parts which are not modified if there are any signs of any problems.
  17. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    from caluclation based on material thickness, density of steel, and the diameters used for the holes the weight saving should be approx 90g per arm for the uppers. Sorry did not measure these whilst at home, it seemed more important to get the job done than worry about the total weight saving.
  18. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    I have just used the homologation papers, plus the work MAT have done as the basis for a similar copy. I cannot find any reports that the Michelotto cars ever had any suspension releated issues, but take on board that parts may have been replaced frequently. The other worthy point on this is that the front end loading on the michelotto cars was much less due to the fact that these cars weighed in the order of approx 200kg's less than a fibreglass road car.
    Guess I could get some FEA done to be sure but at the moment the car is a long way from being finished so there will be time to run through everything. Will also see how Morten gets on with his car.
  19. b27
    b27 F1 World Champ
    Oct 11, 2007
    15,781
    Melbourne, Australia
    Brett
    Yes, I do wonder if one would really notice such a small weight saving. I'd suggest going to the bathroom prior to a race would probably remove more weight. :p
  20. maestro8
    maestro8 Formula 3
    2,054
    Nor Cal
    Jason
    I'm not here to start a flamewar, I'm truly curious. I only ask the question because I see the same "weight reduction game" being played in the cycling world with questionable results.
    I understand the physics of reducing unsprung mass, but I don't understand the purpose when a simple order-of-magnitude calculation shows <1% change in action ...or even launching into such a project without doing any calculations.
    Sure, "every little bit counts"... so why haven't you tossed the valve stem caps? Those add unsprung weight to the car!
  21. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    The whole point is this is just a bit of a hobby (the design of these parts have been poven out on the original michelotto cars), the upper A arms are part of a bigger picture to create a group iv rally replica, the weight saving for the entire car from people that have done this before is approx 200kg - close enough to a 20% weight reduction from a standard euro fibreglass car.
    If you take the suspension then it all adds up as follows;
    Upper A arm 90g (by calculations)
    Lower A arm 120g (by calculations)
    Swap out front brakes to 355 plus 2 piece discs - 1.4kg - already on car
    Swap out Koni's to Intrax or similar - approx 3-4kg - based on weight data from similar cars
    The whole reason for doing this is that the group iv cars just look so good!
  22. Tour de Corse
    Aug 13, 2007
    259
    Copenhagen, Denmark
    Morten
    Hi Simon,
    You're spot-on !
    We only live once and going through the life without any fun, it is not ...fun at all :)
    MO
  23. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    And some further good news today, Kari has sent me the invoice for the group iv body bits, now it is starting to come together, and for me its worth every penny.
  24. Tour de Corse
    Aug 13, 2007
    259
    Copenhagen, Denmark
    Morten
    Splendid :)
