News
upper saftybelt fixing BB and BBi
Discussion in 'Boxers/TR/M' started by turbo-joe, Sep 12, 2020.
  1. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    6,344
    southwest germany
    romano schwabel
    #1 turbo-joe, Sep 12, 2020
    hello all
    I just got for my BB a complete nearly never used interieur from a BBi and have now a little problem. there are some things a little different.
    here are 2 copies from the parts catalog. one is from the BB and the other from the BBi.
    you see at the BB the upper screw from the safety belt is directly in front of the rear window in the small shelf.
    on the BBi there is an about 8 cm high increase where the cover ( 18 ) goes on but this inside is hollow. so there has to be something under this "cover"
    someone could post a photo from this part the cover is on?
    if someone would need the old interieur from my BB please send me a message. it is light to medium brown
  2. mexicruiser
    mexicruiser Karting
    95
    25oN 100oW
    On my BBi there is a welded metal post with a thread on top, the cover is there so the post is concealed.
    turbo-joe likes this.
  3. turbo-joe
    Apr 6, 2008
    6,344
    southwest germany
    romano schwabel
    I thaught so already but in the parts catalog I can not see. could you remove the belt screw at the top, remove the cover and make a photo please?
    or someone else may post a photo?
    thank you
  4. mexicruiser
    mexicruiser Karting
    95
    25oN 100oW
  5. turbo-joe
    Apr 6, 2008
    6,344
    southwest germany
    romano schwabel
    W O W ! ! ! :)
    so great
    thank you so so so much mexicruiser
    so I will remove the old and see what I can do, looks not so hard to make 2 of those
  6. mexicruiser
    mexicruiser Karting
    95
    25oN 100oW
    Not difficult to fabricate but correctly welding it inside your car in this tight spot can be. Make sure you shield the glass as it is easily damaged with sparks. I’m sure you also know the bracing is crucial when lengthening the anchor point so much. I’m guessing you are tall and the current position is uncomfortable?
  7. turbo-joe
    Apr 6, 2008
    6,344
    southwest germany
    romano schwabel
    I´m not tall, only 1,68 m, and so as it is just now I´m happy with.
    so I think I will use the old original threads for the safety belts and forget those "doms", but then I have to use the old cover and put new black leather on.
    will have a look coming week and then decide
    mexicruiser likes this.
  8. pshoejberg
    pshoejberg Formula 3
    1,273
    Denmark
    Peter H
    It is smart to keep the low posts Romano. I'm also 1.68 m high and the belt in my BBi is slightly annoying due to the belt crossing too high on my chest.
    Best, Peter
  9. ag512bbi
    ag512bbi F1 Veteran
    Rossa Subscribed Owner
    Nov 8, 2003
    6,581
    So. Cal
    Armen
    I was VERY lucky to have a gentleman in Australia who was in the process of restoring his Boxer fabricate a pair of those parts.
    Here are photos of the mold. They are a PERFECT fit
  10. turbo-joe
    Apr 6, 2008
    6,344
    southwest germany
    romano schwabel
    those are only the covers, not the mounting like in post 5
  11. mechaniker
    mechaniker Formula Junior
    May 30, 2004
    461
    So far, I´m very confused with the Seat Belt Mounts in BBs/BBis...
    Some have the higher variant, some not. Some have a Tray on the rear shelve, some not.
    So far, I couldn´t make out, if it was market dependant, year depandant or whatever. Some very near chassisnumbers have different configurations. Why?
  12. turbo-joe
    Apr 6, 2008
    6,344
    southwest germany
    romano schwabel
    I think the BB are even mounted on the rear shelve and the BBi is higher. so the parts catalog says ( see post 1 here )
    also I think only the BBi has the tray
    ag512bbi likes this.
  13. mechaniker
    May 30, 2004
    461
    No. Its not that easy ;)
    A friend has a BB with tray and high seatbelts. We have an BB with low seatbelt and no tray. At the dealer is a BB with tray and low seatbelts. All in the 32xxx to 34xxx range.
    A friend has an BBi without tray and high seatbelts.
    Initially i thought also, that BBs had low seatbelts and no tray, but that prooved wrong.
  14. turbo-joe
    Apr 6, 2008
    6,344
    southwest germany
    romano schwabel
    oh ?
    so complicated? never expected this
