Uprated Aluminium Radiator for 308 2V | FerrariChat
Discussion in '308/328' started by Sandeman, Jun 21, 2019.
  1. Sandeman
    Sandeman Karting
    Dec 27, 2010
    59
    Belgium
    Hello,
    Has any of you ever installed an Uprated aluminum radiator sold by Superformance to replace the original Ferrari radiator ? Are there any differences in the cooling between an original radiator part # 116286 and an aluminum radiator part # 30810175, and which one would you advise me to buy ?
  2. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    FWIW my ‘82 308GTSI radiator was re-cord with 2 less FPI (fins per inch) and exact same cooling tube design, it runs at t-stat temp all around. The reduction in FPI actually flows more air through the core. I was very pleasantly surprised. Just saying
    Martin308GTB likes this.
  3. absostone
    absostone F1 Veteran
    9,949
    I think there are threads on this subject.
    I think nicks forza has theses
  4. offtheworkigo
    offtheworkigo Karting
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    BigTex and miketuason like this.
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,781
    Cerritos, CA.
    Looks great Dave, was the mounting spot on?
  6. offtheworkigo
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    Yes mine was a exact fit on the radiator. Radiator hose fit with no problem. A/C evaporator fit right on. New fans work great. Fit in old fan mounts and plug right in with out any cutting and splicing. Make sure you get new foam to go under and on both side of the radiator. Got my foam from Lowes, used for going around window A/C units.
    miketuason likes this.
  7. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,602
    California SF bay area
    Paul
    I don't have any knowledge of the Superformance product but I also put in one of Forza's aluminum radiators which are fabricated by Wizard. While it does fit it should be noted that it is close to an inch thicker than the original (It has to be because aluminum is not as efficient as copper) so it's a tight squeeze getting it in there. Like most people who do this I also upgraded the fans so I'm not sure how well the original fans would fit since there is an inch less space up front.
  8. JohnInItaly
    JohnInItaly Karting
    Feb 5, 2019
    117
    California
    John McCoy
    My left hand radiator fan melted the brush holder plate. I think that there is a specialist rebuilder, but I would also like to try the 10" Spal fans, based upon comments here that they bolt right into the stock bracket. There are ten different 10" Spal fans. Does anyone know which one fits best? Thank you.
  9. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,602
    Paul
    I wouldn't exactly say they just "bolt right in" but with a few little L-brackets it's pretty easy so basically any of them will fit.
  10. JohnInItaly
    JohnInItaly Karting
    Feb 5, 2019
    117
    California
    John McCoy
    Thank you for the rapid response. I turned your photo upside down and tried to enlarge it, but still cannot read the SPAL model number, and there are ten different 10" fans. Can you access the SPAL model number? The bolt-in remark was regarding the photos of February 26, 2016, which appears to be SPAL blades and shields, but oem style motors, which looks interesting. I did find an original NOS brush plate kit on eBay for $23 and bought it to repair my original fan motor, but am still willing to try something that will push more air. I see that you are in the SF Bay area. I did enter both Concorso and the Carmel Village street show this August. Please introduce yourself if you see the car there. Thank you.
  11. GordonC
    GordonC F1 Rookie
    4,158
    Calgary, AB, Canada
    Gordon
  12. JohnInItaly
    JohnInItaly Karting
    Feb 5, 2019
    117
    California
    John McCoy
    Thank you! Do you think that the February 26, 2016 photos are some special hybrid of original motors and SPAL blades and enclosures?
  13. GordonC
    GordonC F1 Rookie
    4,158
    Calgary, AB, Canada
    Gordon
    It looks like he re-used the empty housings of the original fan motors as a shell to mount the new fans with simple angle brackets (have seen that described in previous fan threads as well). kcabpilot's photos show the band that holds the original fan housings, but he has chosen to use angle brackets to mount the new fans to the mounting band, rather than to the shell housing as offtheworkigo did. Both mounting methods are equally good, it's just personal preference as to which you use.
  14. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,602
    Paul
    #14 kcabpilot, Jun 29, 2019
    The fans I used are VA07-AP12/C-31S 30100381 straight blade pusher 590 cfm 15 amp. I spliced the connectors from the original fans onto these so they are direct plug in and no modifications were done to the chassis side. The original circuits are 15 amp so no need to change anything the spec sheet says these run at around 6 amps. They also make some curved bladed fans which may be quieter but I don't have any direct experience. These ones seem to be about the same sound level as the originals.
  15. offtheworkigo
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    I used 3" muffler pipe 2 1/2 " long with L brackets from Home Depot. Riveted the L brackets to the pipe and removed the screws from the fan and installed longer screws. This way I could adjust how close I wanted the fans to sit from my condenser using the old fan mounts. Also used 3 " rubber caps to fill the holes in the muffler pipe. Many ways will work. Just looks differant.
  16. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,602
    Paul
    I did the same thing but after installing the Forza radiator which, as I said is about an inch thicker, I found that the Spal fans just fit between the condenser and the original brackets so there was no need for the tubes. If you are doing this with the original radiator then yes, you would need the tubes to extend from the brackets because the Spal fans have integral shrouds and you want them right up against the condenser fins for best performance.
  17. dinoart
    dinoart Formula Junior
    792
    Westminster CA
    David
    The Carmel Village car show, what day is it on?
  18. JohnInItaly
    JohnInItaly Karting
    Feb 5, 2019
    117
    California
    John McCoy
    Aug 13, 2019 at 10:00 AM to 5:00 PM
    Downtown Carmel-by-the-Sea
    Ocean Avenue
    Carmel, CA 93921
    Free spectator admission
  19. BigTex
    79,337
    Houston, Texas
    Bubba
    Those fans look the business!!!
  20. Andrew McCrae
    Andrew McCrae Formula Junior
    Jun 5, 2016
    250
    Ireland
    I think I read somewhere about GTO engineering buying the original ferrari radiator tooling. I know you're looking to upgrade but maybe they can help too.
  21. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,253
    Black Forest Germany
    Martin N.
    When I hear 'uprated' from SF I get wary.
    Same here exactly. 10 years ago. Works still perfect and was inexpensive.
    Best from Germany
    Martin
    waymar likes this.
