Urgent - 550 MPG | FerrariChat
Urgent - 550 MPG
Discussion in '456/550/575' started by Hawkeye, Apr 28, 2023.
  1. Hawkeye
    Hawkeye F1 Veteran
    8,183
    Road trip in the 550. I’ve gone 277 miles without stopping, gauge reading 1/2 tank. Destination is 320 miles, am I gonna make it?
    F456M and Bas like this.
  2. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    680
    Continental Europe
    600 miles on one tank? Are you dreaming?
    Qavion and Bluebottle like this.
  3. Reuvenh
    Reuvenh Rookie
    Jun 26, 2016
    21
    Are the reminding 320 miles all downhill?
    bball16, Qavion and Bluebottle like this.
  4. Hawkeye
    Hawkeye F1 Veteran
    8,183
    No, here’s an update, I worded that poorly. My total destination was 320 miles, I had drive 277 and the gauge was at half tank for a long time, I thought the fuel gauge might be INOP.
    I stopped for fuel at my exit with 297 miles on trip odometer and bought fuel. I filled her all the way up, put in 16.26 gallons.
    297 / 16.26 = 18.265 MPG, can this be right?
    It was mountainous highway with spirited driving, except for the 45 minutes of wipers on high speed due to major rainstorm. The car is aces in the wet, wipers amazing.
    Bas likes this.
  5. Timmo
    Aug 26, 2017
    680
    Continental Europe
    I have only driven one long trip so far and got 18.5 mpg, so it sounds like you are doing ok.
  6. Hawkeye
    Hawkeye F1 Veteran
    8,183
    that’s much better than I had thought it would be.
  7. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,761
    ESP
    Bas
    no comment on the mpg...but this whole car is amazing.
    Hawkeye likes this.
  8. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,420
    Los Angeles
    Bill Karp
    I have 93,000 miles on my 550 I always get at least 18 sometimes 20 miles to the gallon depending on the trip
  9. 12659
    12659 Formula Junior
    Oct 6, 2005
    349
    Seattle WA. USA
    mark
    The fuel gauge is not very accurate, however I think Ferrari intended it to be so, The fuel light comes on early. The tank holds 34 gallons including reserve
    so do the math to calculate range and carry a 2 gallon emergency gas can.
    F456M likes this.
  10. tazandjan
    39,174
    The 550 holds 114 liters of gasoline including the reserve. That is 30.1 US gallons. 575M only carries 110 liters, 29.1 gallons.
    18+ mpg is easily possible for a highway drive.
  11. Hawkeye
    Hawkeye F1 Veteran
    8,183
    Thanks for the info fellas, I was convinced the gauge was stuck, nice to know these have some range, here she is, thread needs at least one pic. NART Blue
    technom3, JohnnyRay, Robb and 6 others like this.
  12. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    I went through France at around 110+ kph. (70 mph.) on the cruise control for 750 kms. and refueled a few houres later. I got exactly 10 liter per 100 kms., which is 23,5 mph. Usually I never drive like that, but this day I just wanted to relax and listen to music while seeing the landscape cross by... So again, the 550 is the best and most economical car I can own.
  13. Vilhuer
    Vilhuer Karting
    Aug 3, 2008
    164
    Helsinki, Finland
    With 100+ L fuel tanks 456 and 550 have diesel level range when driven slowly.
    F456M and Hawkeye like this.
  14. tazandjan
    39,174
    NE550 and Hawkeye like this.
  15. Hawkeye
    Hawkeye F1 Veteran
    8,183
    I just returned from a quick three day weekend, a little more than 700 miles in all, absolute fantastic machine, she loved the high speed mountain roads of West Virginia. Encountered heavy downpours where the wipers could barely keep up, completely stable, no hydroplaning. This was my first long drive in a 550, quite amazing really, comfortable seats and plenty of power when you need it. Need to do a bit more research but when at "higher speeds" the oil pressure was pegged at 140 (nearly 10 bar) water remained low (130) and everything else was in normal ranges.
    F456M likes this.
  16. 308 GTB
    308 GTB F1 World Champ
    11,722
    New Jersey
    Barry Wolinsky
    Clean the contacts on the oil pressure sender. That's the usual cause of a pegged oil pressure gauge. When that's done, get the MSW oil pressure sender boot sold by Ricambi America: Oil Pressure Sender Cover
    The oil pressure sender on the 550 gets dirty quickly down there.
    Qavion and F456M like this.
  17. Timmo
    Aug 26, 2017
    680
    Continental Europe
    Are yours gallons imperial or US?
    My 18.5 mpg posted earlier are imperial, actual consumption was 14.5 L / 100 km, again on the motorway at 140 km/h on the speedometer.
    For what it's worth 10 L / 100 km = 28.3 imperial mpg.
    F456M likes this.
  18. tazandjan
    39,174
    UK gallon = 1.201 US gallons, so fuel consumption would be 20.1% better if quoting UK gallons consumption.
    F456M likes this.
  19. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    I think of gallon as 3,8 liter. So optimum gas milage for a 550 is 28 mpg. then?
  20. tazandjan
    39,174
    US gallon is 3.8 liters. UK gallon is 4.55 liters.
    F456M likes this.
  21. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    552
    Tempe
    Jon
    Are you sure both fuel pumps are working and have full power?
    Being over 20yrs old with the various gasoline blends in two decades has and will wreck the rubber insulators for fuel pumps. Such a high mpg makes me think you’re not fully pumping.
  22. JohnnyRay
    JohnnyRay F1 Rookie
    3,620
    Central FL/NW WI
    Also, apply some "No-Ox" to the contacts after clean up...
    https://www.ebay.com/itm/394491268853
    308 GTB likes this.
  23. 308 GTB
    11,722
    New Jersey
    Barry Wolinsky
