URGENT-599 Battery empty-NEED HELP!!! | FerrariChat
Discussion in 'Technical Q&A' started by cmack, May 22, 2010.
  1. cmack
    cmack Karting
    Jan 8, 2009
    191
    Germany
    Saturday afternoon, cant reach the dealer and the battery of the 599 is totally empty. After reading the users manual three times I still cant find the chapter where the plus and minus pols of the battery are. Anyone here online who has experience where to find the plus and minus of the 599 battery?
    I already have removed the carpet on the trunk to come to the battery but cant also find there any signs for the plus and minus - unbelievable but true. I'm not sure If I'm just blind or if they are really on a very silly spot.
    Thousand thanks for Your help!!!
  2. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
  3. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    The positive pole is always larger in diameter.
  4. tazandjan
    39,305
    #4 tazandjan, May 22, 2010
  5. cmack
    cmack Karting
    Jan 8, 2009
    191
    Germany
    First of all thank You very much for all postings, I think I'm winning some progress.
    If I read the images right, the positive pole is on the left side of the battery (if You look at the battery from the trunk ), but I'm still not sure if I read the negative pole correctly to connect the recharging? Is it on the right side of the battery?
    It is not possible to see the battery top on as the wheel-arches are surrounding that place in the trunk.
    As much as I oversee it at the moment, the battery of the 599 is indeed in a very difficult place to get to. I also don't understand why Ferrari is not adding + and - signs somewhere make it easier for a stranded driver like me.
  6. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    844
    Houston
    PW
    If you have a voltmeter it would be easy to tell.
  7. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Most battery chargers will not charge if the polarity is reversed,
    Negative pole lead goes to master disconnect switch.
  8. cmack
    cmack Karting
    Jan 8, 2009
    191
    Germany
    YESSSSSS - I MADE IT
    Finally I risked it and indeed I found the right poles.
    The + pole is on the left side of the battery if You look top on from the trunk and the - pole is on the right side. The cabin lights and hydraulic is already working.
    Once again many thanks to all of You who supported me. I recharge the battery now overnight to make sure it has enough power and make a drive on the autobahn tomorrow.
    I really owe You a favour, the link to ricambia was really great!!
    Greetings to all of You!!!
  9. f355spider
    f355spider F1 World Champ
    18,054
    If the L3-80+ is describing the battery size, then the 599 uses the same size battery as the 355, which in North America is designated as a Group 34R. (the R designates reverse terminals). In most 348s and 355s you can actually fit a standard Group 34, as the battery cables are long enough to reach the terminals even if they are on the "wrong" side. :) Using a Group 34 opens up a lot more choices, as the 34R is an uncommon battery.
  10. tazandjan
    39,305
    #10 tazandjan, May 22, 2010
    For us Yanks, here are the replacements for the 599's L3 80+:
    Mondial/TR/512 TR/F512M/355/456/456M/550/575M/599 Battery
    MTP-91 Interstate (More Power, Cheaper, Lighter, than MTP-H6)
    Product ID: MTP-91(Automotive Truck)
    Amps: 875
    Cranking Amps: 875
    Cold Cranking Amps: 700
    Voltage: 12
    Termination: A
    Pro-rata Warranty: 85
    Weight: 36.9 lbs
    Width: 6.88” (175 mm)
    Length: 11.38” (289 mm)
    Height: 6.88” (175 mm)
    Retail Price: $124.95
    MTP-H6 (Alternative)
    Product ID: MTP-H6 (Automotive Truck)
    Amps: 800
    Cranking Amps: 800
    Cold Cranking Amps: 640
    Voltage: 12
    Termination: A
    Weight: 40.8 lbs
    Width: 6.89” (175 mm)
    Length: 10.94” (278 mm)
    Height: 7.48” (190 mm)
    Retail Price: $163.95
    Delco 48-6Yr (substitute for MTP-91)
    48-6YR 12 Volt Automotive 110 700 875 11.5 6.8 6.8 35.5
    Retail Price: $112.44
    Taz
    Terry Phillips
  11. f355spider
    18,054
    Assuming you can get a Group 34 to fit (terminals opposite side from the 34R that comes with the car), I would recommend the Sears Platinum battery. It is of absorbed glass mat construction, so it never needs water, and even if the case becomes cracked, it will not spill electrolyte. 880 Cold Cranking Amps (versus 700 of the Interstate 91) and has a four year free replacement warranty. It was also top rated by Consumer Reports in their two last tests of batteries.
    http://www.sears.com/shc/s/p_10153_12605_02850034000P
    Only downside is it is a bit heavier, around 49 lbs.
    This battery appears to actually be manufactured by Odyssey:
    http://www.odysseybatteries.com/battery/pc1500t.htm
    All the specs are identical. But Sears sells it for considerably less.
  12. tazandjan
    39,305
    He lives in Germany. Not a whole lot of Sears stores there.
    Also the battery is a full inch taller than the FIAMM and Interstates, might not fit in some Ferraris.
    Taz
    Terry Phillips
  13. f355spider
    18,054
    Thanks Taz, you are correct. I was responding to your post #10. You are right, the height might be an issue in some cars, but so far, has not been reported to be an issue in 355's or 348s. I am uncertain if anyone has tried in a 550/575. Being a Group 34 standard, it should still be within spec, even if it is taller than the Interstate.
  14. tazandjan
    39,305
    Yup, you are correct. I forgot I even put those charts in there. Would probably be a very tight fit in a Maranello, not sure about a 599. Looks like a pretty heavy duty battery. If fitting one, Odyssey does make a 34R, which is a bit more expensive than the Diehard, but would probably fit better.
    Taz
    Terry Phillips
  15. GTtech
    GTtech Guest
    Apr 28, 2010
    9
    Istanbul
    Serkan
  16. Mfoncerrada
    Mfoncerrada Formula Junior
    Dec 20, 2009
    419
    Monterey, CA
    Miguel Foncerrada
    Please, Please, Please do not mention the autobahn...it makes us all jealous...Have fun!
  17. CuriousMarc
    CuriousMarc Rookie
    Jan 26, 2012
    1
    Just changed my 599 battery, which was more than dead (could not even recharge it past 9V). What a nightmare.
    First off, the trunk won't open when the battery is dead. There is a "secret" mechanical release though. It's in-between the seats, there is a two compartment flattish tray, pull that up by picking it up by the middle divider. Underneath there is a black release cable, pull on it to open the trunk.
    Then you have to remove the right side trunk lining. There are two 4mm Allen screws hidden behind the leather holder for the manuals.
    Then you have to remove the + terminal. There is a red safety pin/plate hidden inside the positive junction box/tray sitting atop the battery that will prevent you from doing that (how do they come up with that stuff?). You have to open the lid of the junction box by pressing two hard to see tabs, then unscrew the red pin inside.
    Then the plus side terminal connection and nut is all the way at the back, you can't access it to loosen it. So you have to remove the minus side, unscrew the upper and lower attachements to the battery, pivot it 90 degrees so you can access the round positive terminal and loosen the nut from there.
    And when you are all done the regular 34 won't work. You need the 34R with the reverse terminals, or the junction tray won't fit.
    My battery said L3 680 74 Ah 680A EN, FIAMM Genuine Ferrari
    I guess the engineers were thinking we owners are a little too lucky, they wanted to get back at us by making battery changes real difficult. They might have overdone it a bit ;-). Great car it is.
  18. Caeruleus11
    Caeruleus11 F1 World Champ
    11,691
    Glad you're up and running.
