Urgent help needed/engien did not start | FerrariChat
Discussion in '456/550/575' started by Komo, May 31, 2013.
  1. Komo
    Komo Rookie
    Dec 27, 2012
    6
    Hi,
    I drove my car to the workshop in the morning, in the afternoon I tried to start again, it revs but did not start. It shows "engine warning" tried to read DTC with obd tool, no connection, checked all fuses, everything is fine? Any ideas? It did not run any more and want to come home :-((
    Daniel
  2. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    37,983
    houston/geneva
    Ross
    is it getting fuel?
  3. Komo
    Komo Rookie
    Dec 27, 2012
    6
    yes, there is fuel, no spark. It seems the ecu has no power, no idea which pin on the ECU is the 12V feed so I could check for it
  4. Healeyguy
    Healeyguy Rookie
    May 13, 2011
    23
    Once I had a problem starting my 550. I jumped in the car, turned the key (check ok) and tried to start the car AS IT WAS ROLLING. This triggered a fault message for the Traction Control system and the car would turn over but, not start.
    I turned the power to the car off (switch under the hood near batter) for a few minutes and I think this reset the ECU enough that the car fired right up again.
    Paul
  5. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    when car was driven to normal or hot the car did not want to start. 7mo. at a dealer did not solve the problem. brought it home, removed all fuses and reinstalled. car now starts every time. i keep my car in a controlled climate
