USB key evaported? | FerrariChat
USB key evaported?
Discussion in 'Other Off Topic Forum' started by Z0RR0, Sep 15, 2006.
  1. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    This is weird.
    I'm working on an older puter (some P3 laptop), and there is a bunch of data I'd like to transfer to my new puter, via my USB key. Issue is, the old puter doesn't have USB 2.0 ... and doesn't allocate a drive (the C, D, E ... etc thing) to my USB key. It does tell me my device will work slower because it's not a USB 2, it has figured it's a Lexar blah blah, it tells me it's working properly, I just can't find it anywhere on My Computer, nor Windows Explorer ... and the right-click>Send to trick shows no Lexar Media thing.
    Exact same problem when I plug the big hard drive (USB as well).
    This is annoying, I don't feel like emailing myself 1Gb of random stuff ...
  2. carl63_99
    carl63_99 Karting
    Oct 22, 2001
    199
    It sounds as if your laptop and/or OS doesn't suppport the USB key. The issue with USB 2.0 is only a matter of speed, I see that on a few machine. Check the USB key website, see if your laptop and OS are supported, or if there are drivers you may have to download for it to work. Good Luck!
  3. Whisky
    Whisky Three Time F1 World Champ
    32,106
    In the flight path to Offutt
    The original Fernando
    If it's Windows 98, you will need to download a piece of software to make it work. If it's W2K, NT or XP, then you don't (or shouldn't) need it.
    I'd go research the FAQS at the Lexar website.
  4. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    Well, it is Windows XP, so everything should be plug and play.
    I'll try the driver thing, although it properly detects it (in the Control Panel) and says it works fine. It just does not assign a drive to it, meaning I can't access it.
    For now I solved the problem by transferring the files via ftp ... but it still sucks.
  5. Whisky
    32,106
  6. QT3141
    QT3141 Formula Junior
    Jul 24, 2006
    609
    Are you able to locate the USB drive on the Hardware config menu? You can access this by right clicking your "My Computer" icon and going to Device Manager. Pre-XP, that menu option is present when you right click. On XP, you need to go in via the management menu (click "manage").
    Look under disk drives. See if there's an entry for the USB drive. If there's a "!" next to it then there's a problem with the drivers. Try removing the device and reinstalling it.
