Useful Ferrari Add On Or Not? | FerrariChat
Discussion in 'Technical Q&A' started by Ferrari Mackintosh, May 6, 2005.
  1. Ferrari Mackintosh
    Ferrari Mackintosh Formula Junior
    Sep 21, 2004
    716
    N/A
    Ferrari Enthiusiast
    #1 Ferrari Mackintosh, May 6, 2005
    Does anyone know if this aftermarket add on pictured below is a worthwhile addition to a 512TR? Two are required (one for either side of car). How much extra BHP would these things give?
  2. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    About half as much as a few stripes on the side and a lightning bolt on the hood.
    (Those things will not change your car's HP while those ducts will likely slow you down.)
    Ken
  3. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Obviously you jokers don't know the first thing about the Venturi effect. Clearly the shape of the cutout (and I'm sure the cross section of the grating) is wind tunnel tested to provide a harmonic flow that works with the intake tube lengths to at least double your power. And don't forget the undercarriage neon tubes to properly charge the ions for optimal slip at high speed.
    BT
  4. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    But seriously, none of this matters if your crystals are not aligned.
  5. nopassn
    nopassn Formula 3
    Nov 19, 2003
    1,959
    Kansas City
    Roy
    Don’t forget that in order to get the largest gains you will need to change your carburetor belts and change your blinker fluid over to synthetic... :D
  6. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,606
    Pacific NW
    Anthony C.
    But as long as he is able to calibrate the warp fields on both sides to the same harmonic frequency, he should be okay, right? My Japanese is a little rusty, but I am almost sure that what it says on their website.
  7. Jdubbya
    Jdubbya The $10 Trillion Man
    43,517
    PNW
    It actually is close to the correct shape for a NACA duct. I have no idea what it would be feeding from there but it should actually be able to pull some airflow.
  8. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,322
    Ventura, California
    Robert Garven
    isn't there a big rubber or fiberglass thing under there with the fuel cap? maybe it is to blow the overflow gas down the drip tube? :-0
  9. son of caesar
    son of caesar Rookie
    Feb 24, 2005
    19
    long beach, ca
    nick calciano
    I swear when I read this title, I thought I was going to see two shiny turbos still in the boxes. But turbos wont help, like this high tech air suppression device. Just goes to show that old school guys like me are obsolete.
