Using a used 360 ECU? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by jasonlanglois, Feb 9, 2012.
  1. jasonlanglois
    jasonlanglois Rookie
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    Nope, swapped left to right. No start. Swapped back. Started and ran really rough. Swapped back again and made sure for sure I had a good ground, no start. Now that the boxes are back to the original spot and bolted to the chassis, no start. It had P1571 immobilizer active but cleared and stayed out.
  2. tech4ferrari
    tech4ferrari Karting
    Jan 22, 2010
    234
    Mt Airy N,C
    casey johnson
    It will run rough until it learns its values you need to turn key on for 30 sec to learn throttles and then let it idle 10 min without touching throttle, after that test drive for 15 to 30 min that way it learns its adaptive values. If it will not start by swapping left to right then that means someone else has already burned that ecu to another car or someone has replaced that ecu with one from another car probably trying to fix the problem you are currently trying to fix would be my guess.
  3. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    I figured it would be something like that. It was late in the day and I had a date with my wife ;). I'll make sure I have a good reinforced ground and let it clear her self out.
    Thanks,
    J
  4. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    Lots of good insight here and no I don't thing anyone should take offense. I did swap the injectors from the cylinder ID along with (but not as the same time) coil and plug to see if the problem (misfire #3) would follow. I also had all injectors, coils and plugs out. At that time I did a visual inspection of connectors/pins, reach/lean, tracing, resistance of coil/injector/plug (I've seen a plug bust out and conduct to ground internally...just a thought), gap, coil springs, and boots. I also did submerge the injectors (all 8) in cleaning solution. I did not carry out a spray pattern test as I was only looking for a #3 misfire resolution (but very good point about cleaning and testing). I carried out an injector buzz test with the Leo and a sound scope, all seemed normal...click click click. Like I said the intake was pressurized with .5 bar for 10 minutes with no fail. The continuity on the injectors was something like 3.8-4 ohms, all within one tenth.
    I'd like to think I'm somewhere between "pro" and really good at my craft...you guys be the judge.
    http://www.granturismo.ca/
    Thanks guys,
    J
  5. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    That's exactly what I'm talking about! I'm the tech that will take the risk with the informed decision. With hours and hours of research...fchat, phone calls, books, mags, hands on experimentation...
    You guy's have really been very informative.
    J
  6. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Ohhh....... that's a network I'd like to be able to access!
  7. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Jason, did you ever try that leakdown test with a higher input pressure?
    Also, once the adaptive values have re-learned take a look at the parameters bank to bank and see what the fuel adaptives are-you will probably need to do a couple of short drive cycles-a high long term fuel adaptation could also point towards a leaky/sticking injector..
  8. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    I looked at the notes I had made and we in fact did the leak down test at 80 psi not 60. The reason being is the graduations on the guage are very accurate up to 80 but coarse after that.
    I tried swapping the ECU's side to side again. It took 2 attempts of cranking after leaving it KOEO for 10 minutes, but after that it started. After running for about 3 minutes it generated code P0303 again on the left hand side this time not the right (is this because that "right hand ECU" is still the master?) It also generated front 02 sensor high (rich) on the right hand bank.
    I'll verify what cylinder is actually misfiring again and go from there.
  9. fatbillybob
    Aug 10, 2002
    29,258
    socal
    Is the error code still in that ecu from before? I would erase codes once good starting and decent running are assured. Then run car and these next set of codes I would believe.
  10. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    No codes in the ECU from before. I deleted the codes with the Leonardo before swapping them. I will do some more run time when the weather is more suitable.
    Thanks all for the continued help
    J
  11. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Stick with it Jason. Sometimes as FBB states we have to sneak up on these. Easy to jump off and throw parts at it then start more threads but sounds like you're thinking it through.
    Time to sit back and study the exact pattern of issues, your test results and any changes such as the code switch above. This is and isn't rocket science, there are simply inputs and outputs which produce a reaction, need to see where the flow chart goes off track. If the code stays with a cylinder, that is the problem area, if it switches with the ECU, then you were corrct in OP.
    Sometimes I'll eat these jobs out of pure stubborness, eventually it gets fixed and I can justify some charge.
  12. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Hi Jason, I feel your frustration!
    I'm hesitant to post in this serious thread and apologies if this is a spurious observation but I don't understand how you can have a P0303 code from the left hand side. I would have thought that this code could only possibly be generated by whichever ECU is on the right hand (1~4) side of the vehicle.
    If the ECU on the left hand side has indeed generated that code it must surely be confused as regards it's current purpose/location?
  13. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    try resetting the adaptive values, cold start it and watch the fuel adaptions. Post the results of the short term and long term trim....
  14. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    Oh yes, stubborness is a trait all of us probably have here. I thank formally for that thought, because I have never given up on/or let one beat me and I'm not about to start with this one.
    Your right, I should go back and take a good look at and re-fresh my charts on the problem. Its not the primary operation in the shop at the moment and the mind does get a little stretched.
    Thanks for the input,
    J
  15. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    That's the problem I've been dealing with. Location. They clearly (ECU's) move P0303 from bank to bank as they get cleared and swapped, however is it because *master* stays master and *slave* stays slave? The Leonardo reads the P0303 (as stated) moving from bank to bank as they get swapped.
    Also the fuel trim values go opposite (+/- short term) as a result of swapping (observing strict rules of "no throttle input and minimum 10 minutes run time).
    Thanks for chiming in,
    J
  16. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    So a side thought...the customer also complained of a "harsh shift/clunk" (it's an '03 F1). As the weather here does not permit me to test drive at this time, I have not verified the complaint. I know these box's can be noisy and it has some age on it, however he seems to think there is a correlation between the two (misfire and gearbox noise).
    This maybe a topic for another thread but I wanted to feel out the thought of a misfire issue disrupting/confusing the calculations made for F1 shift change.
  17. fatbillybob
    Aug 10, 2002
    29,258
    socal
    It has been 1 week. Any news of the diagnosis?
  18. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    So, finally the car has come out of winter storage. We got a new ECU from Ferrari NA and after installation I've got crank-no-start with P1570 (immobalizer). I could not have been any more careful with the installation (battery charger, grounded ECU, 10 min KOEO before crank, etc.) Davide at Accinni said its probably a bad bus line to/from ECU.
    Is there anything that I'm missing with this ECU installation?
  19. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    I'm no expert but is it possible the unit was previously tried in a different vehicle? If I understand how these ECUs work the one in the master position gets perma-linked to the Immobiliser in that car and can not be used on a different car thereafter. If someone previously had the bright idea of using your "new" ECU to try and diagnose a problem on another car perhaps this would lock it out of being used on yours?
  20. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    Good point. The costomer purchased the ECU himself, however I cracked the seal on the packaging and it looked lagitamite.
  21. tbakowsky
    Sep 18, 2002
    20,037
    The Cold North
    Tom
    Is the car a coupe or a spider?? If its a spider, check all the connection pionts behined the drivers seat fuse block...they are a bit of a bugger to get too as the go under the rocker panel a bit. These connections corrode and create high ohm readings which can give out all kinds of crazy running issues. Check them...I had to replace an entire harness because of it.
  22. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    Thanks for that, and it is in fact a spider. I was thinking of digging in that spot again. I had some of those panels off when I did the comp and leakdown testing and did a cursury inspection by defauld. However I was only dealing with the P0300 at that time. I will be getting the car back on site within 24-48 hours and will resume the hunt.
    Thanks for all the input guys, much apreciated.
    J
  23. jasonlanglois
    Dec 20, 2010
    28
    Alliston ON, Canada
    Jason Langlois
    So gents, I've got the sultry red/tan mistress back in the shop. I only managed to get three hours into her as the shop is very busy (not a complaint as we are finishing a long and satifying resto project).
    Everything started nice. Located security ECU (that had been *into* in the past). I Preformed a pin-drag test and failed two terminals. This prompted me to go back to the R/H ECU...thats when I became angry. Its one thing if your working on the some Ford van thats on its last leg but come on...pierce testing the main harness six inches below the main sheithing without puting ANYTHING on the hole you made! GRRR.
    Sorry, anyway back to the point. After doing more tests and looking at the workshop manual I have found two lines from the security module to be bad on pin drag, one on high resistance. Also five lines from the R/H ECU to be bad, one to the security module and the rest to the engine (including cyl #1 #4 coil and cyl #2 injector, no wonder the ECU didn't have a chance).
    My question, is there a differance in main harness length between Modena and spider? I pulled the harness out from the ECU location and it was double folded about one foot down from the connector (and made a craking noise like my wallet;-). It seemed to be incorectly routed. I have access to Modena WSM and the routing as such seems shorter.
    Thanks again for the help guy's, even more so to those on the phone.
    I've been asked many times what it takes to work on these cars day-in day-out and the answer is always the same...a clear head and lots of patiance.
    J
