Using an f1 gearbox for a manual 355 application | FerrariChat
Discussion in '348/355' started by PAUL. S, Sep 17, 2011.
  1. PAUL. S
    PAUL. S Karting
    121
    Can an f1 box be used in a manual application, from what I understand the gearboxes are the same, its the ancillaries that differ. I would be grateful if anyone can confirm the basic box can be used, as I have access to a bare f1 version but want to use it for a normal h gate set up
    Appreciate any help and advice
    cheers
    PAUL
  2. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    I have a complete manual gearbox if you need one.
  3. PAUL. S
    PAUL. S Karting
    121
    thanks for the offer, but I am in the UK and this one is local to me if its any use for my project
  4. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    The F1 gearbox should be no problem at all....the difference is internal and will work with a manual set-up.
  5. Ricambi America
    Sponsor Owner
    Some things, like the release bearing are specific to the F1 variant, but if you have your old box and the new box, you'd be able to get all the proper bits. IIRK, the lower cover is different on the f1 box because it is drilled to accept the position sensor. So that's the kind of minor stuff you'd face.
  6. PAUL. S
    PAUL. S Karting
    121
    thanks for the info.
  7. Europeanroadandracing
    Europeanroadandracing South Carolina
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    I installed a manual into an F1 a few years ago. I'll try to remember the details but I had to machine the release bearing flange because the inputshaft was shaped differently.
  8. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Can you turn a manual box into an F1?
  9. Europeanroadandracing
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    #9 Europeanroadandracing, Sep 18, 2011
    I've done it successfully.
    Karl Troy
    PS since the F1 was a one year wonder in the 355 there were no used ones available. It was the only way to save our client huge $$$$$.
  10. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    Why would anyone want to? :)
  11. Europeanroadandracing
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    Because a new F1 tranny costs more than half of what the car is worth.
  12. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,400
    London, England
    Sy
    Thanks Karl. May investigate it further.
    I've got a manual 355 gearbox and am considering putting it in my 348, ideally with a flappy pedal for faster gearshifts.
  13. Europeanroadandracing
    Dec 19, 2003
    2,228
    Isle of Palms, SC
    Karl Troy
    I just want to clarify.
    We were working on an existing F1 car. The gearbox failed and there were mo used ones available. We modified a gearbox that came out of a manual car and installed it in the F1. We did not convert the car from manual to F1.
