Using Nitrous in a 308 with carbs. | FerrariChat
Discussion in 'Technical Q&A' started by carb308gtb, Nov 28, 2008.
  1. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    Is it doable, I was thinking about a wet system with 16 nozzles, 4 at each carburetor and about 50-100hp and of course the system only get activated at full throttle and the timing is then retarded and with the right spark plugs.
    Have anyone done this with a 308 or is this a bad thing to do?
  2. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,207
    Austin, TX USA
    Greg
    Can the drivetrain/clutch handle the additional load?
  3. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    #3 Fast_ian, Nov 28, 2008
    Not according to a thread I just read, but can no longer find..... [Sorry - It's not in the 308 section as I don't "go there", but darned if I can find it.]
    The comments therein seem to suggest that the rear stub axles and/or uprights will (may?) fail. But, I'm not sure how many HP he's feeding 'em.
    Cheers,
    Ian
    EDIT: Found it: http://www.ferrarichat.com/forum/showthread.php?t=101045&page=6
  4. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    Thanks, but one thing we must remember is that with full throttle and extra nitrous is not the same thing as a supercharger with torque at the bottom of the rpm.
  5. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    In Bishop's great book on Ferrari maintenance, he has a short chapter dedicated to how one guy was doing nitrous at Bonneville IIRC and the guy did a motor meltdown. I think he had a supplimental fuel line become clogged, ran to lean and holed a piston or two, with poor results.
    Something to think about,
    chris
    Now, if you had a haltec fuelinjection system and could program it to do the right fuel.....
  6. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    Yep, the fuel delivery is important so you don’t go lean; nobody wants a hole in any piston.
    Anyway with the right settings it is okay in any engine, but will the 308 take the load at full throttle?
  7. fatbillybob
    Aug 10, 2002
    28,772
    socal
    Did that to my carb 308 about 25 years ago. put in jets until I ran out and could not destroy the motor. Took the motor out to rebuild it for more HP and it miked out just fine no acelerated wear. I used 4 throttle plates w/ rod nozzles for gas and NO with hob switch to make sure there was fuel pressure before the NO came in. It was very crude in those days no rev limit. What city do you live in I could help you make a monster. 100-150hp is very easy. Best thing is it is more than 100hp because NO build torque and HP across the entire RPM range.
  8. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    You miss tinkering don't you ;).
    cheers
  9. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,792
    Cerritos, CA.
    DO 308 HAVE Forged Pistons?
  10. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #10 luckydynes, Nov 29, 2008
    This is what I've come up for my 308 with the Haltech ECU and I wanted to have a semi-covert system.
    I'm going to use the main fuel injectors (existing EFI conversion) for fuel enrichment and limit the rpm that the nitrous will be engaged if I have a problem running out of duty cycle.
    Billybob ... isn't this more fun than rebuilding 348 gearboxes/fixing Ferrari blunders? LOL.
    cheers
  11. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    stock no but Billyboy played with the stock setup for a while.
    Forged in my motor though.
    cheers
  12. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    #12 luckydynes, Nov 29, 2008
  13. fatbillybob
    Aug 10, 2002
    28,772
    socal
    YES! What is really fun is when you have a Nitroused 308 sleeper and you eat Pbugs, vette, and any ferrari in a straight line. I've run 308 carb cars with nitorus plates and 308 qv care with a single plate just after the throttle body. My thinking was that since these cars were CIS and had a cold start injector they must flow a wet mixture in the most dry manifold decent enough. I ran lots of nitrous in the QV too and no damage known. I think maybe I'll run some on my 550 just for laughs and giggles. It really does not need any more power but what the heck. I'll probably be lazy and keep the amount of NO small and read plugs to prevent lean out. If I wanted to do it right it would be dinking with injector pulse/rev limits on and off/and NO entry after the MAF. To me doing direct port means you want max NO flow and that means bigger injectors and bigger injector and short duty cycles for 99% of daily driving would probably mess up drivability.
  14. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    fatbillybob thanks for you answer, that’s very impressive, you force this little engine to work hard and with no problems, sorry to say but I live in another country, Sweden that is, otherwise we would have a nice project.
    I was thinking to drill in the nozzles under the carbs, and let’s say I make a 100hp spray. The engine is stock with a clean work in the intakes so they run smooth and the sodium exhaust valves is now stainless and this is a dry sump engine.
    Is it better to make a plate under the carb instead of drilling the intakes?
  15. fatbillybob
    Aug 10, 2002
    28,772
    socal
    Whatever disrupts the air flow is always best so that your normal drivability will not be effected. I like plates because they are dumb low tech. If I did direct port etc I would need to be sure the design was sound before I did it and then have to think about all the negative effects. The positive effects are only on nitrous which is a very small percentage of the time. To me that's what is so attractive w/ nitrous over turbos etc
