V-12 Engine into 308 Build, over on Grassroots | Page 100 | FerrariChat
Discussion in '308/328' started by dave80gtsi, Jan 16, 2019.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Yes park & sun, and yeah, just the net goes for $170, the whole set with the poles is more like $1500 and that is the kind of deal Lana simply can't pass, even if we in no way need it. That is done and a permanent part of the yard now so on to more important stuff....
    I've picked up tasks at work that have required evening calls all this week and next making it harder to justify turning on the AC out in the shop and doing stuff but I'm free tonight and through the weekend. I still don't have a real plan for how I'm going to pressure test the intake ports beyond I'll need to fix the tig torch to fix the leaks when I find them. And the pistons need to come out so I can fix the valve pockets. I want to inspect all the bearings, i'm pretty sure I left a few in I shouldn't have last time. So plenty to do while I make a port repair plan.
    Ferraripilot likes this.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    So years ago I had water leaks and rigged this up to find them. I air pressured it and found and welded the holes.
    The problem now is oil from the cam galley.....and I'm probably thinking WAY to much. I guess I just install the cam cover and make a plate to seal the timing chain end with a fitting for the leak down tester. Then I need to seal the valve guides so I just ordered some 5mm plugs, they will be here Sunday so I'll target having everything else ready by then and just get on with getting it fixed.
    LE06 and Ferraripilot like this.
  3. sltillim
    sltillim Formula 3
    1,729
    San Diego
    @mk e I tried sending you an email on the power steering but it bounced back - can you shoot me a note at [email protected] ?
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    This week and last I've had work calls in the evening so little shop time during the week. I filled my time thinking about what to do when this engine is running.....and I'm thinking nothing says "I'm a dumb-a$$" quite like an 8-71 blower with dual quads on a flathead V12 sticking through the hood and mid mounted just because I can....I'm trying to figure out how to add wings that look right.
    Hopefully in the shop working on ferari heads tomorrow. :)
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    I took a look at the steering.....and decide I needed some processing time because even thought the new EPA unit is generally smaller, its a bit longer along the steering shaft so there is really no way I'm putting a quickener...well....unless I attack the steering column which I kind of don't want to do.....but I frikin love the quick steering so I really don't want to give that up.....but I don't need another big or expensive project.....processing time.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    I've now got myself about 3/4 talked into gut building a steering rack......
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    I set the steering stuff aside and got back to the engine. I cleaned up the decks which seemed to take forever then checked the liner protrusion. I got 2-4 which should seal fine.....but I set them to 5+ last time so that kind of confirms the deck is not really strong enough to support the liners and things are moving.....but they are high enough to seal :)
    rwbolt1, LE06 and Newman like this.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
  10. Anthony Rapuano
    Anthony Rapuano Karting
    Aug 16, 2022
    216
    CT
    Anthony V Rapuano, Jr.
    I'm not an engineer, but those valve relief cuts seem awfully close to the outside edge of the top of the piston. Will the piston be compromised in any way as a result? I've been following your journey with this build off and on. Hope you're getting close to fulfilling your dream.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    That is an excellent question and one I do not know the answer to. I've never seen/read anything beyond sand the sharp edges which I will do once I finish machining....but how aggressive I need to be radiusing I'm just not sure....1/16" maybe? that would mean nothing thinned than 1/8" remains....1/32? I'll see what it looks like when I start sand I guess.
  12. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,538
    Canada
    Newman
    It's fine. Factory pistons have the radial relief cut going down the side of the piston. What matters is the amount of material above the ring.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
  14. sltillim
    sltillim Formula 3
    1,729
    San Diego
    I was looking at a bunch of cars for you. It looks like you are on a similar track. I think one of the most beautiful cars out there is the Delage D8-120 S, which I was lucky to see in a museum once. Otherwise look at the custom's by Rick Dore, who nails art deco inspired cars.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Very nice, but all front engine.....I'm just not getting my head around the right look in a mid-engine. I've been busy trying to figure out how to get about 400hp from a 125hp engine to make the project worth doing and I think that starts with rods that won't fly apart.....about ready to order some I think that should fit, save 100g (rod+piston) and EASILY handle 35hp/cylinder.....I don't have time for this right now but another guy wants to split the order and that about cuts the price in 1/2 so....now it is. I'll get back to play with body design on the 308 is running.
    LE06 likes this.
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,488
    Dumpster Fire #31
    SMG
    Yes, the ring land to deck is critical to avoid collapse. Also the pockets can create thin walls and that's where it gets tricky. Leave the thin wall? Window it out?
    The consideration is down to combustion pressure and temperatures and the material thickness.
    There's a crossover point where it's too thin and it creates a hot spot that risks detonation. But what that is, is really a combination of a bunch of factors.
    Various gas laws and some calculus will get a decent ballpark number when you've got the peak pressures and temperatures for a given combustion event. Then using the thermal conductivity of the material, it's thickness etc.. easy peasy.. :D:eek:
    Honestly outside of crazy knife edge walls, ring gap is a bigger risk for detonation and problems.
    Newman likes this.
  17. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    245
    Boerne, TX
    Rodney Bolt
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
  19. LE06
    LE06 Formula Junior
    289
    Lee
    Could I stuff that in my X1/9.............
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    For a long time I thought my next build would be a 308 powered x1/9 and I still think it a good plan.....but you know a v12 x1/9...hmmmmm...that would be quite a thing. The V12 is narrower f/r so that helps.....you're probably going to need some decent rear flares to make the width, but yeah i think its possible. Bring it over and we'll start cutting.
    Ferraripilot and LE06 like this.
  21. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    502
    Pacific Northwest, USA
    Dave W
    Haven't you been there, done that with an X already Mark? How about a 308-powered Scorpion this time around? ;)
    - Dave
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Yeah...but I didn't do a very good job, it was ugly and nearly undriveable when I "finished" so I've always though it deserved a do-over. But ill likely never get to it.....unless @LEO6 somehow drags me in
    LE06 likes this.
  23. LE06
    LE06 Formula Junior
    289
    Lee
    I would love to try but I would have to sleep at your house. After my other car project my wife may lock me out of the house.:D
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Well.....I almost bought a motorcycle. I took my son to a track day with his and it physically pained me to stand and watch. When we got home he was talking about racing in the spring and that was too much so I started looking at what it would cost to join him and class rules and such. There is a special class for 40 and up...and I just turned 60 :eek: Luckily the one I was eying we couldn't agree on price so back to the ferrari.
    I have the bottom end all over the bench so I decided to finish that so its off the bench before the heads. I think I mentioned I don't love the way the bearings look so I ordered new....at least I think I did, I haven't seen the bill yet but sometimes they wait until its packed to get the shipping. Remember I cleaned out the crank last time but I didn't polish the journals at all so and for whatever reason the bottom side so all the rod journals was a little rough but it mics fine so a quick light polish so I know there is nothing rough and new bearings.
    Then rings...they are quite a bit more expensive then they were in 2019. Last time I talked myself into the totalseal with a gapless 2nd because the bores are about 0.002 over so the ring gaps are like 0.018 when they should be 0.015. Last time they were $36/set, now they are $59/set. JE rings that were I think $25 are now $38 but I have 2 sets so $380 for 10 more instead of $708 for the gapless it is. I was worried about low rpm before but now I know there is no issue so I figured no need to spend more.
    I need to see what stones I have for my hone to deglaze the cylinder and get everyht5ing clean while I wait.
    LE06 and ZikZak like this.
