V-12 Engine into 308 Build, over on Grassroots | Page 30 | FerrariChat
Discussion in '308/328' started by dave80gtsi, Jan 16, 2019.
  1. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    Thankfully you noticed the leak preventing any “flamethrower” action! So close to starting, very exciting!
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    Pulled the manifold off and didn't really see the smoking (or leaking) gun but o-rings didn't look great so I ordered all new, be here Wed. In the meantime I'll get everything cleaned up and ready to install and maybe have another look at the tach.
    dinogt4guy and Aus_yz like this.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    Back to when I was cranking the engine to prime the oil pump and noticed I had like 10psi oil pressure and thought it fine....but then noticed I also has around 10psi fuel pressure with the fuel tank empty and pump off. Last night I discovered that the pressure transducers read just fine on the bench but when they are installed and the chassis grounded they have a 0 offset...270mV on the oil pres and 330-370mV on the fuel as it drifts around 30-40mV. These are 2 brands from Amazon, as typical chinese stuff they look the same other than the marking on the casing...both are junk it seems. I'll try 1 more where a couple reviews specifically mention no/low offset for fuel (don't care about the exact value for oil as long as its reading something so I know there is pressure and I can remove the offset in the ECU easily) before ordering a $200 Honeywell version cuz I do need to know fuel pres to calculate the correct mixture
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    I've had very good experience with these,
    https://www.te.com/usa-en/product-CAT-PTT0028.html
    Mouser, digikey and I think Newark should have them. Normal go-to is mouser.
    MS is now TE. Price point similar to Honeywell. From what I've read TE is better suited for the automotive environment.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    Yes, I was looking at something very similar
    https://www.digikey.com/en/products/detail/honeywell-sensing-and-productivity-solutions/PX3AN1BH100PSAAX/5878260?s=N4IgTCBcDaIA4A8DMBDAdgRgEYAsMAZ8QBdAXyA
    They both even use the connector I already have, but both are 1/4NPT instead of 1/8. I just had to add a 45 elbow to the oil so if I could get to it I could change it for the new sensor...but even manifolds off reaching it isn't easy. On the fuel, adding a kludgy looking adapter is a no-go so I'd need to retap the port.....hence my overring 1 more Chinese sensor just to be sure the rework is needed
    In other news I decided to try 3x8mm lower o-rings instead of the standard 3x8.5mm on the injectors to make assembly easier. The plan this time in rail end in the rail, then pop the manifold ends in....I think that is how I did it before to avoid the fuel side leak risk but that makes the lower o-rings REALLY hard to install without pinching/cutting so these should help at the risk of a mild vacuum leak I suppose. The rail o-rings are coming today so assembly/test tonight hopefully.
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    Stupid question.. are you using any grease on the injector o rings? I've never been able to get them to insert dry without problems. Since I've usually got a tub of Gibbs open during assy, I use a bit of that on them. Slips right in. STP has some old school lube, works fantastic but dang near impossible to remove if you need clean up, like anti-sieze!
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    Right, dry is flat impossible on this setup. I have been using WD-40, but noticed the rail o-rings get pretty stuck on removal so this time I pulled out a tube of silicone grease to try
  8. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I've used Wurth HKS oil on fuel o-rings with good results; BG also makes a nice light silicon lube that works well too.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    The new fuel pres sensor is much better, 71mV offset and seems stable. The oil pressure still reads 0 with the 270mV offset so it appears stable and I'll call them both good enough.
    The manifold o-rings came yesterday, I bought 3x8mm instead of the standard 3x14.5mm to make it a little easier to assemble and they seems fine. Just waiting on UPS to bring the rail o-rings now. The plan this time is make sure the injectors are seated in the rail then pop in the manifold end because the fuel needs to be sealed but a small vacuum leak doesn't really matter so I want all the risk shifted to the manifold end as best I can.
  10. Vonbarron
    Vonbarron Formula 3
    2,281
    Westside Mofo
    S B
    You guys are using lots of trigger words, Dear Penthouse Forum, today I fingered some lube for some tight O rings
    Jdubbya likes this.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    Car porn.
    Well...its almost sealed this time. It looks like a mist coming from 1 injector on the end. Hopefully 3's a charm.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    This is a challenging assembly. I didn't have room for 2 fuel rails or to assemble the rail to the TBs then drop the assembly into place so assembling relies on everything flexing enough to pop into place.
    I decided the rail wasn't sitting just right and was torquing against the injectors so I sawed the end off and repositioned it a bit....and then there was fuel pressure.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    I put the plugs in then spent some time trying to get the boots to right right and the wires resembling neat
    As long as I was making stuff a bit neating, I gorilla taped over the hack job I did on the stacks so they at least look right even if they aren't
    oh yeah, then I started it....a little....on staring fluid. I'll give everything a good look over and spend some time with the log now and be share everything there looks right before another go.
  14. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    Sounds good. That cam profile has a unique sound I recognize:cool:
    High rpm it'll scream:D:cool:
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    Right, if I'm not mistaken you worked on an engine with ALMOST as radical cams ;)
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    Yup, a couple actually... Let's see..
    4L NA monster
    3.5L QV NA
    QV supercharged
    Your build sounds closest to the 3.5L build. Oddly, as the 4L has ITB trumpets... But it's also sporting a massive custom tri-Y exhaust currently open so it's stupid loud. Once tamed with a muffler it'll be interesting to see how it sounds.
    Valved exhaust though with that cam profile really makes a 'bark'. 4k and up just howls.
    The 3.5L was fitted with a valved Capristo, custom headers. But stock plenum so there was this constant sucking whistle. The supercharged QV is sporting the same exhaust but I used the custom manifold with a monster oval 2k CFM TB.
    Banzairacer likes this.
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    Mine are large tri-y headers as well. 4 mufflers, 2 are loud 3" race mufflers good for about 800hp, the other 2 are 2" hotrod mufflers good for maybe 150hp eacreach and not TOO loud for normal driving. The valves are wired open for now but the ecu will control them at some point.
    Banzairacer and smg2 like this.
  18. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    I've got to dig up some audio video files on the 4L engine. Now where did I put them?....
  19. Jdubbya
    Jdubbya The $10 Trillion Man
    43,696
    Hell's waiting room
    You tease. :D Posts like this need a Love not a like button. Look forward to hearing and seeing more. How long ago did you start this whole project?
  20. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,922
    Atlanta
    John!
    way cool Mark. Keep cracking.
  21. Cirorsi
    Cirorsi Formula Junior
    790
    Louisiana / Lac du Saint Sacrement, NY
    Steven
    Really nice job Mark!
  22. ginoBBi512
    ginoBBi512 F1 Rookie
    3,535
    SO CAL
    GINO RUGGIERO
    Im so looking forward to your machine completely dialed in !! Everytime I see a new post on this thread, I get so excited !!! I have my fingers crossed, and pulling for you Sir.
    Thank you
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    Running , 6-7k, idle around 2k, pretty rich so a lot of tuning to be done
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    14 year last month.
    yeah, I know.........
    Jdubbya likes this.
  25. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    Sounds good, real good.
    Yeah, that sounds like the big 4L but with more pops:D like an entire bank more:p:D
    You need a key man... I get Nick to run start/stop and leak checks while I'm manning the PC.. real time tuning keeps you on yer toes. Rolling cart, folding chair right next to the engine bay. I'm assuming your ECU has a kill switch hot key, can't tell you how many times that had come in handy.:eek:
