V-12 Engine into 308 Build, over on Grassroots | Page 72 | FerrariChat
Discussion in '308/328' started by dave80gtsi, Jan 16, 2019.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    The is interesting and looks to be about what I'm thinking is needed with the changed ride height.....is the ride height on the 288 adjustable in some way?
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    No, just standard Koni coil-overs. I guess if you were serious about tracking the car you would swap the shocks.
    Not sure how long those suspension forks would survive being stamped steel and used with sticky tires.
    mk e likes this.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    I've been having that same thought as I think about how I might want to implement any designs I eventually settle on. Mike's idea of weld-on adjustable has a lot of merit....but we all love the idea of bolt-on stuff. It looks like superperformance is sell brackets that must be just offset versions of stock but the more offset the more twisting, fatique forces are there. Maybe just make it thicker metal or I'm strongly considering new bosses in the frame.
  4. Rifledriver
    37,288
    #1779 Rifledriver, May 23, 2024
    The forks need regular inspections when used with oversized or sticky tires. They do break right at the radius on the front suspension. 328 with its bigger tires was recalled for those forks. Ferrari made new forks with a near 50% increase of the gauge of the metal. . What I have seen more was broken rear stub axles. I have advocated for years on 308 track cars having them magnafluxed on a regular basis. They are old cars being used with tires we never dreamed of in the 70's.
    Newman and Ferraripilot like this.
  5. Rifledriver
    37,288
    That was never intended to be used. It was there only to homologate the car to allow it to have adjustable ride height for the class it was intended to race in. A class that was dissolved before the car was finished.
  6. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    Im having new stub axles made that take a larger bearing so I don't watch my rear wheel pass me. Boxer forks look to be billet steel but the integral stud doesn't give a warm fuzzy feeling. Drill it out and run a bolt through it.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    I have a similar plan, we should compare notes or more accurately drawings :)
  8. Rifledriver
    37,288
    Before going to the expense have a look at Mondial axles. Pretty sure some are bigger.
    Have never heard of that bolt failing in anything. Have a look at BBLMs and see what they used for forks. That car was mostly off the shelf parts. I have never heard of them having suspension issues and high banks are really hard on suspension. But then the gearboxes broke so much maybe they never had a chance.
    Newman likes this.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    How do we get this question answered? anybody know the bearing numbers maybe? no point in reinventing things
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    #1785 mk e, Jun 1, 2024
    Stub axles again. So a 308 uses a 40mmID outer bearing and it looks like modial8 uses the same axles;
    A 348 axles uses a 45mm ID bearing and early cars the same CV joint as 308 so are a possible upgrade option.
    328 and 3.2Mondial use a different axle from 308 and 348....anybody know what size the outer bearing size is? I don't ever recall hearing about broken 328 stub axles? so I'm guessing 45mm but would love to know for sure.
  11. Rifledriver
    37,288
    Mondial 3.2 and T both use 45 mm axles.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    Thanks! And it looks like the 3.2 mondial and 328 axle PN are the same, and for sure the 348 is 45mm so lots of parts to pick from it looks like.
  13. Newman
    Dec 26, 2001
    14,523
    Canada
    Newman
    I wonder if going to the park brake shoes inside the rotor hat on the 328 meant they changed another dimension that might throw a wrench into your plans?
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    Maybe....probably the only viable path is update the whole carrier assembly. I think I can get my hands on a loner 348 stub before deciding to buy anything.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    I found an OLD fchat thread from 2001 that was talking about 308 stub axles and included a 328 that lost a wheel at the track and blamed a poor design with inadequate radiusing and no heat treat, apparently fixed on the 348. I saw a couple 348 left side wheel carrier assemblies on ebay for around $1000-$1300, no rights to go with. It will likely be $2.5-3k if I go down this path. I'll likely end up making stub axles....
    Ferraripilot likes this.
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    I know this suspension/stub axles is a little ping-pongy but I don’t want to fix the suspension and then change the wheel carriers and need to fix it again. The 348 stuff is a pretty pricey so kind of refocused on making stub axles and I have confused myself a bit. The 308 uses a 40mm (1.575”) ID bearing, the 328 and 348 a 45mm (1.772”) ID bearings but the 328s still have issues, maybe material, maybe design, probably both.
    My plan was grab grab some US diff axles to use as blanks and start cutting knowing they rarely break and ASSUMING that was because they are big and heavy…wrong. The big bearing ford 9” and all the mopar use a 1.564” ID bearing, not quite 40mm. The small bearing 9” and a lot of GM stuff use 1.53”. There are some GM trucks with 1.618”…WTF? These things don’t break without REALLY trying and they are smaller?
    Design wise the US axles all have a pretty decent radius between the wheel flange and bearing surface and that must be where the magic happens. For sure the US axles are heat treated and the 308 are not for whatever reason. The ferrari stubs have a nut torqued on to hold the CV flange, that is an extra force I guess.....but it feels like a slight design change will sort the issue. Just not certain the off the shelf US axles have enough metal where I need it, I think so? I probably need to pull mine apart and get some measurements so I can be strategic about what I order.
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    This race car raced 9 seasons pulling 2Gs in the turns using 308 wheel carries and bearings with 4340 stub axles...so it seems a well design axle has no issues.
    I emailed Strange engineering to see if they are interested in making 208 axles or interested in partially finished non-hardened axles to at least save me the annealing step.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    Just got the long awaited email, gaskets are ready to ship!
    Sadly I'm only 1/2 done with the floor refinishing :(
  19. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,919
    Atlanta
    John!
    Hey at least they'll be sitting there waiting for you.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    #1795 mk e, Jun 23, 2024
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    Sooo pretty
    ...and come with some pretty interesting instructions like start the engine without coolant and let the heads come to 40-50C. Then water only to full temp. Then coolant. We shall see! (once I free of house work)
    Aus_yz, Ferraripilot and Ferrari Tech like this.
  22. Ferraripilot
    May 10, 2006
    17,919
    Atlanta
    John!
    Super cool. That guy in Australia has a really good knowledge of all the super dangerous wildlife and stuff down there too. Scary stuff, everything wants you dead in Australia
  23. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,271
    Gold Coast, Aust.
    Patrick
    What, you want to live forever?
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,811
    The twilight zone
    All the time mindlessly sanding floors has me thinking I should upgrade the alternator before the engine goes back in. I'm sure its marginal at this point and I have a plan forming in my head that involve an electric AC compressor. I see a 12V 3speed unit on ebay for $500-$600 that is probably big enough....1140W, so like 85A, although the word say 35-66A input which seems to not match the rpm/power required chart. Maybe even pull all the stock HVAC stuff out and fit a vintage air heat/AC unit that does all the modern stuff like work properly :) Anyway, I would need a much higher output alternator is the point.
  25. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,464
    Dumpster Fire #31
    SMG
    I would suggest you look at hairpin wire alternators. We get custom units built for our builds of that flavor due to thermal and esp high rpm. Everything from 180-300+amp. Serpentine belt though.
