V-12 Engine into 308 Build, over on Grassroots | Page 75 | FerrariChat
Discussion in '308/328' started by dave80gtsi, Jan 16, 2019.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    Since you have a weakness for dynos, let me direct you to this ad
    https://www.ebay.com/itm/276627600406
    That includes most of what you need to adapt to a pre-83 ferrari V12 and know that all proceeds will go to support a deserving 308 :)
    I've decided that as much as I love the idea of "every day is dyno day" its probably best I try to do my best normal person impression and go rent dyno time when I need it.
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,919
    Atlanta
    John!
    Super cool. I have the perfect room in the shop for it too. My shop is 5-10 minutes from Road Atlanta, lots of shops around here and exactly zero dynos of any kinds nearby, it's bizarre. What stopped me is it might pigeon-hole me into being just the local dyno guy and I'd be doing way too much of it, and some idiot would come to the shop and injure themselves doing who knows what maneuvering an engine or whatever. Nope nope nope
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    It sounds like you need to become the cranky dyno guy where people are afraid to step out of line in your shop. I knew a chassis builder like that, great guy to competent customers and while I spent very little time in his shop (he did some bending for me) I saw him throw 2 would be customers out. you could be that guy with you spiffy GoPower dyno :D
    Ferraripilot likes this.
  4. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,153
    SanFrancisco BayArea
    1983 US 308 GTS QV
    You just have to charge the "I don't really want to do it, but if you pay me this much ..." prices.
  5. Vonbarron
    Vonbarron Formula 3
    2,279
    Westside Mofo
    S B
    Do you have a Zelle account?
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    Me? I had to gooled it but I can and and would love it to go to a good home. Email me, [email protected]
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    I was remembering 1/16" off the motor mounts so that's what I did, just 1/16" of an inch before putting the engine in.
    I bought 12 point flanged nuts for the headers, which made the install SOOO much easier as it was a 10mm wrench not a 13mm. The front set needs to go on before the engine is fully down...which led me installing one of the headers over the lifting strap. OK, jack it up, loosen the header, pull the strap, retighten, a 30 plus minute delay but the new nuts saved way more than that and now time to drop it down.....and the right side is sitting 1/4 may in the air....floating really. I screwed around for about 2 hours trying to figure out how the f.. a 700lb engine floats off the mounts and it was about 8 things I guess the last of which was a nut I lost fixing number 6 or 7 was found under a mount, it turned out that 1/16 of an inch I took off the mounts mattered. .... it was that kind or night.
    Right now its sitting properly on the mounts but not bolted. The flywheel still clears the frame by a full 1/4". So the 1/16 I was remembering is what I thought needed to come off the bottom of the decklid and 3/16 needed to come off the mounts. In the morning, after a couple honey-dos I will cut another 0.150" off the mount and get it bolted in place. I'm hoping to be ready to run Sunday.
    LE06, ZikZak and Ferraripilot like this.
  9. Ferraripilot
    May 10, 2006
    17,919
    Atlanta
    John!
    A whole 1/4” lol
  10. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,457
    Dumpster Fire #31
    SMG
    At a certain point a removable sub frame just makes sense:D
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    Can you even imagine how good this thing it's going the handle once I lower the engine OVER 3/16"?
    Me either....but I can imagine the deck lid fitting :p
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    I like to think I'm smart enough to have made a different choice if I'd known the effort it would take to lower the engine 3/16"....I'm probably not but I like to think I am. It's finally bolted, there is just shy of 1/8" clearance under the flywheel cover and I will no doubt enjoy the amazing handling improvements now that the engine is sitting so much lower Image Unavailable, Please Login
    For sure I'll enjoy being able to close the deck lid. Image Unavailable, Please Login
    tomberlin, smg2 and INRange like this.
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    It's just going slow this time. I bought new CV boots but never installed them and the axles had to go in so an hour e that to change the boots. The puke is getting small though...4 hours left?
    LE06 and smg2 like this.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    I worked a solid 8 hours on what I thought was 4 hours of tasks and its at least on the ground
    but I still need to install the coils and the front WBO2 sensor then pull the left rear wheel and tie up wires. There was a bit of a stupid tax when I couldn't find a 3" long piece of hose and had to buy a $40 fits I don't know what radiator hose because they no longer stock generic stuff plus the time to go get it. Then again when I filled and primed the oil system but for whatever reason the 10 quarts I ordered didn't fill the 14qt system so back to the store....but it has good oil pressure cranking and its returning to the tank properly and nothing is on the floor (yet). And yes I filled the trans before I even put the drain plug in the engine.
    This is a little funny, I completely forgot I changed the clutch master so when I bled it and the felt the force needed I thought I messed something up with the clutch. Oh wait, I switch from a .70 to ,75 master because it was so soft and I thought I'd rather have a faster pedal and it turns out a 15% force change is very noticeable. Its still a pretty light clutch so no worries but now I'm really excited to try to brakes that should now be about 25% less force with the new masters and it will be less force yet once I actually get the higher friction pads I picked out but were backordered.
    I don't like to start fresh engines in the dark so tomorrow after work I'll finish up then Tuesday first thing after work I should be ready to try it. That's the plan anyway
    LE06, steved033, Ferraripilot and 2 others like this.
  15. LE06
    LE06 Formula Junior
    260
    Lee
    This is a great build! I cant believe that V12 fit!
  16. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    It's got to be angled just right going in, drivers side about 2" lower then passenger side, no more, no less.
    LE06 likes this.
  17. LE06
    LE06 Formula Junior
    260
    Lee
    Very cool! Sorry if this has been asked, I have not read the complete thread. Are you running a standalone ECU? If so which one?
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    You should read it then ;)
    The ECU could be a thread all on its own, it's an enginelab it programmable not just tuneable. It runs pretty much everything now.
    LE06 and INRange like this.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    I think I should whine about oil a little. Sunday I ran to the auto parts store to buy some oil. I am running 20w50 for break-in which to me is a very normal thing I've used it in various car and motorcycles for 40+ years. At the parts store I very nearly gave up as 0w16 has replaced it on the shelves but just as I was about to leave I saw they had 6 bottles of 20w50 castrol classic high zinc in a clip on rack next to the main oil display like a little freak side show. 0w16, what has the world come to?...next thing you know they'll be trying to sell us electric cars Image Unavailable, Please Login
    The OEM specified oil for this engine is 10w50. I don't recall ever seeing that in a store, but it is available to order so after break-in I may hunt some up.
    LE06 and Ferraripilot like this.
  21. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,334
    Atlanta, GA
    Steve D.
    as long as you don't have to worry about a cold temperature start, 20w50 will probably do fine?
  22. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,457
    Dumpster Fire #31
    SMG
    Oh noes an oil thread!
    I run this in all our old Mercedes and Ferrari engines.
    https://www.liqui-moly.com/en/us/mos2-antifriction-sae-10w-40-p000207.html#2042
    The new engines run what looks like straight water these days. Chasing that epa fuel economy.
  23. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,457
    Dumpster Fire #31
    SMG
    Hadn't really caught the plug wire setup you've got. The resistance Bank to bank is going to be different just given the lead length. Have you noticed any effect on the kernal and flame energy? I.e. spark formation for burn, hot enough?
    Thems some looong leads!
    If you're interested I can dig up a bench setup to test high voltage amp draw and spark energy I made way back in my days of high energy physics lab work. Fairly simple setup with voltage dividers, amp clamp loop and a massive resistor.. Oh and a scope. High frequency high voltage is a funny beast.
    It's a shame that non resistor plugs are such a PITA to find.
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    Yeah that sound right. The lighter the oil the faster it makes pressure and the larger the range XwY the wide the temperature range it maintains pressure in the target window. I tend to be a bit rough with engines so I like to make sure I have the higher end covered more than the warmup so when it says 10w50 and the store had 10w40 or 20w50, I always bought the 20w50. Now they don't have it and I'll need to order, so I guess I'll order the correct 10w50 which several brands sell and its not more bother anymore....I guess in a way they did me a favor.
    And please no one take it as fighting words, its just what I like to do, not telling anyone else what they should do :)
    steved033 likes this.
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    Why make it so hard man? :confused: The coils are pretty hot, like 60k volt with a pretty long duration....it all seems to work fine as long as the insulation isn't cut.
    Honestly I never even thought about it. The shortest wires are about what the shortest stock wires were and the longest about what the longest stock were. Now the rear bank all have about the same length and the front all about the same....so I guess if I think I notice a timing issue I can do a bank correction.
