V-12 Engine into 308 Build, over on Grassroots | Page 98 | FerrariChat
Discussion in '308/328' started by dave80gtsi, Jan 16, 2019.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    yeah....I guess there really isn't a need for both. I cold go this way too I guess
    ChevyDave and smg2 like this.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    smg2 likes this.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Todays I played with the push to start bit and good that I did as nothing really worked the way I hoped and it became quite jumble of stuff on the bench
    But I think I got it doing what I wanted, there is a video
    Then I printed an adapter for the VW button that I think came out pretty well and I was pleasantly surprised the threads worked with only minor futzing
    I sprayed it satin black, I'll see how that looks tomorrow. The black button is still on the way so I still might go that way but I think this will look closest to original.
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Can somebody measure the OD of the stock trim piece on the ignition switch? The one I made just looks a little big so I'm wondering what stock is?
  5. Dockboy
    Dockboy Formula Junior
    643
    Maryland
    Mark,
    53.2mm OD
    32.2mm ID
  6. Dockboy
    643
    Maryland
    That is for an early '77
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Thanks! That is a huge help!
    I guessed pretty close....Mine is 50mmOD, 28.5ID, for a 10.75mm wide ring vs 10.5 wide stock...but I guess the fact the mine is slightly smaller to fit the VW button makes it LOOK wider/bigger than stock. I may take 1 or 2mm off and see if I like it better, and reprint if I decide bigger was better I guess.
    Dockboy likes this.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Dockboy and rwbolt1 like this.
  9. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    245
    Boerne, TX
    Rodney Bolt
    I have to nerd out. What is your 3D printer rig? And what filament are you using?
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Oh, I need to decide what to do with the LED too....it needs ground to light so I guess another relay. Its not really bright enough to see in daylight so my thought was wire it to be on with the dash lights but power on is fine too. Chatting with a buddy yesterday he offered to take a look at making a simple no relays controller box for me so I need to write down what I did for him so I'll hold on final wiring this stuff in and see about getting the CAN to steering working and I guess the ECU setup and wired for starter control.
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Its an anycubic resin printer and I use their abs like resin. its 3 years old(?) so they don't make this particular model any more but the newer ones I'm sure are better. when we first got it we had to play with the support and attachment settings to get it to reliably stick to the build platform and not leave holes int he part where the support break off....but once we figured that out it prints really nice. I think we've gone through about 8 quarts of resin at this point with not issues and the list of printed 3-08 parts keeps growing...velocity stacks, mirror mount convers, starter button bezel, I was going to print a box for all the bits on the bench to make the button work but I'll hold to see where that ends up.
    Just sold my older filament printer, never turned it on after getting this printer.
    rwbolt1 likes this.
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Here is what I built to get
    touch or hold - on
    touch or hold - off
    This is how I got that working, it was $26 in parts from amazon, but everything was 2 packs...so $13 used plus the button. The output of this will trigger my aux and ignition power relays. I'm planning to let the ECU handle the starter relay so it will crank until it starts or time out at maybe 5 sec for a no-start situation...or I could just connecting a starter relay directly to the button for push and hold to crank.
    LE06 likes this.
  13. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,488
    Dumpster Fire #31
    SMG
    Do you have it so that it'll power on in acc mode if the interlock brake or clutch is not activated. Useful for ECU programming/reading etc without starting.
  14. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    My ecu is only on in the ignition on position but yeah, the plan is ignition on no crank is an option.
    I was planning on on ecu handling the starter..... but I'm sort of back to press and hold the button as it just gives me more control so it should work like
    No brake, no security switch
    -press(or hold) button = aux power on
    - press(or hold) again = aux power off
    No brake, security switch on
    -press(or hold) button = aux + ign power on
    - press(or hold) again = aux+ ign power off
    Brake + security switch on
    -press & hold button = aux + ign power on+crank while holding up to 5 sec about
    I would need to add a couple timers for the push and hold cranking....I'm thinking 1/2 sec delay for fuel pressure then a time out so there is no cranking during push to stop......or I might still do ecu control of cranking......
    smg2 likes this.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    This is the bit for push and hold for cranking. Note my clutch swith goes to to ground not 12v. The timer lets the ecu boot and fuel pressure come up which is nice, but also effectively locks out the starter once the button is released.
    I ordered a 5 pack of 40A relays with connectors for $9, they'll come tomorrow so I can finish up the wiring. And I need to print a little box to hold the relay/timer boards.
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,488
    Dumpster Fire #31
    SMG
    So you have to let the clutch out to stop engaging the starter... Hmmm... Is there a way to have the clutch simply activate a timer or feedback so that you don't have to be quick on the draw? Or is the starter relay there timed?
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    No, no.
    Press and hold the button, the ignition comes on about instantly, that sends voltage to the output side of the timer relay which engages at about 1/2 sec (could be anything), the starter will crank until the button or clutch are released.
    Press and hold again, the ignition shuts off about instantly killing power to the starter circuit before the time is close to finished so no cranking occurs.
    It will act like a simple Press and hold button from a race car, but also cycles the ignition...almost a turn push to start but should work for any engine, no efi or ecu required...I guess the clutch switch is optional, a nice safety feature but not needed like it would be with a true push to start where it cranks until its running whether you release the button or not. Here releasing the button is the samecas releasing the key, it stops cranking.
    smg2 likes this.
  18. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,488
    Dumpster Fire #31
    SMG
    Gotcha, that makes more sense. I just kinda interpreted the schematic.
    The clutch interlock might sound redundant but when you get used to just pressing a button to start and forget you left it in gear one day.. Habit and all.. the interlock just ensures that extra step prevents a real "jump start" been there.. It's why I added the clutch interlock.
    On the automatic modern cars the brake depress is annoying..
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Yes. I was thinking about my kids who have never driven anything old without all the safetys....even the lawn mower has them. But 308s like most older cars don't have clutch switches, so my thought was for anyone who wants to do this, the clutchvswitchbis optional or could be replaced by a brake switch, but the brake swith is off/12v, so 1 extra low-power relay would be needed i think.
    For the automatic with true push(and resease) to start, the brake is what tells the ecu if you want just the radio or you want the engine. 1 button with 1 position can do 1 thing, but radio or engine is 2 things and that needs 2 switches....so press the brake.
    What i drew is a little different...push and release=radio, push and hold=engine, 1 button, 2 action, 2 results. This seems better for older cars where you kind of don't know how long it will crank and generally don't have and ecu you can have monitor that.
    Time to get (re)wiring and check thisvoff the list.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    #2445 mk e, Jun 28, 2025
    Still working on the push to start......but close now
    I printed a box that everything mostly fits into (I had to file the sides on a few of the bosses)
    I printed 2mm holes, then drilled 0.093" so #4 sheet metal screw that fit through the 3mm holes in the boards nice
    Wired a little neater with a few colors so its easier to tell what's what
    And it seems to work
    Touch - on
    Tough- off
    Hold on at least 1/2 sec (+clutch) it's on and cracking until release
    Starter locked out after release so touch or hold off, no crank
    I still need to wire in the power relays so it actually controls the car but that is pretty straightforward so I expect to wrap this up tomorrow.
    ZikZak, ragtop1, Ferraripilot and 4 others like this.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    so it turns out straightforward and quick are not at all the same thing...behold the 80s Italian art
    It is all wired and working though other than the clutch pedal switch and that wire is run and hanging at the switch ready for another day. I kind of forgot I wanted a light on the dash so I need to run 1 more wire for that.
    Step 1 was of course unpin the pre-pinned connects and throw out the wires, I am not a fan of splices where they are not absolutely needed.
    I have no idea what I was thinking when I did this whenever I did it.....only think I can think is I didn't want the connection burried in the mess but I need that relay slot so burried it is
    And it appears the subwoofer has aged out and there is now a hole in the foam ring supporting the cone....which has me pondering just removing the stereo in the name of I can't hear it over the engine anyway so why not save the weight....need to think about it.
    Ferraripilot and LE06 like this.
  22. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    502
    Pacific Northwest, USA
    Dave W
    Phone+Spotify+Ear Buds = All The Stereo You Need.
    - Dave
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    Yeah, that's what I've been thinking. Removing most of it is easy, but the door and dash speaker not so much so I planned to wait until I was redoing those items.....so i'll likely just put the sub back. I need to think about this a bit.....
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    I'm guessing we're all pretty tired of looking at wires but the silly push button is all wrapped up
    In final testing I did find the the relay board was not really behaving as it should. A pretty quick tap would sometimes having it switch and switch back and then the light in the button stopped working. I swapped to the spare relay board but the same thing and the same failure with the light. Not sure why but the ICs they added for I don't really know what reason were the issue, so I jumped past them
    and removed 1 of them that just wasn't behaving at all and got all angry about the jumper.
    and everything I tried works right Getting the wires on the clutch and brake light switches was not so easy with the power steering in the way but I got them so the brake lights are working again (I didn't realize they weren't working when I was driving) and the clutch down for the starter works right.
    With that sorted I wired the ECU CAN buss to the power steering so now I need to add code to the ECU to read the brake and clutch switches and talk to the steering units....then I can get back to the engine. The tig torch I needed to fix the intake ports has been sitting on the bench for a while
    As has the piston.
    so engine work soon......
    smg2, Ferraripilot and ChevyDave like this.
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,830
    The twilight zone
    The last couple days as I found time I worked on the ECU to PS unit CAN stuff and tonight the ECU was able to turn on the PS. My laptop died before I had time to mess with the steering force but it works so I'm pretty happy. I set it up so I can test different settings easily so I should be able to get the force stuff sorted without a lot more effort....should....
    As an added bonus when I was looking at the CAN buss data I was pretty sure I was seeing the PS unit sending out the steering position so when I was writing CAN code I added some stuff to read that channel from the PS unit and convert it to something meaningful so now I also have steering wheel position displayed on a gauge and available to log which is a great bonus as I had no idea that info was there to be had.
    I think this means I can put the dash back together and get on with fixing the engine.
