V-12 Repair...NOT! | FerrariChat
V-12 Repair...NOT!
Discussion in 'Technical Q&A' started by 308GTB, Mar 5, 2007.
  1. 308GTB
    308GTB Rookie
    Mar 22, 2006
    24
    ontario
    Rob
    A friend sent this link and I figured it was worth a post!! A reminder that anything is possible with a vintage Ferrari! WOW! Wonder what that "ACE" was mixin' with that pepsi? Yukon Jack maybe? and LOTS of it! haha! "Can't find my soda Bubba,guess were gonna hafta drink'r strait!!
    http://blog.hemmings.com/index.php/2007/03/05/ferrari-v-12-repairnot/
    Oops! Probably should have posted this in general discussion! Sorry! Mods please move if necessary...
    Cheers Rob
  2. QWKDTSN
    QWKDTSN Formula Junior
    Oct 14, 2006
    373
    WA, USA
    Steven Patch
    Funny thing is, that looks like a very recently made Pepsi can. Probably no more than 2-3 years old.
    VERY weird. Thanks for sharing!
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    That was'nt a diet was it?
  4. DMOORE
    DMOORE Formula 3
    Aug 23, 2005
    1,720
    San Diego
    Darrell
    That's just crazy. I've seen some hillbilly engineering but that is one of the strangest.
    Darrell.
  5. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Too much end float hey :D
  6. DGS
    DGS Seven Time F1 World Champ
    72,097
    MidTN
    DGS
    Could'a been worse. A shop in MA messed up the (multi-piece) head gaskets on my GTV-6, and rather than fixing the misplaced gasket rings, they kept torquing the head bolts until they pulled three studs out of the engine block.
    I wondered if maybe the same MA shop did that to the VT car -- but the MA shop was only Alfa and Maser, and has been out of business since the '80s or early '90s.
  7. blainewest
    blainewest Formula Junior
    Aug 26, 2005
    729
    Kelowna, BC
    Blaine W
    That's incredible...but s**t happens as we know. Makes me glad I do most of my own servicing. At least the mistakes are mine and I know how things have been done.
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Not surprised, If you take enough of them apart you'll see everything. I rebuilt a Healey gearbox. Someone had substituted finishing nails for needle bearings.
    I guess it was better than toothpicks.
  9. DGS
    72,097
    MidTN
    DGS
    Necessity is the mother of invention. For non-concours "driver" examples, sometimes it's better to innovate and be on the road, than to sit waiting for the "correct" part.
    Alfa shops used to stock $400 (in '70s dollars) spacer kits for adjusting the plungers on Spica injection pumps. On mine, at one point, I found that a dutch 10FL coin was a perfect sized substitute on the cold idle plunger -- and a lot cheaper than $400. ;)
    But innovative parts substitution is different from just plain messing up. Leaving your soda sitting on the block while installing the heads is just plain attention deficit syndrome.
    And similar to leaving something in the way while trying to close the trunk --- and we've all been there, at one point. :p
  10. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    The can wasn't used as a fix, but as a tool. When you install a head on a V12, you must use a piece of shim stock to hold the large square cut seal ring in place on the timing cover. As the head is slid down, you pull the shim stock out. The head tends to pull the shim down, and for some reason whoever used the Pepsi can let it get pulled down and did not remove the head and start over again.
  11. PAP 348
    Dec 10, 2005
    100,220
    Pap
    #11 PAP 348, Mar 9, 2007
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,350
    Dumpster Fire #31
    SMG
    I didn't know that, but i was going to say it looked to be intentional use as the top and bottom of the can had been cut off. no excuse for not doing right though.
  13. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    He's right, It's part of that brilliant engineering. Only the Italians and British would have sealing surfaces meet at right angles. It is part of the reason there is always a little (if you're lucky) oil on your floor.
    Pretty careless not to pull the "shim" back out. I'll bet the phone rang.
