V12 engine rebuild bill? | Page 2 | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by John Se, Mar 29, 2005.
  1. Horsefly
    Horsefly F1 Veteran
    May 14, 2002
    6,929
    This link http://www.roelofsparts.com/ from a post by Tom Yang on his site.
  2. thecarreaper
    thecarreaper F1 World Champ
    18,155
    Savannah
  3. DBR328&330
    DBR328&330 Formula Junior
    May 31, 2001
    605
    Winchester, VA
    Daniel Reese
    Great thread.
    On a twist:
    In what kind of shape is a typical UNrebuilt 40 year old Ferrari V12 in terms of compression, rings, valves, smoking etc? Do they all need a rebuild at some point?
    Given the extreme cost of a rebuild, when do you decide an engine needs rebuilt? It would seem to me that driving a car with an engine that is a little tired is better than rebuilding it.
  4. Rifledriver
    37,327
    In the 60's and 70's when we were still stuck with using the old Ferrari parts doing a top end on a 250, 275, 330(valves, guides, pistons, rings, liners, rebuild the entire valve train) at 25k miles was considered normal. It wasn't until the 365 that they started to last. Thats one of the reasons so many of those early motors have so many parts to fix now. With the modern high quality parts available now the motors last much longer and with as little as most of those cars are driven a good motor overhaul now will probably last the rest of the cars life.
    As to when to decide I have done several just because the owner was embarassed to drive a multiple hundred thousand dollar car that smoked like an old Vega. When you consider the value of the cars the motor overhaul price is not out of line and as said before adjusted for inflation it has gotten much cheaper over time. A Ferrari does not cost a hundred or more thousand dollars because it is built from a pile of $20 parts. It is in fact built from a bunch of very much more expensive parts that don't fit together very well and takes great care and patience to make it work well and run correctly. And don't forget a 250 Pininfarina Coupe motor costs just as much to rebuild as a 250 GTO.
    Come to think of it knowing very well how much work it is to do one I think 25-35k is a bargain and I don't regret not doing them anymore.
    BTW I was in your neighborhood over Easter up in Round Hill. Prety country, just wish the weather was a little better.
  5. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    I'll see if I can get you some photos. Mine is 42 years old and appears to have never been rebuilt in all that time.
  6. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    14,364
    Central NJ
    Wayne,
    What made you decide to rebuild rather than repair?
    By the way, once the engine becomes stronger, you will soon discover if you have any other weaknesses in your drivetrain - I did.
    Regards,
    Art S.
  7. Davidindallas
    Davidindallas Formula Junior
    Nov 5, 2003
    344
    I've enjoyed reading this thread. I have often been tempted to bite on an earlier car (a 330 or c4 say). I've worried that a rebuild will be on the menu at some point of my ownership (I'm not a seller). I've asked of my mechanic (who I count as one of the handful you all cite as capable of doing a complete rebuild) whether the rebuild, if prospectively needed, would also produce useful power gains, given the prospect of stronger modern materials (pistons, rods, etc.). His answer was no. You can't really gain much from a rebuild on an older V12. Do other agree?
  8. El Wayne
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    Simply put, wear, wear everywhere. It was time.
  9. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    14,364
    Central NJ
    Ouch! Sorry to hear Wayne.
    I hope it doesn't dampen your spirits too much. I'm sure it will be a blast when the engine is fresh. How fresh is the rest of the drivetrain?
    Art S.
  10. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    14,364
    Central NJ
    David,
    If the engine is worn, the engine's ability to hold a compressed charge is reduced. This results in lower power output (note, this is an oversimplification). When you rebuild an engine to stock specs, you will gain power, not much more than intended but substantially more than the engine was making prior to rebuild.
    Art S.
  11. Rifledriver
    37,327
    Unless you change the tuning specs (compression, cam grind ) no. You will just have a motor that puts out the power it should and will last longer if the proper component suppliers are chosen.
  12. DBR328&330
    May 31, 2001
    605
    Winchester, VA
    Daniel Reese
    Rifledriver,
    Winchester is a great place and has wonderful driving roads. Some are great for the 328 (twisties) and others for the 330 (long sweepers).
    My engine makes good power and doesnt smoke, and although it may not be as good as new, it sounds like a rebuild isnt neccessary until something becomes intolerable. Its never been rebuilt.
    Dan
  13. ferraripete
    ferraripete F1 World Champ
    michael (carreaper),
    i have a friend that possess similar skill sets as you and i must say, i am always thinking that he is the perfect vintage ferrari owner. w/ a factory book and your tools...and your ability to make your own speciality tools...well, i just get jealous. boxer ownership will be a breeze for you and quite frankly w/ the exception of the expensive parts...you will be the perfect boxer owner.
    go get a bad azz boxer and when you figure it out (in no time!) you can coach me!!!
    your boxer bud,
    pcb
  14. thecarreaper
    18,155
    Savannah
    why thanks, i REALLY need to come up there and vist. my grandfather has been in poor health and i have my house all taken aprt doing some rennovations. and i work on airplanes all day..... :)
    seems a underlying commonality in the comments is that the engines are "unique" and less " mass produced" as regular engines and parts. fine fitting parts is critical in race and drag engines, the tolerances depend on the application, ie a loose engine with a supercharger, a tight engine for power / no add ons ect. from what i have been able to find on google, some of the ferrari parts can me made new ( like Horsefly's link shows) and some of the stuff is rare, rare and super expensive.
    we really need to find a way to save these cars. i know folks of means dont sweat the small stuff money wise, but "we" should not allow all of the cars to vanish. save them i say :)
  15. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    WOW! Excellent fabricator!
    Even down to the cylinder head? That must've cost a fortune
  16. Tspringer
    Tspringer F1 Veteran
    Apr 11, 2002
    6,155
    I remember reading an article about a shop that uses massive CNC milling machines and very high tech computers controlling them to mill engine blocks and such from billet.
    They were producing brand new Maserati 250F engine blocks, cylinder heads and cranks. The complete cost for these basics for a "new" engine was about $100K. They said most of the big boys vintage racing a 250F or a 300S were now using these reproduction engines. They give more power, are more reliable and most importantly if they blow up a priceless matching numbers original engine is not destroyed.
    So, if you have the $$$.... ANY engine can be recreated!
    Terry
  17. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,509
    MA
    If people are racing with replica engines that never saw the factory (and could replica transmissions or differentials be far behind?), why not just race full replicas and not have to worry about any aspect of the original car?
  18. Tspringer
    Apr 11, 2002
    6,155
    I agree.... why not?
    As I have said before, the hands down absolute best and most fun race I saw all of last year was the the televised Speed channel coverage of the Goodwood Revival.
    F1, FIA Sportscar WC, LeMans GT, ALMS, SCCA, NASCAR.... none of these had racing that was as exciting to watch nor as closely fought as the Goodwood Revival.
    Those guys flogging the crap out of Cobra Daytona coupes, E-Type Jags, Aston DB4GT's, Bizzarininis, Ferrari 250SWB's, 250GTO;s, 330LMB's and all the other vintage hardware were AMAZING!
    Watching those cars with big HP and skinny tires sliding all over the track, passing back and forth, going side by side at 130mph in full 4 wheel drifts as the drivers pushed to 10/10ths and beyond in an effort to win.... it was without doubt the best RACING I saw all of last year and I can say the same about the year before.
    Some folks scream about the dangers or such close racing in such valuable and irreplaceable cars. They claim that "racing" such cars should not be actual racing..... whatever.
    But if they could have such races using EXACT replicas.... then everyone would be happy. We could have the amazing close racing in cars that place a maximum on the drivers and are a hoot to watch AND we would not be endangering the historic hardware.
    If such a series existed, not only would I watch it, I would buy such a car and race it!
    Terry
  19. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    Not only is there CNC machines that cut, there are stereo lithography machines that lay down molds. It's far cheaper if you're doing more than one engine.
    Water passages and other hidden dimensions make block recreation a lot harder than you would think, even with today's technology.
  20. jsa330
    jsa330 F1 World Champ
    10,059
    75225
    Scott
    Then, the next step would be to volume build exact-replica vintage cars for road use, but the feds wouldn't let us have them.
  21. Tspringer
    Apr 11, 2002
    6,155
    Not a problem. Just purchase a rotted out '65 VW bug complete with title for $100, transfer over one of the switches or something, then title your new Ferrari 250GTO replica as the '65 VW. Presto.... grandfathered in and legal good to go!
    Guys are importing and selling the new Superformance Cobra Daytona coupes and doing some sort of title gimmick to make it all street legal so there would be a way.
    Terry
  22. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    14,364
    Central NJ
    You wouldn't have to buy a bug, just get one of Tom S.'s rollers and use the title, keep the roller as a wall hanging.
    Art S.
  23. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Kit cars are exempt from all kinds of things. Look at the Nobel. They ship the body and chassies and you stick 'em together. Presto! A $75k supercar that otherwise would be illegal in 50 states!
    Ken
  24. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    well this is where I stand with my 330 rebuild....
    headwork--new valves, seats, rocker arm rebuild, line boring and fitting VW bearings on cams, new titanium rollers, +++ 5-6k
    new cam grind 1200
    block/crank honing-300
    new 10.0 pistons 1200 ( have a set of new venolias too that i am trashing--600) make that 1800 total.
    New carillo rods 800
    rod and crank bearings 3-500
    new studs, nuts, washers---400
    block decking, cylinder out-in, cyl honing--800 to 1200
    assembly and reassembly time----100 hours????
    basically looking at about 4-6 k in parts and 10-14k in associated labor for the various work.
    Oh--and the danmed 5k in legal bills from sueing a thief/mechanic that screwed the heads completely...
  25. drew365
    drew365 Formula Junior
    Jun 22, 2004
    252
    The Valley, L.A.
    Andy Ritter
    I wish I could say I am going to add my 2c, but my recent rebuild has cost over 35k. I still don't have the car back, though it is running. There was a fair amount of machine work that needed done, and some misc. work to other parts of the car. My car had 67k miles on it and it ran strong but was smoking and it was a little embarassing to drive. So I pulled the engine out myself and took it to a local specialist. I didn't realize I was opening up a can of worms. I plan on keeping and enjoying the car for several more years but if I realized then what the final cost would be and how long it would take, I would have sold the car as is and bought another.
