V8 -- does the single distributor mod reduce fire odd? | FerrariChat
Discussion in 'Technical Q&A' started by GrigioGuy, Apr 28, 2004.
  1. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,340
    E ' ' '/ F
    Splenda Daddy
    Greetings.
    One of the concerns with the US setup is the fear of frying the car with a dead bank. Does converting to an alternate setup reduce that chance?
    What would be a recommended solution for an updated ignition system, and what have you all used with success?
  2. Steve Magnusson
    26,931
    I think it depends on what you call a "single distributor" set-up. Even though the F single distributor has only one body and one cap, from an electrical architecture viewpoint it's still two four cylinder units operating in a parallel interleaved way (so 1/2 can fail independently). If you graft on a US electronic distributor from a V8 (or Unilite, Mallory, etc.) it's more likely to be a single electrical unit from an operation standpoint -- i.e., if something/anything fails, the whole thing stops working.
    If you update the dual distributor set-up with a pair of Cranes or Petronix, it's still a parallel interleaved system (even if you put both triggers in the same distributor).
    What's your $ level and concern about reversibility and/or modification? (some of the distributorless systems are cool, but pricey, and a significant mod).
  3. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    To add to what Steve has said, if you convert to a true single distributor/single coil ignition system, then the famous single bank ignition is impossible.
    FWIW, I have had single bank ignition failure three times. Since I like simple DIY maintenance anyway, I had Norwood's do a conversion for my 3.2 to use an OTS Mallory performance Unilite distributor adaptor which also allows me to fine tune my timing. It's also (hopefully) a bit easier to maintain, parts available and inexpensive, simple technology, and more reliable. Am installing this week. That whole distributor cost less than one OEM Ferrari distributor cap is also a plus. The Electromotive distributorless are more accurate, but much more complicated - this is easy and good for me. Have covered the details in other threads.
    best
    rt
    Picture of adaptor and distributor installed on test head:
  4. GrigioGuy
    Nov 26, 2001
    33,340
    E ' ' '/ F
    Splenda Daddy
    Thanks for the input.
    I use the car daily, so I'm looking to improve it when it comes to the mechanical elements. I haven't had a failure yet, but it will happen, the odds just require it.
    In order of importance:
    1) I want the solution to result in an all-or-nothing failure. Since the single mode isn't a limp home, but rather a car-B-que, there's no advantage to the interleaving.
    2) Budget is a concern. I'd rather not pay 5K for a distributor conversion. However, if that's what is required to be safe so be it. I can live with non-originality, as the car isn't for sale and is destined for further modifications eventually.
    3) Something that will work with an aftermarket engine management system/EFI would be nice, so that I don't have to pull it when I finally change over to that (a few years out)
    4) An updated electrical system will allow me to put the catalytic converter back on the car.
    The Norwood/Unilite system below looks like a very valid option.
    I know there was a great writeup on dist. conversions somewhere in the archives, but I can't seem to find it. Does anyone remember that thread?
    Thanks for all the feedback.
    --t
  5. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    i have had the electromotive direct fire unit on my 308 for 4 years now and no mishaps, car starts all the time, even on cold colorado 20 degree mornings, and my chokes ARE disconnected.
  6. Wayne 962
    Wayne 962 Formula Junior
    503
    Where do you get that adapter, Norwood?
    -Wayne
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Yes - Norwood - talk to James Patterson.
    Installed last week and runs well.
    IMPORTANT POINT: More good news is that the old ECU still runs the tach with the coils disconnected - yea!
    No more single bank failure - yea!
    Pictures next week when I get back from this trip.
    best
    rt
