Vacuum in Petrol tank | FerrariChat
Discussion in '348/355' started by JOW02, Mar 13, 2010.
  1. JOW02
    JOW02 Karting
    Apr 3, 2008
    92
    Brisbane
    I have a 355 (2.7) which keeps sucking the rubber seal off the inside on the petrol cap. I have replaced the cap twice and within 30 mins of driving you can take the petrol cap off and the rubber seal has a large bubble as it has started to come away from the aluminium cap. I have also noticed that on undoing the petrol cap, even after car has been sitting for several minutes not running, there is a large amount of vacuum preasure as you can here the air rushing in as the cap is undone. My question is should there be this vacuum preasure in the tank or has one of the vents become blocked which therefore causes this vacuum to build up. Has anyone else had this problems as those caps are expensive to replace. Look forward to your ideas!!!!!
  2. JOW02
    JOW02 Karting
    Apr 3, 2008
    92
    Brisbane
    Come on guys. Some one out there must know if the 355 should have, under normal running conditions, either vacuum, preasure or neither in the fuel tank.
  3. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Mine has postive pressure and I think that's normal. (5.2 single fuel pump model). I've never heard of a vacuum - and it must make unscrewing the cap even more difficult than it is already.
    As for the cause of your problem, there will hopefully be some experts chiming in. To start the ball rolling, may I suggest a problem with the vent pipe (142104) or the anti-evaporation system (which ends with the cannister low down in the rear left hand corner of the car). In addition to the vent pipe, there are three pipes from the tank to the disareator.
    Maybe the system isn't "breathing" properly, with the fuel used from the tank creating that vaccum.
    Look at Daniel's (ricambi) web site to see the drawing of the pipes etc coming out of the tank. Type a part number (e.g. 142104) to get access to the schematic - Table 11
    Hope you get a fix soon.
  4. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,828
    Austin, TX
    Reg
    Well I'm no expert but my car does the same thing as listed above (poss. pressure) '95 2.7, I'm pretty sure if you do a search you will find a few posts on this. If I recall someone could'nt even get there cap off after putting it on a little to tight..:eek:
  5. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    There's a well-known case of Ernie having a malfunction (valve?) in the charcoal emissions system of his 348, resulting in a vacuum in his fuel tank, and partially crushing it! I'm assuming the 355 is similar, although don't know. I'd recommend you have your system looked at soon! :)
  6. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #6 eulk328, Mar 14, 2010
    This is from page 4 of 14 in the recent USA Recall Campaign 48 (for the 355 fuel block replacement). It would SEEM to indicate that pressure is to be expected rather than vacuum (can you ever be 100% certain with Ferrari documentation??) :
    "Unscrew and remove the fuel filler
    cap to release any pressure from
    the supply system. Then, screw the
    cap back on – (Fig. 6)."
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    #7 ernie, Mar 15, 2010
  8. JOW02
    JOW02 Karting
    Apr 3, 2008
    92
    Brisbane
    Thanks for your replies, especially Ernie, for all the info. I thought it would be something in the "Evaporative Emission Control System". I will look into it and let you all know the verdict is. Thanks JOW02
