Valve adjustment and compression. Would like opinion or comments | FerrariChat
Discussion in '308/328' started by bl10, Jun 6, 2020.
  1. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    1978 GTS US. Got it running a while back after sitting in my garage for 27 years.
    Smog pump disconnected, empty cats, Pertronix Ignitor II otherwise all original.
    Passed Calif Smog with flying colors. (I put all smog stuff back on)
    Car has been setting for two days in So Cal so it was cold (for Calif).
    Before starting valve adjustment (2v) I did compression check.
    Plugs ,iridium, looked perfect and engine idles and runs great. Just a quick note I did a compression check about a month ago and the front bank test consistently low at 100psi however I discovered today the O ring on my compression gauge was cracked and leaking plus I wasn't screwing it in tight enough. Once I changed the O ring the front cylinders were the same, except for #7, as the rear.
    All cylinders 150psi except #7 at 140+. Seems low but also very consistent. I had throttle wedged about half open. Tested each cylinder 3 times with same results. I don't have a leak down tester but there is no blow by to speak of, It's not smoking or burning oil and I couldn't hear the intake valves leaking during compression test.Think I'll try it again tomorrow with throttle all the way open. In any case is 150psi acceptable?
    Pulled rear cam cover, what a pita, I had adjusted the rear bank valves 30+ years ago and used liberal portions of gasket sealer. Actually had to use a heavy duty impact puller to break it loose. No sealer this time except at cam seal / gasket intersect points.
    The valve clearance, particularly the intakes, is puzzling.
    3 intakes at 0.14mm 1 at 0.12mm. Sb 0.20 - 0.25
    3 exhausts at 0.28mm 1 at 0.26mm.Sb 0.30 - 0.35
    I checked each valve 3 or 4 times and double checked I was using the metric scale.
    Intakes really tight, exhausts tight but not to bad.
    When I set them at 25K miles they were 0.22 and 0.32 mm or as close as I could get them. Engine now has about 70K miles on it.
    Does tightening this much sound right?
    Barry
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,824
    Cerritos, CA.
    Barry when I check compression I always have the throttle at full wide open. Try squirting some oil in the cylinder that reads low and check the compression again and see if the compression increases, if it does then the rings is probably just stuck in a collapse position and usually loosens up after driving it for a while or other possibility is that the valves are not seating properly, just a thought. 70k miles is really not high, ive seen 308 with double that mileage and ran like a top.
  3. Albert-LP
    Albert-LP F1 Veteran
    8,182
    around Modena, Italy
    Alberto Mantovani
    Mike, no way that a cast iron slider or an original Borgo piston can last 140 K miles with still a good compression ratio: carburated cars had them as OEM equipment and so at that mileage they are gone since a lot of time. It depends about the usage, of course, but the average cast iron slider with OEM Borgo pistons durability is around 70-80 K miles. I mean when the play between the slider and the piston will go over the maximum play allowed: the engine still works, of course, but the compression ratio starts going down quickly and the oil consumption starts going up quickly too.
    But you are 100% correct if you are talking about QV and 328 only, as they have OEM Nickasil coated sliders and Mahle pistons: they can last 140-150K miles, not as new, but without losing too much compression.
    So, in my opinion: if you have a carbed car with 70+K miles and you have some compression ratio issue, very likely a lot of the loss comes from valve seats and guides, but some comes from the sliders and pistons too.
    ciao
    miketuason likes this.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,979
    Isle of man- uk
    Just reset the clearances as they have only decreased by .05 to . 1 in 45 k miles. That is 2 to 4 thou. Valve clearance can drop as the valve impacts into the seat. In regard to the one compression being a little down, give the car an oil change and a few hundred miles of speed running and see if it evens out. You may just have gummed rings and the new oil can help to free them up.
    I have seen a ferry engine get sea water in the sump oil and jam the rings, after changing the water pump to stop the water ingress we changed the sump oil and ran the engine at low power for a few hours, did this for a few days changing oil every day and increasing power until we had it back at 5000 horsepower. The new oil every day cleaned out the gunge from the ring packs
  5. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Thanks guys.
    While I haven't checked the front bank yet I'm a little surprised by the the valve train noise when its hot. (runs at 195 on hot day with AC on). Its not excessive just noticeable. There is no discernible valve train noise when it's cold. I wouldn't expect an overhead cam engine to change clearance much as only expansion, which would increase clearance, would be the cylinder head. Based on the rear bank I suspect the rear bank is going to be even tighter.
    Anyone got a method to get the washers off the acorn nuts, particularly the bottom row, on the front bank without dropping them? The rear bank washers were difficult as several of them were stuck to the cam cover.
    Barry
  6. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Hold a very high-powered pocket magnet next to the socket/fastener while turning the tool; do it slowly and the magnet will catch them.
    Saabguy likes this.
  7. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Ok, I give, what are "sliders?"
    Lester
  8. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    He means (cylinder) "liners".
  9. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Got it. I kinda figured cylinders just couldn't navigate my brain to sliders.
    Thanks,
    Lester
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,979
    Isle of man- uk
    The exhaust valve will expand its length due to the exhaust temp, hence it has a bigger clearance. The inlet valve runs a lot cooler due to the inlet charge keeping it cooled.
    First time i have heard a liner called a slider
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,979
    Isle of man- uk
    Are you running 5/40oil ? Re the noise when hot
  12. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Conventional 20/50w with a quart of seal Lucas seal softener. Its got got good oil pressure and the top end is receiving plenty of lube. Using a remote starter switch to rotate engine when checking the valves causes oil to flow to the cam chamber.
    Thanks for the magnet suggestion. I used a strong but very large magnet and socket to help with the rear acorn nut washers but ended up using a dental pick to loosen the washer then a standard long reach automotive magnetic grabber for those I couldn't get with my fingers (rear bank). I haven't removed the rear engine cover yet, probably easier with it off. Maybe rotating the socket, if I can find a magnet small enough will work.
    I will document the each shim today to see if I can move them around rather than buy all new ones. I will also check for "hollowing" out but based on the clearance I don't expect any.
    Any suggestions on gasket adhesive removal? It's going to be a real job to clean the gasket surfaces on the head. Might try acetone or lacquer thinner.
    Barry
  13. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Depends on the adhesive material. If it's silicone, it's just a lot of manual cleaning. Personally, I'm a fan of plastic scrapers.
    FrannyB likes this.
  14. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Yup its red silicone and the gaskets I used waaaaaaay back then were black (paper I think) OEM from the then local Ferrari parts store. Any way it's a mess. The cam covers shouldn't be to much of a problem as I have a parts washer (harbor freight) that I can use in conjunction with green scotch brite. The head on the other hand is just going to be a long arduous process. The front cam cover and head should be a real joy as I don't think its ever been removed.
    Barry
  15. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    Is it the first time you've read an Italian writing in English and not getting the translation perfect? How's your Italian? Perhaps we should be cutting Alberto a bit of slack.
    kerrari likes this.
  16. Albert-LP
    8,182
    Alberto Mantovani
    Liners, sorry: the cylinder walls where the piston goes up and down.
    My fault.
    Ciao
    Saabguy likes this.
  17. miketuason
    Feb 24, 2006
    15,824
    Cerritos, CA.
    Some calls it sleeve cylinder
  18. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,979
    Isle of man- uk
    I had a go learning Italian but have to admit it got the better of me.
  19. Albert-LP
    8,182
    Alberto Mantovani
    Ferrari calls them "barrels" in the 308 QV spare parts catalogue and "liners" in the 308 GTB spare part catalogue. In Italian they are called "camicie" (shirts) by mechanics and "canne" by technicians
    derekw and miketuason like this.
  20. miketuason
    Feb 24, 2006
    15,824
    Cerritos, CA.
    I guess different countries and different mechanics have different terms but here in the US it’s know as cylinder sleeves but I guess they are all the same thing.
  21. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,611
    California SF bay area
    Paul
    Yea I think in the States “sliders” are little hamburgers. It could get confusing lol.
    Saabguy and miketuason like this.
