Valve Cleaner Recomendations | FerrariChat
Discussion in 'Technical Q&A' started by Chris Mead, Jun 9, 2004.
  1. Chris Mead
    Chris Mead Rookie
    Jun 9, 2004
    1
    Any recomendations for a fuel additive valve cleaner? I have used Lubro Molly every 3K in the past but I am having a tough time finding it.
  2. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I have heard good things about Chevron Techron engine cleaner for fuel injectors and valves. I'm trying some right now. Hard to know if it's doing anything though!
  3. f355spider
    f355spider F1 World Champ
    18,055
    It would seem advisable to avoid most additives, unless you have a specifc problem you are trying to address.
  4. pnorman
    pnorman Rookie
    Dec 30, 2003
    47
    Redline fuel system cleaner is great. It treats 100 gallons (it's marked in increments) or you can use a bottle in one tank if you need a real cleanup...Patrick
  5. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    We have a very highly regarded place here in MA that works on classic Ferraris as well as many other expensive cars. One of the guys there advised me that Techron is one of the only "snake oils" (his words) that actually works as advertised. It was based on his advice that I tried some to clean my carbs a bit. The back of the bottle also claims that it cleans valves, heads and pistons. ANyway, from the many people I have asked, it will do no harm.
  6. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Most of the cleaners work quite well. They also clean the crap out of the fuel tanks and deposit it down stream. In the next day or so I will post pictures of what some of these additives can do to various FI parts. I am still researching what additives were used to create the problems I have found on the 550 I am currently servicing. This is going to become a enormous problem! Could someone PM me that can help with posting pictures?
    Dave
  7. dakharris
    dakharris Two Time F1 World Champ
    Jun 7, 2001
    29,441
    Sleepy Hollow
    Cavaliere Senzatesta
    Careful with additives. They can clog your cat. If you live in a smog test area, that could be expensive.
