News
Valve clearance check near-disaster
Discussion in 'Technical Q&A' started by 4Webers, Sep 18, 2014.
  1. 4Webers
    4Webers Formula Junior
    Nov 12, 2003
    276
    Texas
    Darrell
    #1 4Webers, Sep 18, 2014
    Ok, disaster is overly dramatic, but it was nearly an 'oh sh**'! While checking my valve clearances, the nut holding my feeler gauges together worked its way off and the nut and tiny washer went flying. Very Luckily, they hit the firewall and fell to the ground, but could have easily gone flying into the guts of the engine. I'm sure the pros and experienced diy'ers already know to do this, but be sure to put locktite on those suckers.
  3. Brewman
    Brewman Formula Junior
    Apr 3, 2012
    417
    NC Mountains @ Boone
    Joe
    Another option (what I do) is to remove the feelers I need from the cluster. Eliminates fighting with the whole cluster and the risk of dropping something into the engine.
    Brewman
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    10,665
    San Carlos, CA
    Mitchell Le
    You can't Loctite that. It is meant to be a little loose so you can fold the leaves and spread them out like a fan.
  5. Dave rocks
    Dave rocks F1 World Champ
    15,969
    Orchard Park, NY
    Dave Lelonek
    You can locktite it, as long as you don't tighten the nut so the leaves and still move.
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    12,005
    Dumpster Fire #31
    SMG
    what he said...
    I have to goto sizes looped with a small zip-tie, so it's like a key ring for the gauges. keeps them handy and no small hardware projectiles.
  8. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,332
    South of Philly
    Paul Nicholasen
    Seems prudent when the valve covers are off and all those nooks and crannies exposed, so stuff some rags in those holes, cause there's always something trying to slip down there. Same thing when the spark plugs are out. You don't want one of the many valve cover nuts or washers disappearing down into a cylinder.
  9. 4Webers
    Nov 12, 2003
    276
    Texas
    Darrell
    I had the holes stuffed, but with something that tiny you never know...
    Good ideas all - I like the idea of separating the most-used sizes from the rest of them.
