Valve cover cleaning? | FerrariChat
Discussion in '308/328' started by keithblackwell, Aug 7, 2007.
  1. keithblackwell
    keithblackwell Karting
    Jul 7, 2006
    87
    St. Louis
    Keith Blackwell
    has anybody found a good way to clean or polish the valve cover on a 308? Mine is not filthy be any means.... it just has a little "hazy" or oxidized look.... someone told me it looks like it had beed cleaned with too strong of a solvent, and etched it. It does not look bad, but I'd like to restore it. I'd like to avoid taking it off if possible. maybe a dremel and some sort of compound??
    any thoughts,tricks, or experience appreciated!!
  2. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
  3. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
  4. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
  5. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
  6. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
  7. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Maurice,,,
    Did you see (have) any small cracks in the front belt cover, after you bead blasted it?
    (I really like that polished look.)
    Edwardo
  8. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    How about a pic of the engine after all the polished parts are back in place???
  9. Hans
    Hans F1 Veteran
    Feb 17, 2006
    7,734
    Hilversum, Netherlands
    Hans Teijgeler
    Wow
    Nice!!!
  10. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    No cracks whatsoever but it showed how the casting isn't perfect.
    The polishing made it look much better and the guy only charged be $80 to do the 2 valve covers,2 belt covers and the rear engine brace.I was impressed with his work that I brought him a case of beer which he appreciated more than the cash :D
  11. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Dino I didn't take a proper picture of the engine altogether with all the bits on it before it went in.I did'nt have my camera the day we put it back in.I do have a pick though of the engine back in the car that was taken later.http://www.ferrarichat.com/forum/attachment.php?attachmentid=329724&d=1147766999
    Note that the ignition leads have been replace by red ones since the photo was taken
  12. rizzo308
    rizzo308 F1 Rookie
    2,780
    Perth, Australia
    riggio
    looks neat maurice, but how do you keep the shine longterm............ heaps of elbow grease..... or did you clearcoat them........
  13. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    Did the same polishing with my valve and belt covers. No need to blast before you polish, you can even use a polish set for the drill. You should treat scratches with fine sand paper before polishing. PITA is to remove the polish wax between the Ferrari letters. It is still shiny after one year, without clear coating.
    Regards
    Harry
  14. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    I tried a dremel on mine and it didn't help.
    I think i'd use 1200 grit sand paper and then a sisal wheel with the black compound first then follow with a cloth wheel and the white compound last
  15. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Funny you should ask ... I started cleaning my rear valve cover today. I've tried numerous pastes and lotions and potions and techniques in the past, but none of them were really satisfactory. Personally, I don't like the idea of media blasting either ... I'm no expert, but I imagine it changes the finish in a way that's non-original. Anyway, each unto his/her own, and I certainly do not want to offend anybody.
    FINALLY though, I seem to have found a combo of products and techniques that is most impressive:
    We've all heard of POR-15 ... right? Well, check out their full range of products. I think I invented a good 4-step process today:
    1. Do a quick pre-clean using POR's Marine Clean product cut with 5 parts of water. Just apply sparingly using a stiff tooth brush, work it in thoroughly, then wipe off using a damp cloth. Do a small section at a time.
    2. Then apply a tiny tiny amount of POR's Artisan Metal Polish. Again, apply very sparingly using a stiff tooth brush, and work it in thoroughly.
    3. Buff off the black residue that remains after step (2) using a soft cloth.
    4. Repeat step (1).
    I think you'll be impressed.
    For the belt covers just use a tiny bit of Artisan Metal Polish and a soft cloth. You don't need to make a huge multi-step performance out of this.
    I was thinking of patenting my 4 step process because it impressed me so much (!!!!!), but being the kind soul that I am I have decided to share the knowledge instead.
    Happy buffing,
    Simon.
  16. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    No clearcoat and no elbow grease at all.Just once in a while I use a rag with some methylated spirits or thinners and clean it but it doesn't get that dirty.Its been 18 months now and they still look the same
  17. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Simon if you see in the picture of when I had it bead blasted it looks like the original finish,but I dont think it would be easy to keep clean.The reason I had it polished so that it was easier to keep clean.The raised lettering is a bit of a pain so I just left it as was
  18. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Yes, I do agree, if you keep the original texture to the cam cover it's always going to be a PITA to keep it clean. However, yesterday's discovery taught me that a tooth brush and a 5:1 mixture of water:marine clean should make it reasonably easy to clean.
  19. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    #19 AHudson, Aug 9, 2007
    Man, all you guys are posting some super relevant "sticky worth" stuff. Quirky behavior on my part but I do my best to NEVER re-install a dirty part. Ever.
    Here's my engine before and after my 30k service. The tech was nice enough to deliver my parts to me for the cleaning, and I basically did Simple Green, lots of rinse, then Mothers aluminum polish, then Nevr Dull. Left it as is. Mine's nowhere near as nice as Maurice, but came out okay.
