Valve Cover Finish | FerrariChat
Valve Cover Finish
Discussion in '206/246' started by mechaniker, Oct 9, 2013.
  1. mechaniker
    mechaniker Formula Junior
    May 30, 2004
    608
    Germany
    Hi everyone,
    the Valve Covers on out Dino GTS sadly were polished. Does someone knows, how to restore the "out of mould" finish? Would be very happy!
  2. rosemeyer
    rosemeyer Karting
    Aug 13, 2010
    155
    The best thing in my experience to replicate the effect of an original aluminum casting is to use fine glass bead (NOT crushed glass) in a blasting cabinet. Walnut shells might work also but I have no experience with these. Just don't use harsher blasting media that more aggressively cut the surface as they don't give the right look.
    Start at a low pressure (say around 25-28psi) and see if you are satisfied. If you want a slightly rougher finish, gradually increase the pressure. You will get a smooth, even, semi-dull finish. After some time passes the surface of the aluminum will naturally corrode and get a bit duller, leaving you with a very authentic look.
    Best Regards,
    Paul
  3. mechaniker
    May 30, 2004
    608
    Germany
    Thanks!
    Than I now have to source a company to let me use their machines...
  4. snowsports1
    snowsports1 Formula Junior
    Jan 31, 2013
    918
    Brian
    Mine were nasty so I aluminium oxide blasted then glass bead blast but I blast at the 100 psi + and they come up original.
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Where are you located?
    Perhaps, fill out your profile
    I used a shop in the US which has a huge glass bead tumbler and that provides a very uniform finish with nice luster resulting
  6. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Can you share who you used?
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #7 synchro, Jul 23, 2015
  8. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,640
    Toronto / SoCal
    Rob C.
    That dark finish was not oxidation but Dow 7 Dichromate coating that was added to the covers during manufacture to protect them from oxidation. By removing the coating they will corrode.
  9. rbsloan11
    rbsloan11 Karting
    Apr 25, 2007
    119
    Carmel
    Rob
    Any internal part of the engine in contact with oil should not be glass beaded as the glass beads can become imbedded into the surface material, and dislodge under operating temperatures. The dislodged particles can cause damage to any bearing or machined surface, and premature engine wear/damage. If parts are glass beaded, then aggressive cleaning in hot soapy water must be done (solvents will not remove the particles), or internally sealed with paint such as Glyptal Red which is designed for these conditions.
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #10 synchro, Jul 24, 2015
    Great advice, thank you. Masked off and no direct contact with interior.
    Dow was long gone on these, this was oxidation, evidenced through pitting and multiple prior blasting wear on "Dino" raised letters.
  11. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,333
    Iain
    If the covers are from an E series then they are presumably aluminium not magnesium so would not have had the Dow coating when new.
