Valve Cover Gasket | FerrariChat
Valve Cover Gasket
Discussion in '360/430' started by nchhotu, Jul 25, 2022.
  1. nchhotu
    nchhotu Formula Junior
    316
    Roseville, Ca.
    Nick
    2007 F430 9,000 miles. Just purchased the car went in for new mounts and the tech reported oil on under pan small leak in valve cover gasket. Probably because car has very low miles. The tech said at some point will need to replace gasket and is labor intensive and require engine out. Does the engine have to come out? Getting different answers.
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    I’ve never heard of having to remove the engine to replace valve cover gaskets, that is ludicrous. I have heard that it’s a several hour job.
    Mine weep slightly on my 2009. Try snugging up the bolts a little. The required torque is low, so just tighten them a little and see if that helps.
    VAF84 and nchhotu like this.
  3. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    Engine out??? That isn't correct...find a new guy
    DOWORKFCAR, VAF84 and nchhotu like this.
  4. RedNeck
    RedNeck F1 World Champ
    12,286
    The CSA
    Me
    Uuuuhhhh...did they get the head gasket and valve cover gasket mixed up? I can't imagine it's insanely different than the 360 but it's a couple hour job at most.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,918
    Central NJ
    Dominick
    I think there is a mention of oil pan gasket ..i went back to reread the first message
  6. nchhotu
    316
    Roseville, Ca.
    Nick
    #6 nchhotu, Jul 25, 2022
    It's only leaking from timing cover gasket. Oil was found on the under tray. Tech said 50-60hrs of labor.
  7. nchhotu
    316
    Roseville, Ca.
    Nick
    Sorry, it's the timing cover gasket that's leaking.
  8. nchhotu
    316
    Roseville, Ca.
    Nick
    I got it totally fixed up buddy. It's the timing cover gasket that's leaking.
  9. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    I don’t see anywhere near 50-60 hours for the timing cover gasket either!
    nchhotu likes this.
  10. F-Serge
    F-Serge Formula 3
    Aug 3, 2004
    1,945
    UAE
    Serge
    I replaced a timing cover gasket on my 360 a few years back, definitely no engine out and nowhere near 50 hours of labour. I think it took me half a day, and it was on a Spider. Coupe should be much easier with no roof getting in the way
    VAF84 likes this.
  11. Kent Adams
    Kent Adams F1 Rookie
    3,261
    Find a new tech. That guy is a scammer.
  12. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,556
    San Carlos, CA
    Mitchell Le
    Gentlemen, the 430 has timing chains and the 360 has timing belts. The two engines are vastly different in the timing area. There is no timing cover gasket on the 360 while there is a very complex timing cover gasket on the front of the 430 engine. Its replacement would absolutely require the engine to be out of the car and is a big job. Unless there are other reasons to remove the engine, it's probably safe to leave that alone until the need absolutely arises.
    RedNeck, Sj_engr and RedTaxi like this.
  13. yelcab
    Nov 29, 2001
    13,556
    San Carlos, CA
    Mitchell Le
    What gasket did you replace with the engine in? number 21? If so, that is a job well done.
  14. AandSC
    AandSC Formula Junior
    957
    Jax, FL
    Allen
    Post up pics of the leak. There’s a good chance it’s your power steering hose where it connects to the power steering pump. Easy to confuse with a timing chain cover leak.
    one4torque and nchhotu like this.
  15. RedNeck
    12,286
    The CSA
    Me
    Or the reservoir itself...mine was split at the seam when I got it, a complete mess.
    one4torque and AandSC like this.
  16. Tony H
    Tony H Karting
    Sep 3, 2013
    156
    #16 Tony H, Jul 27, 2022
    I fixed the oil leak on my Maserati Spyder which has the same front setup as a 430. Part 21 is not really a gasket but more an o ring so it dries, hardens and leaks. It's made in a way you can't tighten it. Now I realise this is the Ferrari site and you may wish to spend all the money it takes to replace the gasket, but what I did is solvent clean the joint area around the cover and then applid an external film of silicone sealant along the joint. Oil leak stopped for 7 years now. The cam cover gaskets should be easy to get at, but remember to use silicone sealant on the o ring gasket or you'll quickly get leaks. Again no leak on my cam covers for 7 years.
  17. F-Serge
    F-Serge Formula 3
    Aug 3, 2004
    1,945
    UAE
    Serge
    I should've double-checked my covers before posting - I replaced valve cover gasket, not timing cover
  18. yelcab
    Nov 29, 2001
    13,556
    San Carlos, CA
    Mitchell Le
    There is no room in the Ferrari mid-engine location to remove the front cover. The Maserati is very different because it's a front engine car.
  19. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    The front chest? You don't need to take the engine out. 10-12 hours at my workshop depending on how the job goes.
    tbakowsky, nchhotu and LorenzoR like this.
  20. Tony H
    Tony H Karting
    Sep 3, 2013
    156
    Never did remove front cover.
  21. nchhotu
    316
    Roseville, Ca.
    Nick
    10-12 hrs to replace timing cover gasket? Please provide insight.
  22. WashingtonFerrari61
    WashingtonFerrari61 Formula Junior
    Jun 26, 2022
    476
    Northern, VA
    Is this an actual Ferrari dealership telling you this? This is a complete lie and I would never go back and I highly question if the valve cover gasket is even leaking. At most it’s probably just at the sweating stage.
  23. nchhotu
    316
    Roseville, Ca.
    Nick
    Sorry not valve cover gasket but timing valve gasket is suspected of leaking.
  24. nchhotu
    316
    Roseville, Ca.
    Nick
    Will definitely come by and meet you when I am in UK.
  25. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Sorry for the tardy reply - I've been busy in the real world.
    Drain the fluids. Seats out and hatch off. Frame out and valve covers off. Move the AC compressor out of the way. The toughest part is undoing the crank pulley bolt - you will need to lock the flywheel and use a big bar. Once I had to remove the exhaust system and undo the engine mounts to tilt the drivetrain so I could get an impact gun on the bolt. Once the pulley is off then the front cover unbolts. It'll be tough to pull it off the water pump - you may need a slide hammer.
    It's not a challenging job, just time consuming.
    RedTaxi likes this.
