Valve cover seal and gasket replacement | FerrariChat
Discussion in '308/328' started by D.J., Apr 10, 2012.
  1. D.J.
    D.J. Karting
    Mar 15, 2008
    60
    East Norriton, Pa
    Douglas J Schrack
    Gentlemen
    The front and rear valve cover seal or gaskets on my 1988.5 328GTS are leaking oil.
    I am getting conflicting advice.., is this an engine out procedure or can this be done with the engine in. My understanding is the rear valve cover is the problem. Any advice would be most appreciated.
    Doug
  2. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Doug,
    Whom ever is giving you advice to remove the engine should be shot...They clearly don't have a clue. The easiest way would be to remove the rear deck lid. This will give you all the access you need to replace the gaskets and seals. If a major service hasn't been done in a while, this is the perfect time.
    David
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    Defintly not "engine out". Might not just be the valve covers though - there are 3 camshaft oil seals on each bank - two at the front & one at the distributor & then there is a gasket on the end plate at the front bank & the end plate with the breather/oil drain on the rear.
    Either way, all of it can be done with the engine in. If they are doing the camshaft oil seals then the cams have to come out & it makes sense to check the valve clearances at the same time.
    Making the cam covers seal is not hard but it does need to be done with some care & attention to areas where gaskets & seals meet.
  4. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    Basically the same as a 308 I guess. I did mine in place in the past. If the gear side of the cam has to be done you will have to remove the belts which is more work than just the cover gaskets.
    Neeeon likes this.
  5. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    +1
    He's the guy that would know best.
  6. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    +1 :) Some out there sure tell some wild tales....
  7. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,846
    Atlanta
    John!
    #7 Ferraripilot, Apr 11, 2012
    Clean the gasket area to as surgically clean and dry as possible after scraping/removing the old gaskets, then use this on both sides of the new gasket to seal deal. Won't leak, ever.
  8. Constance
    Constance Karting
    Apr 10, 2009
    213
    Kembs - France
    Constance
    I can show you how to replace the seals but you have to learn french
    http://www.forum-auto.com/marques/ferrari/sujet3922.htm
    Some tips;
    - Use high quality gaskets and not cheap paper gaskets (sponges) who favorize the oil seeping
    - Clean all surfaces properly, take care do not scratch the sealing surfaces, use an appropriate tools
    - Install the cover gaskets dry
    - Lubricate with engine oil the lipseals and the o-rings before installation. Do not use silicone compound on the O-rings !
    - Use a drop of Loctite 518 to make the jonction between the cover gaskets and the o-ring and between the cover gaskets and the gaskets on the blaking cover gasket (Inlet camshaft) and the ignition lipseal support gasket.
    - The lipseals on the ignition side have two lips (Post production Service Bulletin 10-18), take care to not bend the inner lip. To facilitate the installation use a piece of milard or similar to guide the lips during installation.
    - To prevent leaks, do not overtorque the cover nuts, use a torque wrench
    And finally, the job can be done without removing the engine and without removing the engine bonnet.
    Good luck....
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    I am partial to Hylomar, for years now.
  10. Constance
    Constance Karting
    Apr 10, 2009
    213
    Kembs - France
    Constance
    Good luck for remove the covers at the next valve clearance check
    If the contact surfaces of the covers are perfectly flat and clean, with the original gaskets and the propre torque it will not leaking.
  11. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I am confused here folks. Are all practices equally valid?
  12. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    No...
  13. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Would you care to elaborate Dave?
  14. Ferraripilot
    May 10, 2006
    17,846
    Atlanta
    John!
    David, what's your voodoo. Everyone seems to have one lol.
    Personally, I don't like Hylomar in these applications. The only thing I ever used hylomar on was sealing cylinder liner o-rings to Lotus 907 blocks which was factory recommended.
  15. Ferraripilot
    May 10, 2006
    17,846
    Atlanta
    John!
    I just removed mine to retorque the heads after the engine broke in. Was easy, but it's definitely easier with other sealants. I just don't think they work as well.
  16. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    #16 stevel48, Apr 11, 2012
    Personaly, I follow David's advice beofore I try anything mentioned on Fchat. He has too many years of experience to ignore or question really. He's never steered me wrong.
    From what I have read over the years here they should be installed dry.
    http://www.ferrarichat.com/forum/showthread.php?t=298809
  17. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Well, like the oil argument, everyone has an opinion...most of which are either dated or incorrect. The same holds true here on the valve covers. The QV cars have there own unique sealing issues, as the o-ring holders float. I'm of the school that less is more...and for sealing to actually occur, the surfaces need to be spotless. Sometimes that actually means removing those pesky valve cover studs to get the last 25 years of excess silicone and crap removed. Once clean, the only sealant applied is at the ends...and a tiny amount it is. This is how the factory did it. There are a few exceptions, particularly if some yahoo scraped the living sheet out of the valve cover or head sealing surfaces. Then a ultralight skim coat may, may be needed.
    For sealants in this particular area, there are several great choices. Sorry gents, old habits die hard and Hylomar of any variety just isn't on my list. I use either ThreeBond, UltraGray or HondaBond. Currently, I'm switching over to the ThreeBond product, as John has spoken very highly of it in our conversations. He is knowledgeable and I trust his judgement. In many respects, this may be a better product than the others, other than perhaps its high temperature limit, which is a bit lower than the others.
    I have no voodoo. No secret tricks, just tried and proven or disproved methodologies. Many, many hundreds of cars over many years with delighted customers.Every once in a great while, we get a leaker. The problem is always "operator error"; me!
    That's my story and I'm sticking to it... :D
  18. yelcab
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    let me elaborate:
    I smear on the valve cover gaskets a very thin layer of Hylomar (they have recently changed the composition) on almost all gaskets I install for all cars. They have never leaked. And it is much better than silicon RTV. Hylomar stays wet, seals well, and does not plug up oil holes.
    For the circular oil seals, I install them dry on the outside, wet with oil on the inside, taking care not to pinch of flip the oil sealing lips.
    Where the round o-rings meet the paper valve cover gaskets, I use a pick to put on a very small amount of RTV so that there is no excess squeezed out and fallen down into any oil galley holes.
    That is how I do the valve covers and seals. There may be other ways that are equally correct, but this is my way.
  19. Constance
    Constance Karting
    Apr 10, 2009
    213
    Kembs - France
    Constance
    #19 Constance, Apr 11, 2012
    Guys, you should see the problem from another view....
    The covers are mounted on the cylinderheads and machined together. Therefore the clearance is so tight that you dont need an additional sealant to the gaskets, they are installed dry.
    Pls keep in mind that each cylinderheard has his own cover !
    Also on the O-rings, an oil film on the O-ring and in the grooves is suffiscent to make a proper assembling
    The way how the guy has installed the O-ring as showned on the bellow phtograph is to be denied !
  20. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Thanks you all for the words of wisdom.
  21. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Dave, so I take it that, like Constance, you are installing the valve cover gaskets "dry." I learned to do a lot of these jobs a long time ago, and old habits die hard, I guess. I've always used Hylomar, as most of my work was on old Jaguars, and the Jaguar shop manuals call for the use of Hylomar as a sealant on gaskets. So I carried that over to the Ferraris, and it's always worked well for me. I apply a very thin layer on both sides of the gaskets, and install, and torque to WSM recommendation, and no leaks.
    But what you say does make sense, both you and Constance. Next time, I might try it your way, and go with the dry gaskets, even though it goes against what I've always done.
    And by the way, what's the objection to Hylomar? I have no great love for the stuff, other than it's what I've always used. But I'm open to change, especially since it's hard to find these days.
  22. Ferraripilot
    May 10, 2006
    17,846
    Atlanta
    John!
    The real trick is not sealing valve cover gaskets so they don't leak, but sealing oil pan gaskets so they don't leak. Those silly things are monsters and personally I can't get them to not leak without pulling and sealing each and every stud and then using Threebond 1194 on the gasket sides to a surgically clean surface, and then tightening each holding nut according to a criss cross sequence to 7-8lbs torque. The valve cover gaskets don't seem to be as sensitive when it comes to sealants.
    If hylomar works for ya, use it. I don't have much experience with it other than the Lotus cylinder liner application which Lotus recommends. Must be a British thing.....
  23. Constance
    Constance Karting
    Apr 10, 2009
    213
    Kembs - France
    Constance
    #23 Constance, Apr 11, 2012
    Again, you will never get a leaking oil pan access panel if:
    - The original gaskets are used (Dry installed),
    - The access panels are perfectly flat and clean (Not bend due to overtorque)
    - Soft aluminium washers and domenuts are used and properly torqued
  24. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    From my very old Lotus and Hewland transaxle days, it seemed that if Hylomar was used, a leak was guaranteed! Then again, it was a Lotus...LOL!
  25. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    I agree with your thinking, but the likelihood of this being true is almost zero. Not zero, but close. I like your optimism, though...
