Valve gasket replacement | FerrariChat
Discussion in '360/430' started by Mardi Gras, Feb 3, 2016.
  1. Mardi Gras
    Mardi Gras Rookie
    Dec 25, 2009
    38
    #1 Mardi Gras, Feb 3, 2016
    Would someone be kind enough to inform me if changing the valve cover gaskets on a 360 is a fairly easy procedure. I also would like to know if they require any type of sealant. Thank You.
  2. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Matthew & Kristen V.
    From what I was told about a 430, the job is a pain in the neck and mostly just lots of labor. The parts aren't too bad. Not sure if 360 is easier.
  3. Mardi Gras
    Mardi Gras Rookie
    Dec 25, 2009
    38
    Thank you so much-it seems that I will have to leave it to the dealer. (I also have a pug, I love the little guy).
  4. stinkpot
    stinkpot Rookie
    May 14, 2005
    7
    I did it myself a couple years ago - wasn't bad at all. If I remember correctly I used a tiny bit of Curil-T on the gasket.
  5. jackgt
    jackgt Formula Junior
    Jan 27, 2015
    574
    california
    Jack
    It all depends on your ability as for how hard it is. Worse part is leaning over the rear fenders. I made a platform, kind of like an ironing board to get access from the rear of the car.
  6. Mardi Gras
    Mardi Gras Rookie
    Dec 25, 2009
    38
    Thanks again-things are looking up, if the worst part is leaning over the fenders, this is something I can do. I have done several procedures on my 360 that required removal of both bumpers and the bottom tray. Thank you for all of the help. It affords me huge reduction in cost in doing this myself.
  7. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Is your car a convertible or coupe? I once heard the spiders are harder to do this job on. I bet the parts are under 100 but a serious hassle of moving stuff to do it.
  8. Mardi Gras
    Mardi Gras Rookie
    Dec 25, 2009
    38
