I recommend JB Weld, it never leaks, and the next person that gets to remove the covers is in for a surprise! Seriously, if you buy the good green gaskets with the red rubber embossed on them, all you need is a little 3 bond silicone sealer at the ends of the gaskets where they meet the covers and o-rings. Anything more is overkill and just causes the next person in there the frustration of cleaning off the old bonded on sealer/gasket material. Brian Brown Patrick Ottis Co,
Brian, I got my gaskets from Ferrari but they are just green the only part that has the red seal on it is for the front left small ropund camshaft cover. Several Ferrari techs said they put the gaskets on dry. My mating surfaces are pretty smooth. Have you ever used the hylomar? What do you think of the slight coating of grease on the head side to aid removal? Thanks Rob Image Unavailable, Please Login
I put my gaskets on dry, but they have the red sealing bead on them. We get out gaskets from T Rutlands. you could call them to see if they have the type with the red seal for your model car. I really wouldn't worry about it too much, if the surfaces are flat, and you have good material gaskets (Green), then I would just put them on dry except for a little dab of silicone sealer on the ends where the covers meet and the o-rings meet. You can use grease or hylomar if you like to take things apart all the time, but they don't mate well with the silicone on the ends. Ferrari put them on dry at the factory, I think you can do the same. Brian Brown Patrick Ottis Co.
Ditto on the Locktite 518. I have used it with great sucess. I haven't had a leak with it yet. Easy to pull stuff apart later. I am told it can't handle the higher temperatures that the Hylomar can though.
I would if I could get away with it... <grin> Funny when you said that it made me think of going to Nurburgring with my brother when the early Porsche turbos were being fielded. They had such a hard time keeping the head gaskets sealed on the race cars, they were just welding the jugs to the heads. Made motor assembly a b**ch but they stopped blowing head gaskets! Thanks Brian, had I bought that type I would certainly think they would be sufficient. Mine were the green gaskets but no silicone (and I thought they were top of the line at the time). In which case I'd support your method. But just a plain gasket... its going to get a smear. Too many years prepping race cars to go dry and chance a leak. I hate leaks. (he says as he leaves to go work on the Cortina...) Rick
