Valve Gearing (timing) | FerrariChat
Discussion in '206/246' started by Erbe, Apr 9, 2020.
  1. Erbe
    Erbe Rookie
    Apr 9, 2020
    2
    Eduardo Bergamini Erbe
    Hi, i'm trying to time the camshafts of my Dino 246 GT 1973 engine but I'm confused with the camshaft marks. Thera are two marks at the camshaft "head", where the driven gear is fixed, distanced 180 degres from each other. One with one dot and the other with two dots.
    At the whorkshop manual that I have it only relates to a "mark" at the camshaft, it does not says which one.
    Can anybody help on that?
    Thanks!
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,191
    Norfolk - UK
    Tony
    On EACH camshaft there is only one mark and this must align up exactly with the marks on the camshaft end caps when the engine is at TDC (firing). A small dab of red paint helps to highlight them. Although i have found the plate near the crankshaft to be accurate it is worth checking the engine is at TDC via the spark plug hole and a dial gauge.
    Tony
  3. daviekj
    daviekj Formula Junior
    484
  4. Erbe
    Erbe Rookie
    Apr 9, 2020
    2
    Thank you very much guys! I end up finding out that the camshafts that I have are not original... and that explains all.
  5. 74Fiats
    74Fiats Rookie
    Sep 20, 2020
    37
    Sarasota, FL
    John Mishriky
    Hello, I am running into the exact same issue as Erbe did ... my camshafts have 1 and 2 dots, not a single mark as described in the manual. Can anyone assist with the proper positioning of these apparently aftermarket cams? I believe the "1 dot" mark is used as the mark for the intake cam, and the "2 dots" mark is used for the exhaust cam, but I would rather be certain than speculate! Thanks in advance on any knowledge of these cams.
  6. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,191
    Norfolk - UK
    Tony
    Photo?
    There shouldnt be any "dots" see post 3 for the slot mark on the cam and corresponding slot on the cam end cap, when aligned all four cams marks should be aligned exactly.
    If you are unsure that these marks are accurate then you will need to degree time the cams using a degree wheel.
    A search on this forum will help as its a lengthy process that needs accuracy to get right.
    Tony
    swift53 likes this.
  7. 74Fiats
    74Fiats Rookie
    Sep 20, 2020
    37
    Sarasota, FL
    John Mishriky
    Please see photos with dot markings highlighted. The third photo shows the passenger-side cams in approximately (what I believe to be) the correct positions, with "1-dot" intake marking aligned and "2-dot" exhaust marking aligned.
    I found the same or similar camshafts at Dino Parts ... you can see the dot markings in their photos as well:
    https://www.dinoparts.com/de/teile-zubehoer/fiat/dino-coupe-spider-2400/motor/zylinderkopf/nockenwellen-mehr/17666/nockenwellen-standard-fiat-dino-2400
    My question is: With the intake aligned to 1-dot mark, and the exhaust aligned to 2-dot, do the positions of the cam lobes look correct?
    Thank you, John
  8. Rifledriver
    36,821
    Likely made by cam grinder during a repair of the cams. Ferrari did not use dots.
    I am certainly not a 246 authority but I do not recognize the hex shapes behind the front cam bearing. Is it possible these are replacements from an aftermarket supplier?
    Ferraripilot likes this.
  9. pshoejberg
    pshoejberg Formula 3
    1,796
    Denmark
    Peter H
    TonyL and daviekj like this.
  10. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,191
    Norfolk - UK
    Tony
    Your cam bearings look worn / scuffed so you need to check them and cam lobes are in spec before you go any further.
    Have these been in this engine before rebuild, is this 246 or Fiat Dino 2.4?
    Cams should be marked A Intake & S Exhaust
    If so and these are the only marks you have then i would suggest you go with these as the reference marks....FOR NOW.
    With crank pulley set to 3-4 on the timing mark, No 3 cylinder should be in the firing phase. I would verify all timing events are as spec using a degree wheel after initial set up.
    The 246 manual can be downloaded here, it gives useful data on spec's.
    http://www.dinospider.com/manuals.html
    tony
    pshoejberg and daviekj like this.
  11. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,191
    Norfolk - UK
    Tony
    Peter, can you recall if the timing reference marks were accurate? I did mine many years ago and they were spot on.
  12. daviekj
    484
    2009 visual on accuracy for the set up on my car..
    I see some variation on mark alignment but cant recall what this was in degrees. Kevin
    swift53 and TonyL like this.
  13. racerboy9
    racerboy9 F1 Rookie
    2,634
    That looks pretty good for a production street engine.
  14. 74Fiats
    74Fiats Rookie
    Sep 20, 2020
    37
    Sarasota, FL
    John Mishriky
    Thank you all for your valuable input. I'll review and make sure I'm clear before proceeding. I've also shot a note out to Dino Parts since they appear to sell these cams with the dots, hoping they may be able to shed light on the markings. For reference, this is for a FIAT Dino 2.4.
  15. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,191
    Norfolk - UK
    Tony
    Every manual I have seen quotes these reference marks once all aligned as the final assembly. Given the width of the thick cam cap mark and camshaft line, a small tolerance is OK.
  16. pshoejberg
    1,796
    Denmark
    Peter H
    I’ve set timing on my 246, 308 and 512 using degree wheel each time and always found the marks to be rather close. Most likely close enough to just use the marks for upcoming belt change. But I would never install a new set of cams going by marks only.
    Best, Peter
  17. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,191
    Norfolk - UK
    Tony
    Totally agree Peter especially aftermarket cams from a unknown source. I have fitted new cams from superformance on 3 dino engines, degree timed them and all were fine and spot on. There will be one that doesnt though!
    swift53, daviekj and pshoejberg like this.
  18. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,778
    Atlanta
    John!
    The hex right there can only be one of two places, Newman cams or Cat Cams, both add that to almost all of their cams. I would think those are Cat Cams though as they've made a great number of Dino cams.
    74Fiats likes this.
  19. swift53
    swift53 F1 Veteran
    BANNED Rossa Subscribed
    Nov 17, 2007
    8,085
    E.S.
    Alberto
    I have a FIAT Dino 206 motor, that I'm rebuilding.
    My cams, stock, have grooved lines on the toothed pulleys, that when taken apart, lined up perfectly with the ft. cam bearing caps. Just as in Davie's photo.
    Regards, Alberto
  20. 74Fiats
    74Fiats Rookie
    Sep 20, 2020
    37
    Sarasota, FL
    John Mishriky
    Thank you Ferraripilot ... you nailed it. I contacted Cat Camshafts and they confirmed that these are indeed their cams. For anyone else running into this in the future, here is their response:
    This is sport profile 1700105 as found on our website. The dots correspond to the location of the line on the standard camshafts. Use the single dot for intake camshafts, and the two dot for aligning the exhaust camshafts.
    Mystery solved, thanks all for your input. John
    daviekj and Ferraripilot like this.
  21. Ferraripilot
    May 10, 2006
    17,778
    Atlanta
    John!
    Very glad you nailed that down! Those are fantastic cams, used them in several 308 engines. They operate as any stock setup would, but with a noticeable increase in power all over the curve. I recall an otherwise stock 308 with 10.5:1 compression and these cams made around 225hp at the wheels after jetting changes, so 265hp or so at the flywheel. A stock 76-77 in great shape makes maybe 195hp at the wheels for comparison.
    INTMD8 likes this.
  22. swift53
    swift53 F1 Veteran
    Nov 17, 2007
    8,085
    E.S.
    Alberto
    I tried 'navigating' cat Cams, but cannot manage. Please help!
    Thank you.
    Regards,
    Alberto
