Valve Guides on 355 ?? | FerrariChat
Discussion in 'Technical Q&A' started by marinelo, Apr 4, 2006.
  1. marinelo
    marinelo Formula Junior
    Jan 18, 2004
    309
    Toronto
    Rob
    Looking for a 355 and I understand that 96 & early 97 models had valve guide issues. Has anyone experienced this.
  2. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,685
    LA & OKC
    Kevin
    People have experienced it on later cars also, it's just been more likely to happen on the earlier cars. Do a search for it on here, I know a few f-chat members have gone through this painful repair.
  3. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    THe valve guide issue was caused the the use of bronze valve guides instead of sintered steel valve guides.
    Therefore all 355's from 1995 to mid 1998 have this potential problem, without exception.
    In mid 1998, however Ferrari changed the guides material from bronze to sintered steel and the problem was solved.
    If the issue is a concern to you then either you should purchase an earlier car that had the guides replaced (but Ferrari was known to replace the bronze guides with replacement bronze guides to 'use up their stock'....so no guarantee here that the problem was actually cured)or go for the 1999 model.
    Me, I'm not concerned. If the problem was going to occur, it usually showed up early in the cars life.....not 10 or so years later.
  4. Watry
    Watry Karting
    Aug 8, 2005
    78
    Berkeley, CA
    Andrew Watry
    Norman Racing here in Berkeley did a million valve jobs for the Ferrari dealers and local Ferrari shops on these heads over the past few years. Fun for the machinist; 40 valves! Early jobs were under warranty. Not sure which replacement guides they used. I haven't seen so many of those heads come through lately.
    Andrew Watry
  5. 4retr
    4retr Formula Junior
    Nov 21, 2004
    384
    Southern California
    David B.
    My 95 Spider needed the valve guide work done during the 2nd major (49K) last year.
    The work was an additional $6k +/- (Not to bad if you average it over 10 years).
  6. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    that sounds cheap! what was done for that, exactly?
  7. TopElement
    TopElement Formula 3
    May 14, 2005
    1,540
    OC & Vegas
    A Montoya
    The first Spider was a 99 and didn't have any of the known 355 issues. The current car is a 96 model, and needed a $20k engine rebuild to fix valve guide and cracked manifold problems.
    Runs better than new though, and shouldn't need to be touched for a long time.
  8. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    I have a car that was built in Dec 97 and I had my valve guides replaced at 22k. If I were looking, I would look for a car that has already had the valve guides replaced and choose an earlier car so I wouldn't pay a premium on the last year 355s were made.
  9. tstafford
    tstafford Formula Junior
    Mar 4, 2006
    754
    Nashville
    Tim
    Excuse my ignorance, but what are the symptoms of the value guide issue when it shows up? And what is a typical repair cost?
    Thanks.
  10. pino
    pino Karting
    Nov 1, 2003
    208
    South Central PA
    rough idle, sometimes accompanied by a check engine light (incomplete combustion)
  11. Llenroc
    Llenroc F1 Veteran
    5,555
    Colorado
    Vern
    What was said above plus excessive oil consumption. If you watch your oil level you should be able know of the problem before there is other damage to the rest of the engine. Regards, Vern
  12. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    In addition to above a blue puff of smoke on initial start up only.
  13. Llenroc
    Llenroc F1 Veteran
    5,555
    Colorado
    Vern
    I don't know that you will always see the puff of smoke in the initial stages because the flow through the guides is slight but, you still could catch it early by watching the consumption/level closely. I think by the time you are seeing the puff you are well into bad guides. Just my thoughts. Regards, Vern
  14. Ricard
    Ricard Formula Junior
    Jan 23, 2004
    867
    Donington Park
    Richard C
    OK, $000,000 question, given the "precise" :)D) nature of measuring the oil level in a 355, what consumption level would be considered "normal" and what level "my valve guides are going" ...?
    I used to have an Alfa 156 which sang along consuming 1.0L per 1000m no problems. Next one (identical model) consumed none, go figure..!
  15. Llenroc
    Llenroc F1 Veteran
    5,555
    Colorado
    Vern
    Both my 348 and my 355 didn't/don't use any oil between changes (2500 mi. changed once a year whether needed or not)under normal use. If I check the oil right after shut down I get the same reading all the time, the oil drains back into the sump the longer you wait so your reading will be lower the longer you wait to check it. I would say if the engine consumes a quart or so in 500-700 miles you might want to check into why. Regards, Vern
    P.S. on the other hand my 308s were a different story about a quart every 1000 mi.(they were in great mech cond.) and the harder you ran them the more they used. Different technology.
  16. Aircon
    100,524
    Peter
    same here with my 355. quite a shock to the system not to consume oil!
  17. Ricard
    Jan 23, 2004
    867
    Donington Park
    Richard C
    Sounds sensible, thanks for the info, think I maybe put 0.5L in after 1800 miles or so.
  18. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    In 2500 klm I have also had no oil consumption but all manufactures specify a certain amount of 'normal' consumption.
    Does anyone know what Ferrari specifies?
  19. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    That sounds about right from what I've known about mine and other 355s. I've never known a 355 that doesn't use up oil in 2500 miles, but then again, I might have only known bad 355s...
  20. f355spider
    f355spider F1 World Champ
    18,055
    RTFM! Every Ferrari I have owned said the same thing (308, 328, 355) that it is considered normal to consume up to 2 liters per 600miles! "according to driving and other conditions"
  21. Llenroc
    Llenroc F1 Veteran
    5,555
    Colorado
    Vern
    Sorry you guys hate to argue with ya but, my 348 and my 355 didn't/don't use any noticable oil between changes. My 308s did however, not as much as the owners manuals said was normal.Maybe a quart in 1000 miles IIRC. I think most of the problem with cars that do use oil, older newer whatever, is quaility/condition of valve guides and their seals. Taking in cosideration the rings are in good shape.
    On a side note I have owned Audis and BMWs with 150,000+ miles on them with no oil consumption in 5000 mile OCIs. Regards, Vern
