Valve guides | FerrariChat
Valve guides
Discussion in '348/355' started by indyheel1989, Aug 4, 2013.
  1. indyheel1989
    indyheel1989 Rookie
    Aug 3, 2013
    1
    Hello All, I'm in the market for a 355 and I've received conflicting information on the valve guide issue. I was under the impression that the 1999 model year cars do not have this issue, but was recently told that all 355s potentially have this weakness and I'm not any safer with the later model years. Is that accurate? Thank you!
  2. XLR8R
    XLR8R Karting
    Feb 14, 2013
    171
    Michigan
    Matt
    There's likely not a short answer to this question. Tons of threads on this topic that you can sift through and form your own opinion. I've seen many people post that it's only the early cars, but I've also seen owners of later cars post that they've had issues with guides so my own view is that it isn't limited to just the early cars. Here's a link that I found to be the most helpful when I was looking into this issue in the past, but as you can see from the thread opinions vary....
    http://www.ferrarichat.com/forum/ferrari-discussion-not-model-specific/132778-95-f355-valve-guides-fact-vs-fiction.html
  3. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    From all the posts I have read, this issue continued until the end of the run. Supposedly one car had the bronze guides on one side of the motor and the sintered steel on the other. I think Ferrari started changing the guides in the later cars but there seems to be inconsistency on that.
  4. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    This issue / topic comes up all the time and people run from potentially awesome cars based on the fear of bad guides. But, people don't seem to talk about the effect of bad guides. My understanding is the car will burn a bit more oil. If that's true, it's not a death sentence...
  5. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    I've heard of a Fiorano with bronze guides. You should be 'safer' but not immune with a '99 IMO.
    That said I own a '97.......when/if the guides become a problem I will fix them.
  6. wrk2ownCT
    wrk2ownCT Karting
    Nov 30, 2012
    134
    Madison CT
    Chris
    A compression & leakdown test is the gold standard of initial diagnosis.. If you're close to an engine out service (30k, etc).. AND you have the budget in my opinion just go for it. I forked over the cash to have the valve guides done, and refinished all the valves.. From this point on, i KNOW my car is sorted fully with no opportunity for guides going and causing a precipiteous event of other damage to the engine.. It runs absolutely fantastic, and i haven't looked back.
    If at least 3 of the 8 banks are looking crappy on that test, and youre gonna keep the car and actually drive (like i do) figure 5k in machine work. I used John Tirrell in Mass and have nothing but fantastic things to say about his shop.
    Best of luck
  7. davey_jones
    davey_jones Formula Junior
    Sep 28, 2002
    781
    wherever it's sunny
    Dave
    ..Just assume it's possible with every year.
  8. ShineKen
    ShineKen Two Time F1 World Champ
    20,036
    Southern California
    Nostradamus
    Million dollar question.... what's the best valve guide (brand and material) for the 355?
  9. gf1red
    gf1red Formula Junior
    Mar 5, 2006
    413
    Staten Island N.Y.
    Mike G.
    I had steel guides for a 360 put in my 98.
  10. phrogs
    phrogs F1 Veteran
    7,358
    Kzoo Michigan
    How about a part number
  11. mwhitesell
    mwhitesell Formula 3
    Sep 17, 2006
    1,083
    Atlanta
    Mark
    Yes. If you buy a 355 your valve guides will go bad the first time you drive it, right when the cam belts fail and your headers blow leaving a molten heap in the road.....
    Don't believe everything you read from someone who's brothers friends cousin once had one that blew up.
  12. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    Yes, I was killed by one! Now I'm a zombie. Penniless..
  13. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    Johnny, another member had his guides redone in sintered steel. I believe he purchased them from Ferrparts.
    Intake # 176437.
    Exhaust# 176438.
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    My car needed valve guides and my sneakers came untied, truth :)
  15. gus355
    gus355 Formula Junior
    Aug 3, 2011
    569
    B.C. and WA
    Wow.
    Cool story bro.
