Valve noise - amount of oil? | FerrariChat
Discussion in '308/328' started by BEisler, May 5, 2007.
  1. BEisler
    BEisler Formula Junior
    Aug 16, 2006
    374
    Carmel, IN
    I have an 85 308 GTS QV Euro and have done a search on this site for help but haven't found something identical to my issue/question.
    Bill D created a thread back in 2005 that described a similar problem - apparent valve noise (clattering in my case) after the engine gets hot - sounds fine before heating up. Valve adjustment and oil viscosity recommendations were made. I am using 20W50 oil which I think should not thin out too much when heated up, but could be wrong.
    The other question I have is that when I changed the oil for the first time myself back a few weeks ago, I saw that the manual called for over 10 quarts of oil. The dealer had previously put in 8 according to a receipt I had. When I put 8 quarts in it, she read full. I didn't change the filter when I did the oil as the filter had very low usage on it at that point.
    I guess my question is, could I be low on oil (8 quarts vs 10) that could be causing the clattering? Should I put in what is called for even though the dipstick reads just about at max? I am assuming the 20W50 is the correct weight oil.
    Any othe thoughts would be appreciated.
  2. rizzo308
    rizzo308 F1 Rookie
    BANNED Silver Subscribed
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    to get a true reading always check oil 15 min after shutdown
  3. BEisler
    Aug 16, 2006
    374
    Carmel, IN
    Rizzo308,
    Never heard that before. . . . I always check cold just before starting up. I will do that!
  4. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Your being too anal about the oil. If your dip stick reads full, the motor is fully filled. The add line is about two quarts down IIRC, but thats for cornering. You could probably be four quarts down and not see any realistic trouble. If your reading proper oil pressure that is the real key. It really sounds like an excessive valve clearance issue, but if you checked them then maybe they were simply at the high clearance limit? Plus the fact you have 16 valves, it could possibly get rather clicky if they were out in the .25 and .30 mm range instead of the tighter end of the spec. More oil above the dip stick line is not going to alleviate your trouble.
    OTOH, get a stethoscope and listen around on the motor. The transfer gears can make noise, as can failing cam drive gear bearings. If its only the valves lightly ticking I wouldnt worry. Just check them accurately next time.
  5. Glassman
    Glassman F1 World Champ
    On my car cold doesn't even register on the stick. The 15 minute rule is correct. Don't take me wrong but read the owners manual.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    What kind of car?
  7. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,067
    Kansas
    Sean F
    On a 308 cold should be way past the tick mark.
  8. Glassman
    83 308 GTS
