Valve seals - anyone has done any measurement for the valve seals ? | FerrariChat
Discussion in 'Boxers/TR/M' started by leslie_choo, Apr 25, 2016.
  1. leslie_choo
    leslie_choo Formula Junior
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Hi do you know the size for testarossa valve seals ? Or any compatible valve seals from other car that could fit testarossa ? Thanks
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    valve seals? so you mean those seals on the valve guides?
    steem diameter ofthe valves is 7 mm, where the seals go on the guides I don´t know the diameter
    you may have a look t a motorcycle shop, a lot of motorcycles with 800 ccm an dmore have valve shaft with 7 mm
  3. Rifledriver
    37,089
    #3 Rifledriver, Apr 26, 2016
    If you tell us what type of valve stem seal you want I might have a part number for you. If you really want those terrible Teflon seals I won't be able to help. I just say no to Teflon seals.
  4. turbo-joe
    Apr 6, 2008
    9,525
    romano schwabel
    the teflon seals work fine - but to install them it is terrible :(
  5. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Thanks , I read from the internet that there is Viton stem seal supposed to be better than the rubber stem seal . So if you do have part number for that will be good . Btw Is the Teflon stem seal always in white ?
  6. turbo-joe
    Apr 6, 2008
    9,525
    romano schwabel
    teflon is always in white
    viton is green
  7. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #7 vincenzo, Apr 26, 2016
    ...and will cold flow. I have not used it in valve stem seals before - and would need to be convinced before using it.
    What is your experience with teflon? Good? Bad? How about over time and mileage?
    rgds,
    vincenzo
  8. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #8 vincenzo, Apr 26, 2016
    Viton is a bit harder than buna - but otherwise has great properties. Some applications are better suited to buna. Note the "moderate" short term resiliance.
    rgds,
    vincenzo
  9. turbo-joe
    Apr 6, 2008
    9,525
    romano schwabel
    #9 turbo-joe, Apr 26, 2016
    vincenzo
    you may see the difference between O-rings and valve seals with different materials
    viton O-rings are the best I think, but only because the O-rings are in a nut and cannot move much. valve seals have not to get fixed and viton I think is too hard for valve seals?
    best I ever had for the old V12 F engines ( colombo serie ) are the seals from the old german NSU TT, those seals have been made of rubber and the inner diameter for the valve stems have been teflon, but only available for 8 mm valvestems
  10. Rifledriver
    37,089
    We thought they worked fine in the 70's but we figured out we were wrong.
  11. Rifledriver
    37,089
    Viton has proven to be best.
    I use a lot of 2 numbers of seals. One fits all the 4 valve heads and one fits all the 5 valve heads. If this number is for the 5 valve I apologize because it is the only one I can find right now.
    It is U.S. Seal #VS518V
    It fits some 1.6L Nissan
  12. Rifledriver
    37,089
    Throw them in hot water and they go on easy but still a terrible seal.
  13. turbo-joe
    Apr 6, 2008
    9,525
    romano schwabel
    brian
    I never use those seals again :)
