Valve stem cores | FerrariChat
Valve stem cores
Discussion in 'Technical Q&A' started by Cadillacbart, Jun 22, 2017.
  1. Cadillacbart
    Cadillacbart Formula Junior
    Nov 26, 2013
    436
    Denver, CO
    I had the tire store dismount the tires from my OEM Mondial wheels so I could begin the refinishing process. The wheels have the original aluminum valves installed. When I went to remove these from the wheels I noticed they did not replace the valve cores after the deflated the tires, so I need new cores. Are these generic for passenger cars? Something like this?:Slime Short valve core 22042 - Read Reviews on Slime #22042
  2. LBBP
    LBBP Formula Junior
    Dec 8, 2014
    485
    Near the Dragon, TN.
    Yes, they are generic for automobiles. The valve cores should be replaced with each valve stem removal/replacement. Pretty cheap insurance against a slow leak, I always lightly spray the valve stem with soapy water to detect leaks. I would also check the rubber gasket on the inside of the valve stem inner seal.
  3. Cadillacbart
    Nov 26, 2013
    436
    Denver, CO
    Thanks. Much appreciated!
