Valve Switch vs Permanently Opening for 812 | FerrariChat
Discussion in 'F12/812' started by Miefate, Apr 19, 2022.
  1. Miefate
    Miefate Rookie
    Mar 8, 2022
    7
    Cincinnati, Ohio
    Warren Watson
    Kicking the idea around about making my exhaust sound a little better. I am never one to slap a full exhaust on a new car but was researching Valve Switches vs. Permanently opening the valves.
    The pros with a switch is I can open and close it. Con is that the car needs to be taken apart a little more than I would like and things tend to rattle at high speeds after the car is disassembled and reassembled.
    Pros with permanently opening is that it cost very little. Con is that I cannot close it. Not sure how loud it gets, so not sure if this is even an issue.
    Have any insights?
  2. klinkman
    klinkman Formula Junior
    Jan 29, 2018
    543
    Eric
    Boils down to personal preference. You've pretty much done a good job outlinimg the issues.
    WOT pretty much solves it, but with the 812 it's a difficult plain to sustain. :cool:
    Thecadster and Miefate like this.
  3. JariT
    JariT Rookie
    Nov 25, 2011
    42
    Switzerland
    I have capristo remote, it gives possibility to keep silent in neighborhood and on long runs :)
    Thecadster likes this.
  4. nimamd
    nimamd Karting
    Mar 25, 2016
    104
    Trying to choose between Capristo and Forza valve controllers. My Ferrari dealer recommended Capristo as "it has a smaller size".
    From my own research it appears that the Capristo valve controller has only 2 modes:
    1. Normal Mode: The vehicle controls operation of the exhaust bypass valves. This is the stock mode.
    2. Always Open Mode: Forces the valves to remain open at all times, overriding the vehicle's ECU.
    Whereas the Forza componenti has a 3rd mode which Capriso is apparently lacking:
    3. Always Closed Mode: Forces the valves to remain closed at all times.
    Sorry if this is a bit off topic, but I would appreciate your feedback as your comment implies that your Capristo controller also has this 3rd mode to keep the valves always closed?
  5. Ngcanada
    Ngcanada Formula Junior
    May 16, 2016
    757
    Ottawa Canada
    I have the Capristo and love the fact as I can resort back to OEM mode. The biggest difference is on the down shifts as the valves remain open and there is really beautiful sounds. You don't get that in OEM.
    Thecadster and JariT like this.
  6. prits_88
    prits_88 Karting
    Feb 26, 2021
    65
    Pritesh patel
    this is all correct. i can only echo this.
    i've had both the capristo and forza. forza is a lot better. better remote range as well.
    have u thought about changing the catalytic converters? that will make the largest difference in sound!
    nimamd likes this.
  7. Miefate
    Miefate Rookie
    Mar 8, 2022
    7
    Cincinnati, Ohio
    Warren Watson
    Usually don’t like to change major components. My other weekend car is an Aventador S, so I was slightly underwhelmed by the exhaust on the 812. It sounds great but it is much higher pitched. Just trying to give it more action without changing major components on a new car.
  8. SeattleStew
    SeattleStew Formula 3 Owner Rossa Subscribed
    Apr 10, 2020
    1,019
    In the rain
    Stew
    I’ve got the capristo controller on mine and I leave the valves open all the time. It’s not that loud coming into the neighborhood at low rpm, so I just leave them open. I don’t really see any reason to close them
  9. RamsHmb
    RamsHmb Formula 3 Rossa Subscribed
    Jan 22, 2017
    1,226
    San Francisco
    James
    I have the forza and my 19 year old installed it in about 2 hours in the dark over the holiday break. Handy kid and sharp but said it was very easy. Just a little more info. And it’s forza that has the third mode…have never used it.
  10. colonels
    colonels Formula Junior
    Aug 5, 2011
    877
    The cabins of the 812 and F12 are so well sound insulated that you really won't be able to hear much unless windows are rolled down. Standing outside the car you will notice a bigger difference. That's why many people who enjoy exhaust sounds change out the entire system.
    I personally have my valves pinned open all the time in my F12 and have no issues with excess noise. If I want it less noisy I roll up my windows.
  11. veelangs
    veelangs Formula Junior
    Sep 27, 2021
    310
    Manhattan
    Vee
    you all don't notice excess drone when on the highway? I know it's not straight piped or something but that's always my fear
  12. RamsHmb
    Jan 22, 2017
    1,226
    San Francisco
    James
    When I have mine open I do notice it a bit and I put it back to normal…but I am super sensitive to sounds. Have been known to obsess over a squeak. ;)
  13. SeattleStew
    Apr 10, 2020
    1,019
    In the rain
    Stew
    Never bothered me, and I can always utilize the stereo too if it did.
    Gh21631 and RamsHmb like this.
  14. Frank_C
    Frank_C F1 Rookie Owner Rossa Subscribed
    May 29, 2004
    3,019
    Whistling through the wheat field in Texas
    Frank
    I had my valves open for a while- did it myself. Quite easy all you need to do is take the wheels off. It was not (too) loud at all. I highly recommend doing it if you don’t replace the rear boxes.
    SeattleStew likes this.
  15. nickorette
    nickorette Formula Junior Silver Subscribed
    Jun 19, 2017
    375
    Canada
    Have remotes on all the cars. Highway drone is noticeable if you keep open. But most importantly it's for the sound when having fun
