Vanquish Idle Surge | FerrariChat
Vanquish Idle Surge
Discussion in 'British' started by alexkam, Jul 17, 2012.
  1. alexkam
    alexkam Formula 3
    Mar 14, 2007
    1,116
    Sunny CA
    Alex
    My friend has a 04 Vanquish that has been sitting for about a month while he was out of town now the car has a jumpy idle, even after a 30 min drive it has a idle surge and jumps from 1k-1500 common issue with this V12? Maybe a tune-up with new plugs i told him, any thoughts?
    TIA!
  2. sunburn
    sunburn Formula Junior
    Nov 2, 2003
    694
    Dawsonville, GA
    Rick R.
    Has he tried disconnecting the battery for a few hours (overnight) and then re-connect. Turn off all equipment (a/c, electrics), without touching the gas start the car and let it run for 5-10 min while the computer re-learns. Hopefully, it will help.
  3. alexkam
    alexkam Formula 3
    Mar 14, 2007
    1,116
    Sunny CA
    Alex
    Thank you! i will pass this info on and post the results.
  4. cgperry
    cgperry Formula Junior
    Nov 2, 2003
    506
    Chas SC
    Charles Perry
    Same can be accomplished in the Vanquish using the battery disconnect in the trunk (upper right by the charging port) and the reset button behind the passenger seat. Make sure you move the passenger seat up BEFORE hitting the battery disconnect as otherwise the electric seat will be disabled and it's a ***** to get to the reset button.
    Also ask if he has had ignition coils replaced on the car. They were a weak spot on Vanquishes and many people didn't replace them as they are $$$. The replacement units seem to be a good bit better. Both the parts and the labor cost for the swap is unpleasant but necessary.
    There is also great advice on the Aston Martin Owner's Club forum if he wants - www.amoc.org. I have also had good luck just sending an e-mail to Aston Martin Works Service in England with questions. They take a day or so to get back to you but are very helpful with things to try.
  5. alexkam
    alexkam Formula 3
    Mar 14, 2007
    1,116
    Sunny CA
    Alex
    Fantastic. Thank you.
  6. calder1
    calder1 F1 Rookie
    Sponsor Owner
    Aug 26, 2006
    2,927
    Redondo Beach
    Craig
    If he needs help and is local have him call me
