360 - Variable Intake manifold diagnosis | FerrariChat
360 Variable Intake manifold diagnosis
Discussion in '360/430' started by dang2407, May 13, 2020.
  1. dang2407
    dang2407 Karting
    Apr 29, 2017
    169
    SW France
    How can you tell if the variable intake manifold valves are opening correctly on the 360? I'm chasing an overly rich high-load phenomenon so wanted to rule out the intake lengths as a cause...
  2. tifosi101
    tifosi101 Karting
    Jun 12, 2013
    90
    France
    You could follow instructions at the end of this article:
    https://aldousvoice.com/2013/01/07/ferrari-360-air-intake-system/
    Then you have to be both, one behind the wheel who accelerates strongly et an other one who looks at the levers.
    Check also the compensation valve at the center of the manifold like on this video at 4min23:
    Qavion likes this.
  3. FlyingHaggisRacing
    FlyingHaggisRacing Formula 3
    Jul 2, 2013
    1,375
    If you have a SDx or Leonardo you can make the Compensator and Intake butterflies functions work.
    May be the Launch 431 can also do it.
    Qavion likes this.
  4. dang2407
    dang2407 Karting
    Apr 29, 2017
    169
    SW France
    Thanks for the tips. Might have to be brave and position the GoPro on the fueltanks while I drive it...
