Variator Question - Campaign 97 | FerrariChat
Discussion in '360/430' started by Kevin Rev'n, Apr 9, 2014.
  1. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,503
    Honolulu
    Kevin
    I really hate to start a new thread about these but I have a major service coming up and want to be informed and make the rights choices for my car and my enjoyment.
    Here is what I see as far as info (am I right?):
    SUBJECT: Timing Variator and Tensioner Replacement - Service Campaign 97
    This campaign involves all 360 models with engine numbers below 60796 only (vin range;
    114015 to 123399).
    Is the engine number the same as the assembly number on the plaque in front of the airbox?
    My VIN is higher than the range given in the bulletin but my assy number is below it!
  2. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    No.......
    The engine number is stamped into the casting behind the base of the oil filter (or maybe pressure sender?). it's actually quite hard to read off the casting but should be logged in your documents anyway....
    A Ferrari dealer will be able to tell you if the campaign was applicable and then done on your car by checking on Modis.
  3. tazandjan
    39,169
    Kevin- Your assembly number will be way below your engine number. My 04 is 52428, and the engine number is way, way higher than that. As long as your VIN is after the published range, you already have the new parts.
  4. Kevin Rev'n
    Nov 29, 2009
    24,503
    Honolulu
    Kevin
    Whew!!!!! My Vin is way above that range! WooHoo! Thanks so much guys!
