360 - Variator Solenoid valve #195086 | FerrariChat
360 Variator Solenoid valve #195086
Discussion in '360/430' started by RodrigoVT, Apr 8, 2024.
  1. RodrigoVT
    RodrigoVT Rookie
    Apr 22, 2020
    5
    Rodrigo Valiente
    Hello
    I need to replace part # 195086 in my 360 Modena 6speed 2001.
    According to regular parts supplier is no longer available. Any suggestions will be appreciated.
    thanks
    rgds
    Rodrigo
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Maranello classic parts are showing a recon unit for sale.
  3. RodrigoVT
    RodrigoVT Rookie
    Apr 22, 2020
    5
    Rodrigo Valiente
    Thanks for the info. I already asked Luke from Maranello and he told that new is not available. Where did you find the info of the recon unit?
    Thanks very much
  4. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,853
    Memphis, TN
    I suggest buying one used on eBay. That's about your only option here, unless there's a similar unit for another make of vehicle, like Fiat.
  5. RodrigoVT
    RodrigoVT Rookie
    Apr 22, 2020
    5
    Rodrigo Valiente
    Thanks for advise. There is one in Ebay but without the cables. My mechanic in Chile indicate that is not clear thta will work attaching other cables/plug.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Just put in the pt no on their web site
  7. vrsurgeon
    vrsurgeon F1 World Champ
    16,540
    Charleston, SC
    Curt
    IIRC has some parts equivalence with maserati..
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,937
    Central NJ
    Dominick
    Thought that was only for 430
    jerbear27 likes this.
  9. vrsurgeon
    16,540
    Charleston, SC
    Curt
    You know.. you might be correct I thought it was the earlier screw solenoid..
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,937
    Central NJ
    Dominick
    If you find out otherwise please share .. I have a friend who needed one and I could not find home one ..we had to get a used one
  11. collegeboy
    collegeboy Formula 3
    Aug 25, 2007
    1,371
    Texas and Kaua’i
    Mikey
    Could not find one that I needed anywhere. I found 2 used ones on eBay so I bought them both. I’m learning with these cars, you NEED to have spares.
  12. eric355
    eric355 Formula 3
    1,226
    Toulouse (France)
    Eric DECOUX
    What was the symptom on you car ? No phase variation at all of the camshaft ? Partial phase variation ? Any error code ? Was the crankshaft/camshaft relationship stable or noisy while driving ?
    Have you tested the valve out of the car ? Is electrical circuit OK ?
  13. RedNeck
    RedNeck F1 World Champ
    12,322
    The CSA
    Me
    I honestly haven't heard much about these failing, definitely not as much as the 430. Interested to know the symptoms. How would you go about testing the solenoid outside of the car?
  14. eric355
    eric355 Formula 3
    1,226
    Toulouse (France)
    Eric DECOUX
    If I had to test one out of the car, I would :
    - measure the resistance of the coil
    - if OK, connect it to a 12 V battery to check if the plunger is moving. These valves are commanded ON/OFF through a relay. No PWM signal there, so no issue at connecting it to a battery
    - try cleaning it in an ultrasonic bath by switching it ON/OFF every 10 seconds or so
    EastMemphis and RedNeck like this.
  15. Vegardertvaag
    Vegardertvaag Rookie
    Jun 15, 2024
    8
    Norway
    Vegard Ertvaag
    Hello
    My 360 even with changed cam variator solenoid valves (used ones) still makes problems. Does anyone know if it is possible to "lock" valve open on +20 deg. full time, meaning that it dosent return to the normal position when under 3000 rpms..It might sound a bit crazy, but with no valves around we need to do something..I preefer to have more sound if not lambda sensor and emissions dosent casue other problems.
  16. Peter550
    Peter550 Rookie
    May 8, 2014
    37
    germany
    I contacted a company in Germany, who told me that they were working on the problem and that these valves would probably be available from August.
