Veglia/Borletti clocks... | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Radiopilot, Dec 10, 2009.
  1. craigf
    craigf Rookie
    May 23, 2012
    1
    Hello Radio Pilot,
    Do you still replace the plastic clock face on 308's? If so, what is the best way to communicate with you to get a quote?
    Thank you,
    Craig
  2. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,083
    I wanted to chime in that NIck helped me me out too and did a fantastic job ascertaining which of the three circuit boards my clock had to repair it! And was totally reasonable.
    Way to go!
    Highly recommend!!
  3. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Had similar situation in my recent conversion. The tach expects an analog type signal but the new ignition system puts out a digital pulse steam. Could be the initial pulse edge bumps the tach at startup but then the tach no longer responds. I solved my issue with a new tach driver board made by Alhbin here on fchat. His board if designed for this situation.
    Do a search on his name to find the links
    using Tapatalk
  4. Cazna
    Cazna Karting
    Aug 6, 2013
    72
    Sydney, Australia
    Robert
    Nick. Would you happen to have a Veglia clock for a 73 365 GT4 2+2?
  5. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    My clock keeps great time I just can't reset it other than with the battery disconnect and patience.
  6. BigTex
    79,418
    Houston, Texas
    Bubba
    You have found a thread that is four years old.....Nick has not logged in since 03/2013.
  7. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    And they say that search is your friend.
  8. BigTex
    79,418
    Houston, Texas
    Bubba
    I have two spare clocks, for my cars...no idea of they run...supposed to.
    Owners take them out, to mount Voltmeters...
  9. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Veglia clock 24 3062 (113047) seeking the time adjustment gear that is on the time adjustment shaft. Mine is stripped.
  10. emcauto
    emcauto Karting
    Jul 1, 2009
    248
    Any suggestions on clock oil.............?? to use when fixed?
  11. BJJ
    BJJ Formula 3
    1,301
  12. emcauto
    emcauto Karting
    Jul 1, 2009
    248
    I will give them a try...........I hope you had success with them , no luck in what I'm using Thanks,
  13. BigTex
    79,418
    Houston, Texas
    Bubba
    Mark, you have a GOOD memory!
    PM sent.......
  14. 997
    997 Karting
    192
    What happen to Nick? Any other reliable person/company? I need a refresh on my instruments
  15. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Anyone know how to remove the Clock? I see the comments about removing the small console. Is the Center Console in 2 pieces, the Front with the Clock and the Oil Temp Gauge, and the Rear Console with all the rest, Gearshift, Switches, etc. I am sure I can take it out a bit at a time, but I was hoping someone could tell me where to start. Thanks guys!
  16. mwr4440
    58,198
    Bavaria, The 'Other' Germany
    Mark W.R.
    Just loosen the two tiny screws in the leather covered bezel holding the gauge and clock and carefully pull and wiggle. Out it comes.
    From there it is obvious what to do next.
  17. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Thanks a lot! I did not get any answers, so I pulled it out this weekend. I pulled out the whole Center Console, Front piece and the Main Rear Console. It was a little difficult to say the least but with my wife's help we got it done! I had to loosen the Handbrake off the tunnel in the end so we could slip the Main Console over the Gearshift, but... it's done now, and I am glad I did. I can now re-dye the Center Console like I did with my seats. I will use Leatherique again as I am very happy with how the seats turned out. I have already gone over the Console with Lacquer thinner and removed all the excess paint. Just that made a huge improvement. I have applied the Leatherique Rejuvenator and bagged all the parts in plastic bags for a couple of days. I will post pictures of the finished product when I am done. Thanks for letting me know about the 2 screws, but I did try that and the damn trim did not want to budge. I was afraid I would break something, so I ended up taking the whole console out only to find what you said to be correct. But...?!!!
  18. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    So back to my original question!!! How do I get in touch with "Radiopilot"? I have sent him a message. Does anyone know if he still repairs the clocks? If not, are there any other suggestions? Thanks again!!!
  19. f355spider
    f355spider F1 World Champ
    18,059
    If you don't have any luck reaching Radiopilot, call Palo Alto Speedometer. As I posted in this thread previously, they fixed the clock in my 78 308GTS, as well as the clock and tach in my 87 328 GTS. All work was satisfactory, and reasonably quick (though this was 12+ years ago).
  20. BigTex
    79,418
    Houston, Texas
    Bubba
    He's gone...not sure where or why...
  21. Signor Buona Wrencha
    Jun 21, 2008
    79
    Albuquerque
    Aaron
    There's also MoMa here in Albuquerque. They do work for collectors around the world. Top notch!
  22. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Has anyone found a "replacement" for Radiopilot yet? Everyone I spoke to quoted over $350 to service and repair the clock, Is that right?
  23. mwr4440
    58,198
    Mark W.R.
    IIRC, I believe he said he was "going off the air" quite some time back.
    There was no stated anticipated date/time for his return.
    Just one of those F-Chat Mysteries.
  24. red27
    red27 Formula Junior
    Sep 7, 2010
    964
    London UK
    Mark Oliver
