Vent window catch on a GTS | FerrariChat
Discussion in '206/246' started by Yves Delhaye, May 10, 2008.
  1. Yves Delhaye
    Yves Delhaye Rookie
    Apr 3, 2008
    25
    France
    The vent window catches on my GTS are glued. But they are not strong enough and I am now thinking about replacing them by bolt and nut ones (84 Euros each).
    I am wondering if the original windows can be drilled with no risk, or if I have to find windows already drilled (available at dinoparts.com - 120 Euros each) ?
    Any advise will be welcome.
    Thanks in advance.
  2. Italian Lover
    Italian Lover Formula Junior
    Oct 26, 2006
    553
    Italian Lover
    #2 Italian Lover, May 10, 2008
    As Dino owners, most of us seem to "enjoy" this vent latch coming off situation. Personally, I would shy away from drilling holes choice. I have not gotten around to "fixing" this problem in my Dino, but here's what I have with my Daytona, which you might consider as an alterantive. Hope the pics help. Good luck. Jimmy
  3. dan360
    dan360 F1 Rookie
    Feb 18, 2003
    2,669
    Boston
    indeed the likelyhood of one falling off is directly related to the proximity of a car show. In fact the last show I went to I parked the car and came to it the morning of the show to see it sitting nicely on the carpet. The thought "how can the glue have failed again" comes to my mind until I inspect the part to find that it is the glass that's failed and a small sliver of glass is still nicely glued to the catch. Oh well now we used a different kind of glue which seems to be holding. Of course one shouldn't make the mistake of actually "using" them!
  4. dm_n_stuff
    Dec 10, 2003
    43,734
    26.806311,-81.755805
    Dave M.
    I don't think drilling the glass is a job for an amateur.
    I've seen a couple of other arrangements that work, including a metal strap around the window edge that the vent latch is then attached to.
    There are a couple threads here about it.
    http://ferrarichat.com/forum/search.php?searchid=2276883
    I'd glue them on, then leave them unlatched. Worked for me the last 4 years. Rear view mirror glue is what I used the last time, I think.
    Dave
  5. tx246
    tx246 F1 Veteran
    6,663
    Texas
    Shawn
    i had the same problem with the glass sliver. i would recoomend putting them in your glove box and forgetting about the issue - althought this isn't a concours competition answer
  6. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    I wrote a Saga about my fix.
    http://ferrarichat.com/forum/showthread.php?t=123335&highlight=061001
    So far, so good. I actually use the clamps. I went overboard on the size of the glue area. I believe that just adding 1/8" of length and squaring the rear of the glueing area should do fine. Probably no need to add to the height. The triangular shape I used doesn't look too good but is sure strong. 1/16" steel plate and soft solder to a modified base should do it with minimum fuss and bother.
  7. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    Ditto. One hard, fast rule we have is to never latch them, and new passengers are advised accordingly. Part of the Dino mystique!
  8. dino2X6lover
    dino2X6lover Karting
    May 26, 2015
    91
    Los altos, CA
    Do you know where I can source something like that? My window vent doesn't quite close correctly so the latch keeps popping off. I'm gojng to try to shave it to fit the window better and then install those latched you recommend. Thanks
    CC
  9. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,298
    NYC. / E. Hampton
    Michael
    My 2 cents
    I have owned a few dinos and got good at the fix
    With masking tape . Tape a dime to the glass exactly where the latch base meets the glass
    Over tape 2inches in each direction.
    With an exacto knife cut the dime perfectly out leaving the glass circle exposed
    Carefully wet sand the glass circle with 180 to 360 or such
    Doesnt hurt to sand chrome base of latch either.
    The reason the adhesion fails is lack of teeth in flat surface areas
    Sanding installs minute cavities for glue to hold
    Re adhere. Mine came out fine every time.
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  11. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    The Daytona has a metal striker, unlike the Dino's black plastic one that can be removed, re-profiled and attached to reduce latching pressure.
  12. TheMayor
    106,148
    Vegas baby
    The fly window latch is a “Dino-ism”. Celebrate its uniqueness. :)
    synchro likes this.
  13. schwoo
    schwoo Formula Junior
    Jun 22, 2013
    845
    Florida
    Marquette
    synchro likes this.
