Verify Valve Timing | FerrariChat
Verify Valve Timing
Discussion in 'Technical Q&A' started by miketarrant, Apr 18, 2007.
  1. miketarrant
    miketarrant Rookie
    Jan 9, 2004
    38
    Is there any non invasive way to verify that all is well with both valve timing and valve clearance? My Mondial QV runs very smoothly, but the 40K service says check timing and valve clearence. At the very least this costs a gasket set. It would be cheaper to dyno check the car but I'm not sure what would be a 'good' reading for rear whel HP compared to factory spec crank HP.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Valve timing and lash measurements need access to the cam lobes. You will need to remove cam covers.
    Of the two checks, I would rate valve clearance more important.
  3. fatbillybob
    Aug 10, 2002
    29,061
    socal
    ...because the timing is probably o.k. if the car runs. Worst case would be down on power.
    You can verify general timing by putting 1-4 at TDC mark and verify the cam caps marks on the 4 camshafts. You will be within a few degrees of perfect doing this. Therefore you will only need to take the cam covers off. However, if you need to change a valve shim your options are using the valve depressor tool thingy (or make one) that I personally hate or just take the cams out which is more invasive but IMO faster and more accurate; since personally I would use a degree wheel to time and pull shafts to change shims. Basically...that is invasive.
  4. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    You can pressurise the number one cylinder with low pressure (20 psi should be sufficient) at TDC on compression. Using a degree wheel you can verify opening points of the exhaust valve or the closing point of the intake valve on a degree wheel by carefully rolling the engine forward or backward and noting the point where air loss is indicated. Its a bit crude, but should be adequate for checking that the cams havnt jumped considerably. Repeat for number 5 to check the other bank. You cant check the other open/close points because both valves are in overlap and open at the same time.
  5. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Doh!!!! 2NA is correct. There is no physical way to check clearance without physically measuring it. And there is no real way to get your cams to exact valve timing, or to an altered valve timing, without a degree wheel and dial indicator.
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yes, to answer your exact question, but those non-invasive ways aren't the right way and would cost you more time/effort/money as well as be more error prone. I suspect *everyone* would frown on them.
    But yeah, if you just *had* to check the valve timing and clearance non-invasively you could use a borescope through the spark plug hole in one cylinder combined with some sort of TDC device in that spark plug hole with the car jacked up and in 5th gear while someone hand-turned a rear-wheel forward.
    Eek!
  7. bigodino
    bigodino F1 World Champ
    13,138
    The Netherlands
    Peter den Biggelaar
    How long does it usually take for a Ferrari mechanic to check the valve clearance on a 308 GTB 2v V8 engine? Thanks.
